Removing RAM from Acer L320
Hi, I have an Acer L320 that I would like to upgrade the RAM in. Not sure if it is 200 pin soDIMM or other? Also not sure if there are Dimm locks like in a "full size" mother board.
any help is greatly appreciated.
    Novelist:
  • 111 Answers
The other expert's solution here gives you the information and practical steps you need to know about what to do to change the memory in a computer.
here is some additional background information you should know specifically about the Acer Aspire L320. this pc is a small form factor (sff) pc. as is common with sff computers the Acer Aspire L320 is based on laptop/notebook rather than desktop pc technology.
unscrewing the single large central silver cross-head screw at the back of the pc means the right hand side panel is free to slide out. slide backwards and lift up to remove the side panel. sliding this panel out will break the green Acer warranty seal on the right hand side of the pc so make sure your warranty has expired before going ahead and breaking this seal.
once it is open inside you will also see three small black plastic clips which hold the front plastic panel of the pc to the case. gently lever each of the three clips upwards and forwards with your thumbnail to release the front plastic panel. disconnect cable connecting the front panel to the inside of the pc (the front panel cable connector near the usually yellow Complimentary Metal Oxide Semiconductor (CMOS) or Real Time Clock (RTC) battery in the front top corner of the pc is easier to disconnect and reconnect than the one on the panel itself). thread the loose cable through the oval slot in the metal frame near the top of the front of the pc case. put the disconnected front panel to one side.
you will also see a silver panel with a black plastic handle in the center. this panel is connected to the hard disk drive cradle that contains the hard disk drive underneath. you will also see towards the center of the inside of the pc about one inch from the back of the pc a small black cross-head screw that fixes the black handled silver panel to the rest of the pc.
use a magnetic screwdriver so you don't lose the screw when you unscrew it. removing this screw means you can now partly lift the silver panel with the black handle and the attached hdd out of the pc case. using your thumb and index finger loosen and disconnect the hdd power and data cables near the back of the inside of the pc. put the silver panel and hdd to one side.
now you will be able to see the two ram slots at the center near front of the pc. you will see laptop/notebook type spring loaded ram memory slots. disconnect the other ends of the hdd power and data cables makes access to the ram slots easier. release the two catches on the side of each ram module to release it and it will spring up so you can slide it out. y there are 2 memory slots and the maximum memory each slot can take is 1gb. our pc usually comes with two 512mb ram modules. you can either replace one original ram module with a new 1gb module to upgrade from overall ram from 1gb to 1.5gb or remove and replace both to upgrade to 2gb. the memory type for this pc is a PC5300 DDR2 SODIMM RAM MEMORY MODULE.
to install new memory slot the new memory module in at the correct angle and then push it down until it clicks in place by the two side catches clicking into the semi-circular notches on the edges of each memory module.
after upgrading the ram reverse the above steps to reconnect the internal cables reinstall the hdd and silver panel and reattach and reconnect the front plastic panel.
before closing the case, reconnect all the rear cables and test that the pc starts properly and if the new memory you just installed shows up in Windows Vista Home Premium which is what this model of pc usually comes with. if so, shut the pc down and disconnect all the rear cables again before closing the case up reconnecting the cables and starting the pc again.
in Windows Vista - 'computer' - 'system properties' shows you the installed memory.
between the other expert's answer and this one you now hopefully have everything you need to know about changing memory in an Acer Aspire L320.
Posted on Nov 05, 2011
  • 488 Answers
Look at this link:http://www.crucial.com/store/listparts.aspx?model=Aspire%20L320
or go to crucial.com and use the memory scanner,its terrific!hope it helps!
Posted on Oct 30, 2008
RAM Acer Aspire 1403LC
Look for a 512MB 200-pin SODIMM DDR PC2100 266MHz
Jan 22, 2014 | Acer Aspire 1403LC Notebook
Can i put ram from packard bell easynote into an acer aspire 5315.thanks
RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) RAM / Max RAM Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support)Max RAM: Up to 1 GB of DDR2 533 MHz memory, upgradeable to
2 GB using two soDIMM modules (dual-channel support) This is the kind of memory you need, no matters the branch
Dec 21, 2010 | Acer Aspire 5315 Notebook
What ram does the travelmate 246xc support
The memory type and speed is 200 Pin 2.5v DDR PC333 SoDimm memory.
The laptop has 2 banks of memory space each supporting 1GB of ram.
Regards.
Aug 15, 2010 | Acer TravelMate 246XC (LX.T3006.191) PC...
I have Acer laptop Aspire 5570z module Zr1 with memory 1GB I want to increase memory 2GB or 3GB Is it possible or not What will be the expenditure?
Your laptop's RAM is upgradeable to up to 4 GB using two DDR2 533/667 MHz SODIMM modules.
So your upgrade options here are:
1. Buy a 1 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 2 GB (Price around US$ 25).
2. Buy a 2 GB DDR2 533/667 MHz SODIMM module & install it to get a total RAM of 3 GB (Price around US$ 45).
Aug 14, 2010 | Acer Aspire 5500 5570-2609 Laptop
I have an Acer Aspire 3680 notebook with 512mb Ram.What type of Ram do I need to upgrade
it must be DDR type of Ram. dont use DDR2 ram.
you can use 1 GB DDR of Ram
Oct 12, 2009 | Acer Aspire 3680 Laptop
Hi i have an acer aspire 5315-2326 laptop and i want to upgrade the ram from 1gb to 2gb. what kind do i get? do i replace or add 1 more gb? and what kind of ram do i use? thanks
I would advice you to add one gb more with same value, kind and frequency this you can read on the installed module after removing it from your laptop
Aug 20, 2009 | Acer Aspire 5315 Notebook
Install new ram in Acer aspire L320?
Sorry- I have to disagree, One screw at the back releases the lid. Inside, the dvd/hdd sub-chassis has one screw holding it to a brass post on the mobo. Undo that, then lift the chassis slightly with it's plastic strap handle, so you can detach the two connectors from the SATA drive, and the ribbon cable to the DVD (careful you don't bust the latch).
Then the whole lump simply lifts out- and you can see the 2 memory cards. The one I've just looked at appears to have 2 x 512mb simms- so you could replace these with 2 x 1024mb DDR2 SDRAM simms, to give 2GB of ram, which is what Acer say is maximum.
Cheers- AL (Luton)
Apr 03, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
I want to up grade my RAM
I'm afraid the highest frequency ram for your laptop is DDR 333. The highest capacity is 1024MB DDR333, 333MHz, PC2700, 200 pin SODIMMs.
Nov 18, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
