Question about Western Digital My Book Premium ES Edition WDG1SU5000 500 GB USB 2.0 Hard Drive
Is this hardisk networkable or not..? - Western Digital My Book Premium ES Edition WDG1SU5000 500 GB USB 2.0 Hard Drive
  • 1,183 Answers
Hi, the Essential edition of Wester Digital is not networkable. The workaround is you can, share the computer to which it is connected and access the drive on the network.
If you want a networkable drive , go for the Wester Digital world edition , its available in single hardrive and dual hardrive capability for more data safety. following is the link for the same.
http://www.wdc.com/en/products/products.asp?driveid=347
Thanks
Proton
Posted on Oct 30, 2008
Laptop acer
Itu menunjukkan yang laptop kamu boot menerusi rangkaian.
Kamu harus tukar pilihan boot dalam "BIOS setup" dan pastikan Hardisk ditempatkan pada boot yang pertama. Selamat mencuba.
______________________________________________________
It looks like the laptop is trying to boot on network,
you need to enter the bios setup and make sure the hardisk is assigned as 1st boot. Good Luck.. :)
Oct 30, 2013 | Lenovo ThinkPad T41 Notebook
My hardisk doesn't recognize in my computer but appear on device manager and disk managemnt
Hello raissateddy
Go to the Control panel and select " Folder Options \View " and check " show hidden files , folders and drives " .
Best regards ,
fanaudi .,
Mar 15, 2011 | Buffalo Technology Buffalo LinkStation Pro...
Hardisk tidak bisa terdeteksi oleh BIOS apa penyebabnya dan solusinya untuk memperbaiki ?
Hardisk tidak terdeteksi bisa di sebabkan oleh :
- Bad sektor
- Hardisk sudah lemah
- Cabel data rapuh/rusak
- Power Supply tidak mencukupi untuk keseluruhan Daya PC
langkah yg pertama :
- coba ganti cable data hardisk, dan periksa PIN Hardisk masih utuh atau tidak
- Ganti Power Supply yang Daya-nya lebih besar
- Scanning dengan hardisk lain dengan menggunakan Norton Disk Doctor untuk mengecek Bad Sektor
Mar 02, 2011 | Maxtor Hard Drive
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Oct 03, 2010 | Computers & Internet
In start up my computer says system fail need a boot disk
Windows was corrupted and it must be reinstalled. Use the recovery disk that came with the pc when you bought it.
May 30, 2010 | Compaq Presario 5000 PC Desktop
I got my motherboard changed in October and my computer won't boot up "disk boot failure 0" could I have the same problem again? I don't have a disk - dell dimension C521
The motherboard is not the problem.
Your hardisk is the problem.
See if your hardisk is detected during boot up procedure.
If it does... Run again your Windows XP CD installer and repair your operating system.
Having "Disk Boot Failure" error means the boot system of you operating system is corrupted.
If your hardisk is not detected... you better check if the power supply connector on your hardisk is secured and not loose..
If still not detected.. your hardisk crashed and need to be replace.
May 19, 2010 | Computers & Internet
Hardisk
Normally is a IDE hard disc. What u can do is to unplug the copier hdd, and u can differentiate what kind of hdd is using...
Mar 29, 2009 | Canon imageRUNNER 5000 Copier
Pls help
configure wireless network
Press Fn (Function key) at the lower left hand corner and F2 at the same time.
select Internet tab>>click on wireless networks.
select the wireless network that you have, and click connect.
this is where you need to know what kind of encryption you have on the wirelss network.
select encryption type. (WEP, WPA or other).
enter passkey for the network, and Press OK
Sep 12, 2008 | ASUS Eee 4G Notebook
Data not copy other hardisk
Maybe your secondary hard drive is write protected due to third party software during the old installation of the system such as norton data recovery.
Hope this will be helpful to you.
Oct 26, 2007 | Apple Drive Module 180 GB ATA-100 Hard...
Western Digital My Book  Premium ES Edition  WDG1SU5000 500 GB USB 2.0 Hard Drive Logo
148 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
