Question about LG Flatron 915FT 19" CRT Monitor
Screen width keeps changing
Whenever I switch on my monitor it comes up with the resolution I expect - 1024 x 768. However, after a couple of minutes it sort of 'clicks' and the screen resolution changes to what I imagine is right for a widescreen display (maybe 1280 x 768). Then after a varying time - can be anything from 2 mins to 20 mins it 'clicks' again and all is ok again. Is this something I can fix or is it a sign of a hardware problem? I've tried using the OSD and played around with various settings but this doesn't help. The monitor is about 4 years old. Thanks.
This is a hardware problem. There's a high wattage resistor inside which normally gets quite hot. Eventually this resistor desolders itself due to heat and breaks the circuit. Any repair-shop can fix this by re-soldering mentioned resistor (it is easy to distinguish it by its brownish color) using a suitable solder or by replacing this resistor by a more powerful one. Another workaround is to change a video mode to, say, 1280x960 or 1152x864 (while in these modes, monitor circuit bypasses the said resistor).
Posted on Apr 26, 2007
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
Width of the screen is increased by itself. Now I want to fix it.
It could be the graphic card is not setup for the system you have. I would get the driver from the manufacture on the web for the monitor and or update the setup that came with your system also from the manufacture of your computer. IF that don't work I would try another Monitor.
Mar 30, 2012 | Computers & Internet
"Not Optimum Mode","Recommanded Mode 1280
FIXED : Before you start your legacy game, software where the "Recommanded Mode 1280 x 1024 60Hz" keeps showing, change your display FROM VIDEO CARD DISPLAY control application to 1024x768 or your choice.
My Syncmaster 2233 had same problem of "Not optimum mode" box coming on whenever I started any old game like Age of Empires etc. It got fixed by selecting FROM DISPLAY CARD DRIVER CONTROL UTILITY's (mine from Catalyst Control Center) >Set desktop area to > 1024 x 768 in my case BEFORE STARTING old application/game. Switch back to your normal resolution after you are done with this application.
Hope this helps.
Regards
Saurabh
Jun 29, 2011 | Computers & Internet
How to enlarge a picture that is scanned or copied? When i scan or copy a picture it is too small and I want to enlarge it in order to view it better.
hi
Open an image. Go to the Image Menu and select Image Size. This is where you can change an image’s resolution and print size (width and height). The following Image Size dialog box will appear:
Notethat the width and the height of the image as you view it on yourmonitor is not necessarily representative of the image’s actual widthand height—i.e., the size it would print out at (print size).Average monitor resolution is 72 dpi. If you view a 72 dpi image at100% in Photoshop, chances are that it will appear on your screen inits actual print size. However, this is not true when viewing a 300 dpiimage. A 300 dpi image viewed on-screen at 100% will be enormous. Don’tget tricked into believing that what you see on your monitor is whatyou’ll get when you print or place the image into another application.The best way to determine what your image’s actual print size will beis through the Image Size dialog box.
When the Resample Imagebox is checked, any changes you make to an image’s width or height willnot change the image’s resolution, and as such, any changes you make toan image’s resolution will not affect the image’s width and height.Keep in mind, however, when you increase width and height, orresolution, with the Resample Image box checked, you are adding pixelsto your image. These pixels don’t actually exist so Photoshop mustcreate them. As such, you will succeed only in degrading the quality ofyour image.
If you want to increase an image’swidth and height, or resolution, then uncheck the Resample Image box.Now any changes you make to the image’s width and height will changethe image’s resolution, and vice versa:
  • If you decrease resolution, the width and height will increase.
  • If you increase resolution, the width and height will decrease.
  • If you increase the width or height, the resolution will decrease.
  • If you decrease the width or height, the resolution will increase.
Thebest way to increase the width and height of a scanned image is to scanthe image in at a high resolution (about twice what your finalresolution should be), and with the Resample Image box unchecked, decrease the resolution. Once the image width and height is where you want it, you can then check the Resample Imagebox and type in the resolution you want if the resolution is too high.At this point, as long as you don’t increase resolution, or width andheight, your image quality will not suffer.
Aug 07, 2010 | HP Officejet 5610 All-In-One InkJet...
Monitor width has changed ....cant see start and clock... even buttons on monitor for shape is not responding...
assuming wondows machine - anywhere on the desktop right click go to properties go to settings tab and adjust your screen resolution up.
Keep me posted.
Jan 30, 2010 | LG Studioworks 700S 17" CRT Monitor
I am not sure why but I notice that my desktop screen is about 1" less to the left on the width. I did purchase a couple programs to hel p speed up my computer, and I suspect that this is what did it. how...
Dear User,
The size of desktop depends mostlyh upon the screen resolution. Though there are other ways to set desktop to its fullest to screen size as:
  • Right Click on the Desktop, go to Properties, then click on Settings. Here you'll find the option to change the screen resolution. Try setting it to best according to you. Click on Apply, and you are prompted to choose whether you want to keep this setting or revert. Choose the option that suits your need.
  • Other option is through the adjustment buttons on the front side of Monitor. Use these control to set the screen to its fullest.
Thanks
Jan 22, 2010 | Computers & Internet
By tessadupre on Oct 03, 2009
im positive its the inverter board going bad
Oct 21, 2009 | E-Machines eMachines Monitor E15T4
Monitor wont stay on- blue light is on. but screen keeps going blank.
Have you tried the monitor on another computer? If so, and it works, the issue is with your graphics settings on your computer. LCD and plasma based monitors often come with a protection circuit that disables the monitor if the synch or refresh rate are beyond it's capabilities. this is to protect your monitor from damage.
Do not exceed your monitor's max resolution.
Resolution is determined the following way:
Width x Height @ Refresh Rate
For your model:
  • Max Resolution 1440 x 900 @ 75Hz
More detailed information about your monitor can be found HERE. If your monitor is still under warranty, and you find it to be faulty, you may be able to send it to the manufacturer for repairs.
May 30, 2009 | Acer X193W LCD Monitor
HP W1907 Monitor goes black after resolution change
This is normal, but it should only take less than a minute for your computer to readjust, make sure all your graphic card drivers are updated, for that may be a factor.
Contact me if you need more detailed explaining.
Regards,
Asitomani
Jan 30, 2009 | HP w1907 LCD Monitor
Iacer 5520 lapptop screen won't come up to normal size
You to change the setting of your monitor that is found at the bottom of your monitor some near the power button (of your monitor when you turn on the monitor) it is a push botton where you can change the width, height, etc. not on the resolution or any program found in your computer.
Thanks
Nov 19, 2008 | Acer AL1717 17" LCD Monitor
LG Flatron 915FT 19" CRT Monitor Logo
103 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
