Question about Marantz SR-14EX 5.1 Channels Receiver
Receiver defaulting to factory restored settings after every Power On/Off
Owned this receiver for about 5 yrs. Recently, after every power on/off, the receiver defaults to factory restored settings. This means I have to go into the Setup screen each time to match the inputs to the components already plugged into the back; set the speaker levels, etc. This is really annoying since the unit's factory default for "DVD" is "D5"...but the Toslink Optical input (best quality for DVD) is only in slots D1 or D2 (Sources 1 or 2). Once I change this, I'd like it to "stay"...makes me think there's one of those watch batteries inside the unit that retains memory that needs replacing??
gadget
  • 14 Answers
SOURCE: playing itunes through receiver
On the back of your tower you should have auxillary outputs that will go into your receiver. Get a connection going between the two ports and you should have perfect sound. The sound that comes out of your headphone output will not really have the amount of power that your receiver needs. Hope this helps.
Posted on Sep 15, 2006
SOURCE: I can not get surround mode on my Marantz 5200 receiver
Check surround mode on the on-screen menu of the amp
Posted on Feb 29, 2008
  • 163 Answers
SOURCE: Input signals Marantz SR4003
There are four digital connectors on the back of the unit: 2 optical and 2 coaxial. They are marked a s 1 2 3 4. 1 and 2 are optical, 3 and 4 - coaxial. Also you have front optical connector marked as F.
You can connect 5 digital sources to your receiver. For example, connect your DVD to input 2 (optical) by optical cable and connect your DSS to input 3 by coaxial cable. Assign DVD to digital 2 and DSS to digital 3 in input setup menu.
Posted on Aug 15, 2009
  • 169 Answers
SOURCE: Marantz SR-18EX Loses Memory and Has Distortion on Center Ch.
take the case off (Carefully of course) and look for the watch battery, replace it, and unless something is gone in the memory itself, enjoy!
Posted on Aug 17, 2009
  • 11800 Answers
SOURCE: Hello, I have recently purchased a
You don't get the OSD on the screen because either the HDMI cable for the TV isn't plugged in the OUT plug (the one on the right) or the tv isn't set on the correct AV source (it should be n HDMI1 - if you have plugged the cable correctly on the tv).
Posted on Aug 21, 2010
Reset after power outage
some of these had resets others reset after you unplug it for about 20 minutes and replug it in. some older models you had to hold in the power button for 5 to 10 seconds.
Apr 23, 2014 | Pioneer VSX-11 Receiver
Tip
Reset factory default settings for yamaha HTR-5650 AV receiver
How to reset yamaha HTR-5650 AV receiver (maybe others) to factory default settings:
1. turn power off.
2. press the 6ch input and stereo button simultaneously for 4 seconds. Then while holding down these 2 buttons, turn the power on.
3. press preset tuning to the right until option #9 is selected.
4. Then, press program button until the *RV option is selected.
5. turn power off, wait 10 seconds.
6. turn power on, settings are reset.
on Feb 10, 2009 | Yamaha HTR-5650 Receiver
Hi i want to restore factory settings my rxv 995
(input mode key)+ ((AM/FM key) lastly Press (power key)
When diag menu appears select 8
when sub menu appears select RESERVED
use tuning up/down at MAIN MENU and
program up/down to move for SUBMENU
Sep 13, 2013 | Yamaha RX-V995 Receiver
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
I have a upro go I get an error window saying invalid master index file when trying to power up and play golf.
Welcome to Fixya
Sounds like there is a software issue with the device. Try to restore it to original factory default and test the issue again.
Restore the factory settings by going to the Device Settings screen within the settings menu. Under the Device Settings, choose Factory Defaults.
Thank you for using Fixya
Jul 12, 2011 | Callaway Golf Company uPro Handheld GPS...
When my receiver is plugged into my boom box, I get a display reading "check cradle for power"
It's not receiving enough power from the boombox so the voltage drops too low for the receiver to function properly. Check the cradle connector for bent or pressed pins and the power source of the box for proper functioning: measure the voltage it delivers and the status of its components, especially the filtering capacitors.
Jul 04, 2011 | Delphi Roady XT XM Radio Receiver
I cannot connect to the internet using my netgear n150 wireless router. The internet light is orange but the modem is working fine and I can connect to the router itself.
When the router is turned on, the Internet light turns amber for about 20 seconds and then turns green. If the light does not turn green, the router has a problem. If the Internet light is still amber 1 minute after turning on power to the router: a. The Internet is not accessible. Confirm that you have the correct internet setting. b. Clear the router's configuration to factory defaults. This will set the router's IP address to 192.168.1.1. c. Turn the power off and back on to see if the router recovers. If its still not working, reset to factory defaults. You can restore the factory default configuration settings that reset the router's user name to admin, the password to password, and the IP address to 192.168.1.1. To restore the factory default configuration settings: 1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink (see "Back Panel" on page 4). 2. Release the restore factory settings button, and wait for the router to restart, and for the Power light to stop blinking and become solid green. The factory default settings will be restored so that you can access the router from your Web browser using the factory defaults.
Jun 06, 2011 | Computers & Internet
I want too restart my aspire as in backto zero, i cannot connect to internet
Not sure what you mean by back to zero. If you want to restore it to its factory default condition, then do the following which will not only clear all user data but remove any malware or viruses. Before starting the procedure, make sure the netbook is plugged into its AC adapter to ensure the restore to factory default condition proceeds to completion without being interrupted by low battery.
1. On power-up while the Acer logo is showing...
2. Press and hold down the Alt key then press the F10 key repeatedly
3. Screen should then indicate starting the Acer eRecovery Management environment.
4. Wait until eRecovery has loaded and its menu asks How would you like to restore
5. Click on Restore system to factory default
6. Once retore is complete, the system will restart Windows for setting up its configuration
Jun 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
There is an orange "i"
The orange "i" means that the Ethernet cable connection to the modem has been detected.
The light should be blinking green for Internet connectivity.
I advise you to reset the router:
1. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings button, located on the rear panel of the router, for about 5 seconds, until the Power light begins to blink .
If resetting the router does not correct the issue, you should call your ISP (Internet Provider) and check if they are having a problem.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
I cant log onto the web site or ip 192 thing to change my password,i cant remember my password and want to change it, but the site is always down or an empty page.... why cant they just make these things...
Here is the procedure to reset the system to factory default:
To use the restore settings button:
1. Locate the restore factory settings button on the rear panel of the router.
2. Use a sharp object such as a pen or a paper clip to press and hold the restore factory settings
button for about 5 seconds, until the Power light begins to blink.
3. Release the restore factory settings button, and wait for the router to restart, and for the Power
Here is the link to download the manual.
Best of luck, Jim
May 01, 2011 | NetGear WNR2000 Wireless Router
Marantz SR-14EX 5.1 Channels Receiver Logo
48 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
