I have recently installed Netgear Wireless G Modem Router DG 834G but failed to select the path to encrypt my contacts with the internet - in other words I am a bit insecure. How do I change this please?
  • 3 Answers
Type in the routers sign in address in the address bar and you can open up the admin page. If I remember correctly, the url is http://www.routerlogin.net/ or http://192.168.1.1/ The default sign in is admin for the user id and password in the password box. User id = ADMIN and password = PASSWORD. This will get you to the default settings of your router and then you can set it up secure.
Posted on Oct 30, 2008
How to Install Netgear Router Using the Wireless Device
hi john.
To install your NETGEAR wireless router using your wireless device:
  1. Get the preset wireless settings of your NETGEAR router. It is written on the back or at the bottom of your device.
  2. On your wireless device, open the WiFi connection manager and find the SSID or WiFi network name of your NETGEAR router.
How do I install my NETGEAR router using a wireless device ...
https://kb.netgear.com/.../How-do-I-install-my-NETGEAR-router-using-a-wireless-devic...
How to Install Netgear Router Using the Wireless Device Google Search
Nov 06, 2017 | NetGear Computers & Internet
I have 7 wired computers operating from a Linksys BEFSR81 Router / 8 port switch. I would like to add a Netgear N150 Wireless Router so my kids can access the internet from their Wii in the basement . Can...
If my memory is correct even though there are 8 ports you can only use 7 of them. take out the 7th one or a couple of them if you can put them into the netgear. basically follow this: modem to linksys to netgear. as long as that path exsits they will all work. make sure to encrypt the wireless so your neighbors dont slow down your network speed or delete any of your files inadvertantly. You need to unplug from the wall electricity and have all computers off when you do this though so that they can all find then new paths. If you happen to have set up network paths with numbers suc as 192.168.123.5 and so on then you will either need to return them all to automatic or recheck these numbers after as both routers will port semi duplicate paths. When pluggin them in you may want to start plug in all the ethernet ports, then, modem, then plug in linksys plug in netgear.
now turn on all computers and printers and they should find the path automatically.
Mar 11, 2011 | NetGear WNR1000 RangeMax 150 Wireless...
Laptop cannot pick up wireless from modem
Is your Wireless router integrated in the modem? If it is not, try to unplug the router for a few minutes then restore the power and see if it fixes the problem. If it is integrateddo the same for the modem. Try to connect using the laptop. If it does not work use the laptop to scan for new wireless locations and make sure you see the home location. If you do not your wireless router is not working, If so select the home location and enter any Web Encryption Protection and try to connect. If your wireless router is not working, make sure the preference for the router has the wireless function turned on. To do this use ether the software which you received with the router/modem or internet explorer to access the IP address of the router. If your router is configured for wireless use it may be a bad wireless router.
Feb 05, 2010 | NetGear CG814M (pn-3201155) Modem
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
Dec 20, 2009 | NetGear RangeMax WPN824 Router
Power light red ,internet light red no other
Most of the time a red internet light means that the box can't find the internet / can't find it ISP / can't get on the DSL what ever.
Might be the modem, might be the power adapter.
Nov 25, 2009 | NetGear DG834 Router
Lost installation cd
Connect the computer to the LAN port of the router, connect the modem to the Internet/ WAN port on the router, access the configuration page of the router (Example 192.168.1.1)configure the router as dynamic IP (DHCP) and configure the wireless settings as WPA or WEP encryption.
Mar 15, 2009 | NetGear WGR614 Wireless Router
Do i need a disk to install a netgear wireless?
You need a network cable (cat5e) to connect the cable modem to the wan or Internet port on the router. Then another network cable to connect the router port(1-4) to the computer's network (NIC) port. If you are going wireless, you do not need to connect the second cable.
You do not need a disk. just power down the cable modem,router and computer.
Hook it all up, then power up the cable modem first, wait 30 seconds, then power up the router, wait 30 seconds, then power up the computer. You shold be able to get online.
Unless: you are using DSL
and unless the original owner had an encryption key on the router.
Dec 16, 2008 | NetGear DG834G Router
Wireless INstallation
you need to ring your ISP to get a network user ID and password, when you enter these in to the router settings the Internet light will light up green.
Jun 08, 2008 | NetGear DG834G Router
NETGEAR DG 834G ROUTER
Could you give me some overview of the topology of the network your trying to install the router on? (How it's all connected, and the ip addresses of the machines and other routers on the network (if any)) ?
Nov 29, 2007 | NetGear DG834G Router
Connecting two laptops using Netgear 834G
If its just a router and not a modem router, go into the routers settings and make sure DHCP is enabled to give each pc an automatic IP address and ensure wireless is enabled if using wireless adapters. Next go to the properties of your network card and on the TCP/IP select properties and ensure obtain IP address automatically is ticked. You must also set up using the XP network wizard and ensure file and printer sharing is set up through both pc's.
Feb 07, 2007 | NetGear DG834G Router
Computers & Internet Logo
David Payne
David Payne
