Question about Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo
Tv will not turn on/off with or without remote must unplug any info will help thanxs
Magnavox rs2568c602 on/off trouble
Need tv code numbers for gemini universal tv remote so i canprogram to my magnavox tv set
Code for your Gemini universal remoet to progrmme your magnavox TV are
080,120,130,190,270,300,0054, 0706, 0030, 1454, 1254
Thanx
Aug 05, 2010 | Gemini 1 Device Universal Television...
Need a tv code for Magnavox. Using
Code for Magnavox TV are
0054, 0030, 0179, 1254
Thanx
Aug 01, 2010 | One For All URC-3300 Remote Control
How to get off choldlock whitout a romote on a magnavox tv
You cannot remove childlock without remote control.
You will require a remote control to remove childlock because the control pannel on TV is locked so you will not be able to operate it.
Thanx
Jul 27, 2010 | Philips Magnavox 27MS343S 27" TV
I have a 1996 magnavox tv that is in demo mode and you can only turn the tv off by unplugging the tv
Those older Magnavox sets had a demo mode available from the on screen menu. Go to the menu and disable the demo mode, that will fix the trouble. When in the demo mode you will have no control over your set by remote or front panel controls. You can still address the menu though to turn off the demo mode.
Apr 17, 2010 | Televison & Video
Magnavox 27ms343s tv won't turn on manually or with remote, help
If you are comfortable with tool sthere is a fuse inside the unit right where the plug goes in. I would check this first. Caution unplug it first VERY high voltage inside 30,000 volts!!!
Mar 24, 2009 | Philips Magnavox 27MS343S 27" TV
Magnovox HD2763C401 dead sometimes
MINE STARTED DOING THE SAME THING RECENTLY BUT HAS WORKED WITHOUT A GLICHE FOR 22 YEARS
Oct 30, 2008 | Philips Magnavox 27MS343S 27" TV
No remote to turn off Closed Captioning
if your tv has a menu button on it enter and try ot turn it off via thr front control buttons
Apr 07, 2008 | Philips Magnavox Learning Universal Remote
Open Questions:
Panasonic PV-DM2799 27 in. TV/VCR/DVD Combo Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
