Question about Koss KS2503 System
I need a replacement fuse
The geniuses who wrote the instruction manual never put the number of amps the fuse is. Its has the volts (250V) but it doesn't say the number of amps needed to power the the system. Does anyone know the number of amps needed? Thanks
  • Johhny Yonus Sep 11, 2006
    Techman I can't find it. It only labels the voltage and the company name.
  • Anonymous Feb 19, 2008
    just recieved system from friend , no fuse in system. which amp fuse should i purchase. thank you
Yeah, my circuit board was fried. I had do get a new system.
Posted on Mar 01, 2008
9 amps try it out
Posted on Feb 27, 2008
    President:
  • 3,130 Answers
Ita on the end in small lettering on the fuse 100%.. You may need a magnifyer to see it. BUT a fusse does not blow all by its self most of the time. It will blow if there is a problem with a circuit and Will case a fire if it is replaced by a larger fude and keeps the circuit from blowing.
Posted on Sep 11, 2006
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
Can I use a 15A/32V fuse to replace a blown 15A/250V fuse
No! Unless you have read it wrong and it should be 320V. You can go higher than 250 volts but not lower. And you can go lower say to 10A and say up to 16 or 20A, though you should stay around 15A to be safe. If you do fit a 10A fuse at 250 volt and it blows straight away then it won't be the fuse that is faulty, but something inside the amp that has gone. As fitting even a 15A 250V will do the same. A 32 volt fuse in the mains section will burn out in a fraction of a second.
Dec 08, 2012 | Audio Players & Recorders
I have a pair of Technics SL-1200MK@ Turntables and I blew the fuses on the curcuit boards. I'm having trouble finding a discontinued fuse. If you know anyone selling them, please post some links for...
Any decent electrical shop should have those fuses. They tend to come in 20mm and 30mm lengths. You will need to know which. Also there are fast blow and slow blow fuses. If you have the originals and you can see the remains of a coil then you want slow blow. Otherwise just replace them with fast ones. The 1.2 amp fuse can be replaced with a 250 volt fuse.
So you want a 250ma 250v fuse.
and a 1.2A 250v fuse.
Oct 07, 2017 | Audio Players & Recorders
What type of fuse do you get for a Breeze AT EcoQuest unit?
A buss type fuse is like the glass tubeb with metal ends and just snaps in two clamp type holder. Any automotive store carries them. know what amperage, like 5, 10,15 ,20 etc. The 250 v is the norm. The fuse protects against amperage overload not voltage. They come in tins of assorted or specifc in fives. Good luck
Jun 21, 2009 | Ecoquest Breeze AT Living Air Purifier
Adjusting temp
I think your problem is a fuse in back panel has burnt out....you will need to replace it, Tthere are two fuses and one is easy to see and as usual the easy fuse is not the problem, the fuse you need to replace is probably the one in a black shrink rap on top left side of the panel. You will need to cut shrink rap off fuse and find wires. Next step cut and solder in new fuse. I belive the fuse used is a 5 amp 250v, I put in a 6 amp to repair.
Dec 28, 2008 | Oster 12-Bottle Wine Cellar - Black
Fuses for P-07
the fuse you need is a t4al 250v
this is a common slow blow 250v 4amp fuse.
You can get them at RadioShack
Oct 03, 2008 | Gemini Sound Products P07 2-Channel...
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
Projector Problems
Sounds like the fuse popped. t5a=5 amps 250v=250 volts So you will need a fast-acting 5 amp 250 volt fuse
Mar 14, 2007 | InFocus ScreenPlay 4805 Multimedia...
Koss KS2503 System Logo
231 people viewed this question
Top Koss Audio Players & Recorders Experts
Steve Allison
Steve Allison
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
