Question about Euro-Pro Steam Generator EP8020 Iron
Heats up but no steam coming out.
My iron heats up fine - the generator turns on and the light show that the iron is ready for use. When I push the stem button on the iron it clicks but no steam comes out.
  • 3 more comments
  • ritzy3 Oct 18, 2008
    iron heats, lights come on, iron sometimes makes a growling noise, but no steam comes out.
  • Anonymous Mar 15, 2014
    Steam generator heats up fine green light comes on. Water is taken from the base to the units but not steam, iron unit itself does not heat up, the light on the iron unit does not come on r
  • Anonymous Mar 23, 2014
    button steam function fine - no steam in normal ironing mode
  • Anonymous Mar 29, 2014
    No steam coming and only a clicking noise.
  • Anonymous Mar 30, 2014
    used self button to clean iron and now it wont heat up and just the automatic switch light comes on
    Genius:
  • 1,074 Answers
Take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Posted on Apr 18, 2007
SOURCE:
I have a EURO-PRO X Model EP965 Steam Generator seems to working but steam is not coming our, neither for the iron nor for the brush.
I think you have a tank that is calcified and is not getting enough heat to the water assuming there is enough water in it. If it was blocked it would either cause the relief valve to vent or explode.
I would start by cleaning it, my best guess would be to run a few cycles with vinegar in it. This is a mild acid that will dissolve the calcium deposits. Try maybe a 50%-50% with vinegar and water.
Be sure the vinegar will not damage the unit, I do not know.
Hope these links help.
http://www.sharkclean.com/manual/EP965-instruction_book_0701A.pdf
Euro Pro EP965 Use And Care Instructions Manual
Euro Pro EP965 Carpet Cleaner User Manual
Questions Answers for euro pro steam cleaner iron
May 29, 2016 | Euro-Pro Irons
MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON does not provide steam
My MORPHY RICHARDS 42256 JET STREAM STEAM GENERATOR IRON has stop producing steam. I have changed the filter and although it heats up, it does not produce any steam.
Feb 29, 2012 | Irons
The iron heats up, but when the steam generator button is pressed no steam gets through at all.
Chemicals and minerals in the water have probably clogged the vents. Empty the water. Pour 1/2 cup WHITE vinegar into the reservoir. Turn on your iron and let it heat. Then press the steam generator button several times until the vinegar is gone. Unplug the iron. As it is cooling, take acotton swab and gently wipe the surface of the vents. You can probe GENTLY with the swab, but don't push it into the vent or the cotton head may get stuck.
As you're pressing the steam button, keep the iron in the ironing position, not standing. If the vinegar just will not come out of the vents, use a wooden toothpick to loosen the build up.
This always works well for me and I hope it does for you.
If so, please come back to Fixya and rate my advice!
Jul 20, 2011 | Russell Hobbs 13153 Iron
Hi iv got a hinari steam generator iron hin001 that comes on and heats up but no steam comes out when you press the button and theres a standby sign flashes on the display can you help me please
don't spend your money on a calc cartrage it will not get it out of standby.
the controll unit carnt tell if it needs replaceing!
if the standby light is flashing it means it carnt heat the steam tank. if the iron is not heating as well it is a buggerd control pcb!
if you live near Newcastle I could fix it for 20 pounds
Paul@rochy.com
Feb 03, 2011 | Maytag MLI7500A Iron
Dear Fixya, The iron heats up but there is no steam coming out of my ''Stirella No Problem'' steam iron. Both the lights stay on and the green boiler light goes out and this indicates that the steam is...
This has worked for my SX8040D, but may not be a permanent solution. Fill the reservoir with clean tapwater - not demineralised or softened and not bottled water. Turn on iron and wait 20 minutes. Then try.
Jul 26, 2010 | Irons
My steam iron does not produce steam it heats up good but no steam comes out
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 29, 2010 | Rowenta Steam Generator DG050 Iron
Conair steam cleaner sc20 - plugged in, pushed button, no steam
If you need instructions go to www.HandBookLive.com. There are videos for GS4 and GS10 under Appliances category. It says that steam is produced in about 5-6 minutes after you turn power on. Also there is a low water indicator light on GS10 that kills power to teh unit if the water level is low. Maybe that's the problem... Not sure if sc20 is similar
Apr 15, 2008 | Conair Compact Garment Steamer Iron
Water and iron heats up but no steam comes out.
there is most likely a small port where some particles have clogged...fill reservoir with vinegar and water (50/50) and allow to soak 24 hrs, then reheat then shake vigorously to drain then rinse then retry
May 18, 2007 | Euro-Pro Steam Generator EP8001 Iron
Euro-Pro Steam Generator EP8020 Iron Logo
977 people viewed this question
Top Euro-Pro Irons Experts
Bruce Showalter
Sheldon Dedek
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
