Question about HP Computers & Internet
Hi, my hp montior has started to become blurred.
  • kane88 Oct 31, 2008
    my monitor is an HP w19b/w19e wide lcd monitor and is only 2 years old. is there another soultion as to why things are going blurred regards kane88.
  • kane88 Nov 03, 2008
    thank's for the quick responce.
    Brigadier General:
  • 6,966 Answers
Assuming that your HP monitor is conventional CRT type and thatno hardware/component fault, the dimness of a monitor signifies near end of life of the CRT (tube).
There are a few tricks/tweaks that can be done but of course these are just prolonging the inevitable. Additionally, this would require experience (not only familiarity) working with high voltage circuitries. Should you want to give any of them a try, they are:
  • Adjust the Screen controller at the rear of the Flyback Transformer (FBT) to maximum effective brightness. It may also be needed to adjust the Focus control;
  • In some versions, there are sub-bright and/or Automatic Brightness Limiter (ABL) trimpots soldered direct to the PCB that can be adjusted;
  • the heater voltage can be slightly increased either by using a stepdown transformer that has multiple taps about 1~2 amps. In some instances, the heater has an external loop around the core of the FBT, adding a turn or so would also serve the same;
  • adding a 100uF/160V capacitor after the diode of the FBT's output that supplies the B+~70VDC of the 3 color drive transistors.
Again, all of the above require experience and knowledge of electronic components and circuitry, use of a soldering iron and working around high voltages. If you are not comfortable going through this route, perhaps your best bet would be to seek the services of a qualified professional.
If your concern has not been corrected after completion of the above procedures, you may need to replace the monitor.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FIXYA.
Posted on Oct 30, 2008
  • Louie  Role
    Louie Role Oct 31, 2008
    Hi again,
    Appreciate you correcting my assumption.
    There would only be two areas in an LCD monitor that would account for your concern:
    • CCF (cold cathode florescent) lamp is getting weak or the inverter powering them is producing insufficient power; and/or
    • video driver board (main board).
    Although there are instances when the main power supply is the issue where the boards are getting lower than the regular power and produces several faults including the blurring.
    Initially, I would suggest that the unit be opened up for a look and see. Common culprits on most LCDs that we have worked on involve dried up or blistered capacitors that would exhibit a variety of symptoms/faults. Of course extreme care as the inverter produces a high frequency high voltage power for the CCF Lamps.
    Cheers.
The display on my hp laptop has become blurred and out of focus, i have adjusted the settings on the "personalise" option but it remains blurred. Is there anything I can do about this?
Good Morning.
This could be a hardware issue, releated to Video card of the Laptop.
Please try updating the BIOS of the Laptop, this may fix the issue, if still the issue persists, then this a hardware issue. Could be with LCD display or video card.
To update the bios, please refer the link below.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01056794&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
This should fix the issue.
Jul 06, 2011 | Computers & Internet
Whenever i hookup montior to my hp pavilion it shuts it down somtime go to blue scene
Hi
It sounds like you are having an issue with your laptop's video card. I recommend you try to update the driver of the video card first or reinstall it using the driver disc from HP.
Thanks for using Fixya
Mar 06, 2011 | HP Pavilion dv7-1245dx Notebook
I have Compaq V6000 series laptop with AMD Processor & nvidia graphic card ,my laptop?s lower half of screen becomes blurred & will become ok after some adjustments & again become blurred when...
There was a TSB about the motherboards on the V series describing severe video issues and Nvidia GPU failures. Many consumers got a motherboard replacement. Try using a laptop cooler in the meantime and see if that helps a little. Also try googling V6000 video and see how many others got nuked by this poor design.
Mar 13, 2010 | Computers & Internet
Display become blur when switch on
your disply cable or LCD faulty replace it
Feb 26, 2010 | Computers & Internet
Photo blurred
THE DRIVER OR PROGRAM HAS BECOME CORUPTED SOME HOW AND YOU NEED TO UPDATE OR DO A TOTAL RESTORE ON THE VIDEO SOFTWARE IF YOU HAVE THAT OPTION AND
BEFORE YOU EVEN DO THAT I WOULD TRY THE
SAFE MODE FIRST
UNPLUG AND DISCONNECT ALL POWER FROM THE SYSTEM FORCING IT TO START IN WINDOWS SAFE MODE, YOU WILL NOT HERT ANYTHING, ALL US TECHN DO IT ALL THE TIME.
RODGANDYSR
Mar 09, 2009 | HP Pavilion dv6000z Notebook
Montiors shut off
if the monitor goes into standbye when you plug it into the computer , it generally means there is NO signal coming from your video adaptor.
Plug the old monitor in , if it works, ide suspect the new monitor(s) are not working correctly.
if it doesnt work , you need to restart the computer in safe mode by repettitively tapping the f8 button as the computer starts, before it says "starting windows".
If you have a signal on your monitor in safe mode, then most likely you have a bad or corrupted video driver and it will need to be updated.
if you have no video in safe mode , you will need to remove the cover and physiclly check that all add-in card power cables and memory chips are squarly seatied in there slots. MAKE SURE YOU UNPLUG THE COMPUTER AND DISCHARGE ANY STAIC BUILDUP IN YOURSELF BY GROUNDING (TOUCHING) SOMETHING METAL BEFORE YOU TOUCH ANYTHING INSIDE THE COMPUTER.
AFTER YOU CHECK THESE THINGS AND TRECONNECT THE POWER AND TRY TO START......POST AGAIN HERE
Feb 18, 2009 | Systemax Venture PC Desktop
Montior
okay make sure your plugging the monitor back in securely
Either you need a new monitor or video card if what you are saying is correct did the video card in your system become lose
Jan 18, 2009 | Acer Aspire T135 PC Desktop
Dgm monitor no sound through speakers
have you got the correct leads plugged in?
have you removed and reinstalled the device???
Have you got another set of speakers to try???
Jul 24, 2008 | HP Compaq WF1907 Monitor
Blurred Corners
hi there, its a decousing problem, look for the connection of the decousing which is connected behined the pic tube to the board. check some electronic parts, it may be temperature resistor, termistor, transistors, capacitor, etc.ty
Dec 25, 2007 | LG Studioworks 775N 17" CRT Monitor
Computers & Internet Logo
85 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
