Question about Acer Aspire 3000 Notebook
Computer hangs up
As i trun on the computer it starts normaly and after few minutes it hangs up. i have formatted the Hard Disk twice but still receiving the same problem.
Can any one help me in this please. Its really urgent.
Regards
  • barcham Oct 31, 2008
    I have exactly the same problem. I have also noticed that if I remove the battery and run it on AC, it works fine. I was wondering if this is possibly the sign of a failing battery but have not been able to find any confirmation of this. And I'm not about to spend any money of a new battery just to discover it makes no difference.
    So for the meantime, my portable is not very portable at all.
  • genny123 Oct 31, 2008
    thanks a lot this really helped. I have urgently asked for a new battery.
    Thanks a lot once again.
Hi I have this problem too with a Aspire 3000, try this take your battery out I did and its fine never locks up not once.
Posted on Oct 30, 2008
    Guru:
  • 257 Answers
You dont need those stress you will only be concern on your processor or do you use the pc with a network as in is it connected for browsing if itis connected try and always clear your cookies and again the processor fan may not be blowing well so it can cause it to be freezing all the time once the processor works too much without cooling fan ok try and do something about that your system will be ok
sure
Please rate this solution.
On startup os logo hangs up
Is not compatible with your device
Mar 20, 2013 | HP Compaq 6730b Notebook
How do you set up an external hard drive?
Turn your computer on and plug the external hard drive into the computer.
Open "Computer Management" by clicking "Start," "Control Panel," "System and Security," "Administrative Tools" and "Computer Management."
Click "Disk Management" in the left pane under "Storage."
Locate your external drive from the list of hard drives connected or installed on your computer.
Right-click the drive and select "Format."
Select a file format from the drop-down menu. Choose "NTFS" if you will be using the external hard drive with a computer that uses Windows 7, Windows Vista or Windows XP.
If you will be using the hard drive with an older version of Windows, select "FAT32."
This is a much less common format.
Click "OK" twice and your external drive is formatted. Once the drive is formatted, it is properly set up to be used with your computer.
hope this helps
Sep 10, 2012 | Computers & Internet
I've zebronic 845 gl mother board, p4 2.4 ghz intel processor, samsung 80 gb hard disk,256mb hynix ram. when i run any program in windows xp sp2 , my system is hangged after few minutes, i press c
First you might need to have service pack 3
XP Service pack 3
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
a slight overhaul of your computer
second clean your computer of dust using a fine air blower from a compressor specifically around your CPU central processing unit making sure there is no MOISTURE in the airline
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
test or replace all the leads that attach to your hard drive including electrical extensions IDE SATA the ones that attach from your motherboard to hard drive make sure they have secure dust free connections
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
then click start run type cmd then type chkdsk/r/f which will automatically scan for and attempt to repair bad sectors and fix any corrupt files this will schedule to happen on restart
another way of running the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart
you should not do anything while the chkdsk utility is in progress any input may damage your computer your hard drive then defragment your hard drive
you have to keep a computer very clean & free of dust and give it regular maintenance
also you might download and use this registry cleaner it is 100% totally free to use
http://download.cnet.com/ccleaner/
and you might need to uninstall some unnecessary programs
right click in the bottom toolbar select task manager applications you will see whats running
also in processes see whats ticking over
do have any tune up programs installed on your computer
hope this helps
Apr 26, 2012 | Intel Computers & Internet
I bought a samsng g2 external hard drive and now i it keeps showing THE DISK DRIVE IS NOT FORMATTED,DO U WANT TO FORMAT IT?i always format it when i will use it..so i quick format and the comp. hangs..what...
You just bought the HD? Have you put anything on it yet? If not, letting the computer format the drive should not hurt the drive. It will format it so that it can be use for data storage and the like. Formatting will format it so it can be wrote to, but also will erase anything that is on the hard drive. Hope this helps.
Jul 17, 2011 | Samsung (SP1614C) 160 GB Hard Drive
My PS3 display's the following message when i turn it on..."The hard disk's database will be rebuilt" - When i click 'ok' it displays "Rebuilding the database, do not turn off the system." - Immediately...
s_kounou
If the hard drive is hanging on the format the drive table may have just gottten corrupted. This can happen with a computer but the operating system can fix this usually. The link below will take you through connecting the hard drive to your computer and using it to format the drive. If the computer hangs on the format and/or you still have trouble with the drive then there is something wrong with the drive and you will have to replace it.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Prob with hard disk
IT IS NORMAL FOR THE HARD DRIVE TO BECOME VERY HOT WHILE WORKING. I WOULD SUGGEST YOU TO CHANGE YOUR RAM ONCE AND TRY. HANGING ISSUES ARE MOSTLY RELATED TO RAM.
Apr 10, 2010 | Samsung (SP0822N) 80 GB Hard Drive
Hang-up
hello. try to find original manual and check & try to set jumpers. Before that remove the battery and put it back in if you didnt try that, so the mboard will reset. hope helped any
Dec 18, 2008 | Asrock 775i65GV Motherboard
Hang poblem
have you try to check disk first? scandisk then, try to defrag your computer.. then restart your computer.. if your computer hang again.. i suggest to backup all your files if you have flashdisk or an external harddrive.. so you can format your computer.. then you should upgrade your computer memory..
Mar 26, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
