Question about RCA 14F512T 14" TV
My TV is making cracking noise
It started few days ago when the TV was working for some time, suddenly it started to make cracking noise which is very loud and I stoped useing ever since.
Model: Technika pro
HD Digital LCD TV/DVD
Freeview buit-in
Nicam Stereo Sound
  • 3 more comments
  • Wojtek99 Oct 30, 2008
    It started few days ago when the TV was working for some time, and suddenly it started to make cracking noise which is very loud and I stoped useing it ever since.
    Model: Technika pro
    Freeview buit-in
    Nicam Stereo Sound
  • rocton58 Dec 02, 2008
    tv cracks and pops noisely and picture wiggles as it cracks. This occurs for about the first five minutes. Then stops. 15 year old Mitsubishi 40in tube. Love it no problems.
    Rocton58yahoo.com
  • Anonymous Dec 05, 2008
    It actually wakes me up in the middle of the night. A lough crack and I know its the tv but I dont know what to do..
  • Anonymous Jan 03, 2009
    Hi ,have a new 46" touch of color series 7 lcd from samsung and today as a matter of fact have heard some loud cracking/popping sounds no idea what it would be. Sounds kinda like the cover housing plastic snapping.
  • mike wold Sep 24, 2012
    Can samsung and other companies pay mike wold for figuring out the problem of the crack noise caused by tv sets
Its the plastic cassing making the noise. If you press the tv together along the edges you will here a crack. Samsung and others did not use 99 cent padding between the plastic and the metal you need cushion padding. Its like not using a gasket or seal. Its a simple fix but the tv companies say its expansion.
Posted on Sep 24, 2012
SOURCE: RCA TV stopped working
Time to go to BEST BUY and nuy a better tv
Posted on Apr 16, 2008
snakehead
  • 1074 Answers
SOURCE: popping noise
The anode cap on the back of the tv tube is leaking the high voltage be careful as going into the back of a tv it store very high voltage and could be fatal.the solution to problem get a tube of clear or red silicone discharge the high from the tube,you do this by getting a alligator clip with wire attach clip to a ground wire on the back of the tube attached the other end of the wire to screw driver gently push it under the Anode cap you will hear a popping sound with i little sparks. remove the cap from off the tube get some alcohol wipe the dirt away apply the silicone around the anode and the anode cap place in on back and leave it to dry and cure for about 7 hrs close up back and turn on your tv and all the popping sound is gone.good luck.but if it is the wire for the anode cap that comes from the flyback is the one leaking change the flyback.again good luck.contact me on fixya.com or email me at nicodhem@yahoo.com
Posted on Apr 24, 2007
  • 1694 Answers
SOURCE: Snap Snap Pop
Probable bad IHVT ( aka flyback transformer ) part # 257805
or Asti 2078...................................T.
Posted on Nov 09, 2007
  • 75 Answers
SOURCE: my tv has picture, but no sound (lots of hash sound)
should replace capacitor ( c 1010 marked on board if it is a M134C chasie also (c 1013) both capastors are 10 mfd at 16 volts. Also check (Q603) rca part number 266897 could be bad.
Posted on Mar 01, 2009
  • 3 Answers
SOURCE: crackling noises while tv is on
We had a TV that did that once and the TV repair man said it was a CRT leak which is flamable. So you may want to be careful with it.
Posted on May 27, 2010
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Hl72a650
color wheel issues replace light engine
Jul 07, 2013 | Televison & Video
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Apr 16, 2017 | Splendide 2000S Front Load Washer / Dryer
Crackling noises while tv is on
May 27, 2010 | RCA Scenium D34W20 34" TV
Exessive noise when in spin cycle?
Could be dirty bearings. As long as it is still spinning, it is nothing to worry about. If it suddenly stops one day, it is probably frozen bearings or the brushes in the motor.
Jun 23, 2009 | Maytag Dependable Clean Top Load Washer,...
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Tv turns it self off after only 2-3 seconds and makes crack noise
Since the set is less than 1 year old, it should still be under warranty. Request warranty service.
The noise you are hearing is probably arcing inside the set on the power supply board. Continuing to attempt to turn on the set will only make things worse. Please request warranty service as this is unusual for a TV that new.
Dan
Jan 16, 2009 | LG 50PB4D 50 in. Plasma HDTV
It seems serious enough
you must first determine where the noise is coming from it could be simple as being unalanced
Oct 20, 2007 | Samsung RB2155 Bottom Freezer Refrigerator
Panasonic PT-53WX54 What is that popping noise?
A loud popping noise, like a sharp "snap!", is usually caused by high voltage arcing. Somewhere in the high voltage system an insulator may be cracked or loose, such as the plastic around the flyback transformer or one of the rubber cups on a picture tube. When the high voltage arcs, it momentarily drops and the picture could go out for a split second. High voltage is dangerous in projection sets so allow a qualified tech to service it for you.
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
RCA 14F512T 14" TV Logo
2,624 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
