Question about RCA MM52110 52" Rear Projection HDTV-Ready Television
On and off
My set turns on and off repeatedly for about 3 minutes each time i turn it on sometimes it works sometimes it doesnt i was wondering if it would be an easy fix or even worth calling the repairman in the picture when it decides to work is perfect
  • Walkey Feb 23, 2008
    I was watching tv last night, everything was fine. This moning I turned it on, and all that it does not is the power light comes on for a few seconds then you can here it click off, then it comes back on again for a few seconds then shuts down again, and keeps repeating the cycle, until I can catch the power light on to turn it off. It does the same think with or with out the remote...
  • yaxche_a Aug 03, 2008
    el tv. enciende pero a los 5 minutos se apaga y vuelve a encender y se vuelve apagar este proceso lo hace como 5 veces hasta que se apaga y queda en espera de encender.
    President:
  • 3,130 Answers
Could ber as easy as a bad capacitor causing the set to shut down or a regulator Ic. This is not a repair for the layman to attempt as a tv set is NOT a place to experiment with.
Posted on Sep 11, 2006
Sometimes when i put it in D it doesnt respond then i turn off the car for a little while then turn it on and works, after a little while it got neutralize turn it off wait a while and a and works
When was the Last time You ahd You're Transmission serviced?, seems like the Trans Switches are Probably gummed up with Varnish from OLD fluid
Sep 24, 2015 | 2007 Ford Escape Hybrid FWD
How to reset security in 2001 yukon?
Its a 30 minute process.
Turn the ignition from off to on
Attempt to start the vehicle then relese the key to the on position for 10 minutes until or until the security light goes off.
Turn of the ignition wait 5 seconds and and repeat the above steps 2 more times, After the third time make sure the ignition is in the off position for at least 5 seconds then attempt to start the truck.
It takes awhile i had the same problem with my 2002 astro and just a note sometimes this procedure doesnt work the first time its a real pain
There is another option that requires a scan tool
Mar 18, 2015 | Cars & Trucks
Maruti/ertiga how to set clock.there is no any botton to set the clock
How to set Clock When the ignition switch is in the "ON" position, the display (D) shows the time. 2) To change the hour indication, turn the indicator selector knob (2) left or right repeatedly when the hour indication blinks. To change the hour indication quickly, turn and hold the indicator selector knob (2). To set the hour indi- cation, push the indicator selector knob (2) and the minute indication will blink. 3) To change the minute indication, turn the indicator selector knob (2) left or right repeatedly when the minute indication blinks. To change the minute indication quickly, turn and hold the indicator selector knob (2). To set the minute indication, push the indicator selector knob (2). To change the time indication: 1) Push the trip meter selector knob (1) and the indicator selector knob (2) together. w WARNING If you attempt to adjust the display while driving, you could lose control of the vehicle. Do not attempt to adjust the display while driving.
Hope this helps.
Bob
Feb 08, 2015 | Cars & Trucks
2004 gmc envoy heater intermites when using... only turns on once in a while on all settings, but seems to only work when it feels like it
I am kinda having the same problem not as bad as yours. They replaced my relay or what ever it is 2 times. When it got down to 9 degrees mine quit working again for 2 days. It started working again but took it back to dealer anyway. They had a new part they put in then they called us and told us the blower motor is burnt up and it is gonna cost us $300. We asked how it can be burnt up when it was working when we brought it in. They said I don't know but said it is. After talking to 3 people and no solution to this, we told them to put the old relay in cause we're not paying 300 for something that was working. So far still working but sure it will quit again. Will never buy another GMC produce.
Dec 31, 2012 | 2004 GMC Envoy
I have a Carrier model 42KPC019303. It turns off while running. The LED blinks five times, stops, and then blinks 5 times again in cycles. After a few minutes, it turns back on again and off again after a...
hello
1- you check thermostat .
2-maybe temp your house is below 26c.
3-you check fan condenser and evaporator .
4-maybe cut off low pressure system.
Sep 12, 2011 | Heating & Cooling
Hitachi 65F59A turns itself off
The power supply may be failing.
Sep 02, 2017 | Hitachi 65F59A Television
Monitor blacks out after running for about 25 mins
Ok based on just the monitor turning off Lets try this,,
FOR WINDOWS XP
1.) Right click on your desktop
2.) Choose properties
3.) Click on the screen saver tab
4.) Click power
5.) Set The POWER SCHEME to Home/Office Desk
6.) Set the Turn Off monitor to Never
7.) Set the Turn Off hard disk and system Stand By to never
8.) Click apply then ok
9.) Repeat steps 1 - 3
10.) Set the wait time to 30 minutes
11.) Click Ok
12. Shut down and restart your system and wait 30 minutes to see if the monitor will shut off if it doesnt then Your good to go
If it does Then disable the screen saver.. and wait half hour to see what happens
POST BACK HERE AND TELL ME YOUR RESULTS OF THE ABOVE SO WE CAN TRY SOMETHING ELSE
Jan 16, 2008 | Computers & Internet
Problem with tv turning off by itself.
I had a friend with the same problem. He had to clean the components and fans in the set. The accumulated dust had caused the set to run hot and a safety switch was the tv off. He purchased a few cans of compressed air and, as he blew the components and fans out, used a vacuum to capture the blown dust. Good luck.
Dec 27, 2007 | Samsung HL-S4266W 42" HDTV
RCA MM52110 52" Rear Projection HDTV-Ready Television Logo
91 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
