Question about E-Machines eMachines Desktop PC
My computer wont start up
My computer when it starts up , it usually tells me to press f1 to continue then goes through the Windows XP loading screen after that goes to the ' Your disk is dirty ' scan thing , then after that it goes to login screen , but at the login screen , you cant see ANY text whatsoever. If i type any text in , it comes up with black vertical lines instead , and when errors come up , it doesnt show anything , just shows an empty error box . Is there any suggestions you can help me with?
  • 749 Answers
Reformat your computer. seems its a virus problem!
error box without any message indicates that the message display is being block by the virus!
try the press
CTRL+ALT+DEL
if the TASK MANAGER window did not appear on your screen, there's definitely viruses that had surpassed your antivirus!
Posted on Oct 30, 2008
    Problem Solver:
  • 8 Answers
Try this start your computer,press the F8 key once or twice a screen will appear chose the (last Good know configuration when you computer started normally) it should come to another screen saying (windows XP) press enter, and see if it boots to your desk top, if not restart your computer Press the F8 key again right away and chose (Safe Mode) you should see a bunch of white font sentences loading which would probably be the name of your drivers and end up on the safe mode desktop, once you get to the desk top it will tell you your in safe mode hit OK once your on the desk top go into start up/programs/accessories/system tools/system restore, choose System Restore, restore your computer back to an earlier date when you can remember it works fine, if that doesn't do it you could try to restart you computer, hit F8 again a few times and choose in able VGA and seen if that works, if not you might have a hardware problem or corrupted drivers/software/operating system etc. or try to go into safe mode and save what ever you need to save on floppy/compact disc/external hard drive etc. before you format which you don't really want to do unless you really have too.
    Sergeant:
  • 306 Answers
First try pressing F2 at start up to see if you can get to setup. Also pressing F12 may get you a boot menu. If cd is already set as first boot you may get a chance to boot from a Windows cd. The idea here is to get to a minimal Windows configuration like setup or safe mode (F8) to see if this is a hardware or operating system fault. Two common issues with eMachines are power supply problems where repetitive reboots can actually fry the motherboard or if the PC has a few years use the CMOS battery. Steve Medley
What do I press to access the bios to reset?
Re-start the computer and well before it starts loading windows press the F2 key continuously until the screen pops up. If it does not and the computer loads and opens windows you were too late hitting the key or you were not hitting the key frequently enough. In that event you need to start the process over again by re-starting the computer again.
Dec 22, 2015 | Computers & Internet
My Acer Laptop opens and runs for about 5 minutes...then goes to blue screen of death with c000021ls windows logon process system process falal error...and shuts down.
Hello
To solve this problem i do the following steps
Rebooted the system and continued pressing F8 -> got a screen that allowed for a F1: Boot -> did the F1 and continued pressing F8 and got the Safe Mode screen -> selected the Last Know Good Configuration and repeatedly pressed Ctrl+Shift+Esc sequence -> Windows XP loaded correctly! -> opened the C drive ->windows folder ->system32 folder ->restore folder -> and started the rstrui application -> selected a date prior to the download of the bad files -> and now the problem is all gone!
Hope it helps, if so do rate the solution.
Good Luck
Dec 22, 2010 | Acer TravelMate 4010 Notebook
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Laptop wont start windows xp pro. goes to a blue
Take one memory stick out and test. Then do the other. Also checking each memory slot.
If not solved. When the computer starts, continually press F8 until you get startup menu- select SAFE MODE and fix the driver or software that is in startup
or
Roll back to last known configuration that worked.
While you are there- disable Auto Reboot on Failure.
May 02, 2010 | Computers & Internet
When starting my computer windows wont let it load because it says there is a problem with a program or drive on a blue screen just after the windows xp logo appears(on screen half time normally is) i've...
Start your computer in safe mode (press F8 before you get the Windows splash screen). I usually suggest pressing F8 continuously as soon as you see anything on the screen.
Once you get the white menu up that allows you to enter safe mode, let the computer boot into safe mode and do a system restore back to when you know the system worked.
That should solve the problem.
Jan 16, 2010 | Dell Computers & Internet
Toshiba satellite L25-s1194 wont boot windows
Is it giving you any error or out of the ordinary "beeping" as it is booting?
Usually the BIOS screen comes up if it cannot find an acceptable boot device.
Can you boot from an XP cd?
Can you boot into set up mode.. usually by pressing F1 or F2 on most computers. It should tell you just before the BIOS screen comes up. Enter into "set up" and make sure your boot order is correct.
You might want to reseat your RAM.
Check to see if the hard drive is coming on.
Nov 21, 2009 | Computers & Internet
Monitor goes to BIOS Screen Repeatedly
Your monitor is fine, the problem here is with your computer, and sounds like a virus. Time to competely reinstall windows, or have a tech look at the computer.
Aug 01, 2009 | Microsoft Windows XP Professional SP2 Full...
Wont load anything including bios
Sounds like your operating system has been damaged and no longer works. You will need to reinstall it.
If its xp then u will need to put the hard drive in another pc to back up any data. If its vista then all your old files will be stored in windows.old on the c drive as long as u dont format it during install.
Hope this helps?
Dec 29, 2007 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
Toshiba Satelite
Can you tell me if your operating system is Windows XP. when it shows the windows screen is it the "boot up screen" showing and returns to the same thing?
Sep 17, 2007 | Toshiba Satellite A15-S129 Notebook
E-Machines eMachines Desktop PC Logo
183 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
