Question about Refrigerators
Water from fridge not going down plug hole into container. How ofter should the water container be emptied at the back of the fridge/freezer
I have a 15 year old sub zero refrigerator. The drain hole keeps freezing up and ice is building up under the produce drawers. There is also a smell that has accompanied this problem. We have melted the ice and forced warm water through the tube to clean out any blockage but it keeps freezing up. Can you help?????
Posted on Oct 30, 2008
Water accumulating inside the fridge
hi kostas.
Condensation runs down the back of the fridge and collects in the gully sitting at the back of the fridge where the water is then channelled through the drain hole into a container which sits on the compressor, it's then evaporated away.
How to Stop Water Collecting in Your Fridge ' eSpares
https://www.espares.co.uk/advice/.../how-to-stop-water-collecting-in-your-fridge Water accumulating inside the fridge Google Search
Nov 07, 2017 | Refrigerators
Water from fridge not going down plug hole into container. How ofter should the water container be emptied at the back of the fridge/freezer I have a sub zero frigerator #550 its about 15 years old....
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. .
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.You can use a hair dryer and remove the ice buildup
Oct 30, 2008 | Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Water is leaking inside
Clogged drain plug. the plug is located in the back of the freezer. Empty the freezer out and pour VERY hot water down the drain hole slowly this will unclog the drain and will stop water from leaking inside your fridge.
Jan 02, 2010 | Whirlpool Refrigerators
Water is collecting in the refridgerator
defrost drain under coils in freezer is blocked or frozen with ice down in defrost hole. defrost hole with hairdryer but be careful not to melt the plastic.
Jun 09, 2009 | Whirlpool ET1MHKXM Top Freezer...
Water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 13, 2009 | Refrigerators
Water dripping from top of fridge then freezing under crisper's
Jan 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Zanussi fridge freezer frostfree ZX 57/3 W not working
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube.
Hope this helps,
Sai.
Jun 12, 2008 | Zanussi ZX99 / 5 Bottom Freezer...
Fridge not working but freezer does
It sounds like you have a plugged defrost drain line. This is where the water goes to in the bottom of your freezer when it goes through the defrost (removal of ice from the freezer coil) cycle. It sounds like that hole is plugged and now the water/ice has now frozen in the vent that lets air circulate down into your refrigerator compartment. What I usually do in this case is to unplug the refrigerator, empty out the freezer compartment. Usually I also end up either pulling off the back panel or the bottom panel (in the freezer compartment) Looking for that defrost drain hole and thawing it out with a heat gun (be careful of melting plastic) or actually I use a hair dryer. I can sometimes do this also by pouring small amounts of HOT tap water onto it and then sopping/absorbing it away with a sponge or dishcloth. I repeat this until I get the water to go down the drain tube
Mar 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Water on the bottom of the fridge - then turning in ice
drain is blocked. to check, pour water into drain gulley in fridge and it should flow away. to clear, push sometthing flexible down the hole. good idea to pour dilute bleach down hole now and again
Mar 19, 2007 | Hotpoint FFA60 Bottom Freezer Refrigerator
Refrigerators Logo
125 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
