I can't install an S400SP printer to my Computer
  • uglybetty Apr 19, 2009
    cant find software to install printer
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Have you attempted your install with the USB cable attached?
    Worldvet
  • 3 Answers
What is your OS?
Posted on Oct 30, 2008
MP Navigator EX not installed
There are two possibilities. Maybe drivers does not support the operating system, or maybe the wrong drivers installed.
Solutions for possibilities drivers do not support OS
1. Download drivers from Canon Support & Download
2. Select Product category = Multifunctional Inkjet Printers
3. Product series = Pixma
4. Model = Pixma MP258
5. Document type = Drivers & Softwares, then click Find
6. Select OS = Example; Linux
How to install the the printer driver
Install the printer driver, then connect the USB to the computer. If the USB cable is plugged into the computer, then install the new driver, happens is the failure of drivers install process.
Solution to fix the drivers install error
1. Unplug the USB cable from the printer, to the computer.
2. Uninstall all software and drivers are already installed, then restart the computer.
3. Insert the Driver CD, do the install process. About a 90% of the install process, it would come the request "connect the printer to the computer".
4. Connect the USB cable, with a computer.
5. The computer will detect the printer, and install process will continue until completed. After the install is complete, the printer is ready to use.
Hope it helps
Nov 14, 2011 | Canon PIXMA Office Equipment & Supplies
Canon mp258 printer can not fine driver on my computer it only picked up the scander part
Possible causes of failure:
1. Error install driver process
How to install the correct driver canon
- Do not connect the printer to the computer. So, turn on the printer but do not connect the printer to the computer.
- Insert the driver CD and do the install process.
- At the time of the install process, it would appear the request connect the printer to the computer.
- Connect the printer to the computer. The computer will detect the printer, and install process will continue until completed.
- Then, press the START - Printers and Faxes - Right click the Canon MP258 series Printer - select Printing preferences - click Maintenance - Print head alignment - Align print head - OK - etc. Perform print head alignment until completion (approximately 3 times the heat print alignment). Print head alignment, to configure the printer and computer.
- After the print head alignment is completed, the printer is ready to use.
Install the wrong driver canon
- Connect the printer to the computer, then perform install process.
- Solution: disconnect the USB cable from the printer to the computer, then uninstall the drivers and applications that are already installed, then restart the computer.
- Repeat the process to install in the correct way.
2. Drivers don't support the operating system
If you need a Canon MP258 driver download here:
Canon Support and Download
- Follow the link
- Product category = Inkjet Multifunctional Printers
- Product series = PIXMA
- Model = PIXMA MP258
- Document type = Drivers & Software
- Click Find
- Select OS = example : Windows 7
- Download driver printer; MP250 series MP Driver Ver.1.04
- Download driver scanner; MP Navigator EX Ver. 3.04
I hope this information helps. Thank you for using FixYa!
Oct 07, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
I just moved apartments, reset up my printer/computer, now computer is not acknowledging the printer. When I try to print it will say "connecting, 78% completed) and then nothing actually comes out.
MAKE SURE YOU HAVE YOUR PRINTER SET ON DEFAULT AND THAT IT IS INSTALLED PROPERLY! OR YOU CAN ALSO TRY...UNHOOKING YOUR PRINTER, SHUT DOWN YOUR COMPUTER AND HOOK YOUR PRINTER BACK UP BEFORE RESTARTING TO LET YOUR COMPUTER INSTALL YOUR PRINTER.
IF YOUR COMPUTER DOESN'T RECOGINIZE NEW HARDWARE, SUCH AS YOUR PRINTER, THAN IT IS NOT SET AS YOUR DEFAULT PRINTER!
YOUR SOFTWARE MAY NEED TO BE CORRECTLY INSTALLED, MAKE SURE YOUR PRINTER IS NOT HOOKED UP WHEN INSTALLING SOFTWARE.
SOFTWARE HAS BE INSTALLED FIRST, AND RECOGNIZED...THEN RESTART COMPUTER WITH PRINTER (HARDWARE) HOOKED UP!
Aug 25, 2011 | Office Equipment & Supplies
When I try to scan or print a message comes up telling me to ck power and usb connections. I have unplugged and restarted computer 4 times and still have problem
It could be a communications error message, the printer is not communicating with the computer.
  • Disconnect and then reconnect the USB cable.
  • Disconnect and then reconnect the printer power cable.
  • Restart the computer.
  • Remove and reinstall the printer software
  • If your printer does not function properly or communication error messages appear when using your printer, you can remove and reinstall the printer software.
    1. Click Start®Programs or All Programs®Dell Printers®Dell Photo AIO Printer 962®Uninstall Dell Photo AIO Printer 962.
    2. Follow the instructions on the computer screen to remove the printer software.
    3. Restart your computer before installing the software again.
    4. Insert the Drivers and Utilities CD, and then follow the instructions on the computer screen to install the software.
    If the installation screen does not appear:
      1. In Windows XP, click Start®My Computer.
    In Windows 2000, double-click My Computer from your desktop.
      1. Double-click the CD-ROM drive icon. If necessary, double-click setup.exe.
      2. When the printer software installation screen appears, click Install or Install Now.
      3. Follow the instructions on your screen to complete the installation.
    Communications error message
    The printer is not communicating with the computer.
    Dec 06, 2010 | Dell 962 Photo All-In-One InkJet Printer
    Install my printer
    1. For Windows XP, install the software CD that comes with it.
    2. After installation, plug in the printer cable into the PC
    3. When the printer detects by itself, Windows may ask you to restart the computer.
    4. You may be told to print a test page.
    5. Let me know if you have any issues.
    6. If you do not have the drivers, click here to download.
    Thank you for rating the solution.
    Jan 04, 2009 | Canon Office Equipment & Supplies
    How to install the lexmark E120 network printer
    to clarify this, you need to install the printer in a computer that is connected to a Local Area Network lets call it computer 1. Once the printer is connected to the computer 1, share the printer by going to the start/settings/ printers. Right click on the lexmark e120 printer and click share. Click share this printer. Once done the printer that is connect to computer 1 is now on the network. on the other computer lets call it computer 2, to to start/settings/printer and click add printer/ select network printer and then browse the printer in the network and select it so that it will be added. Now you computer 2 has a network printer installed. try printing, make sure not to turn off the computer 1 when printing, or else it wont print.
    Dec 22, 2008 | Lexmark E120n Laser Printer
    Please down load s400sp printer software
    go to www.usa.canon.com they have the software and driver you will need to download and get printing.
    Oct 23, 2008 | Air Tools & Compressors
    Canon S400SP Offline
    see the mode of printer by right click on printer icon and make to online and also chek is it pause or some thing just do that your printer will work.
    bye
    Oct 06, 2007 | HP DeskJet F380 All-In-One Printer
    jasbo
    jasbo
