LG Plasma 5 years old has 4cm black line from top to bottom of screen
  • 507 Answers
Just mark where the line is, then dismantle it. You'll find a connector & film at the same spot as the line (bottom of screen) . On this film is SMD resistors, resolder them VERY carefully, as these can go dry joint. Clean connectors
Assemble
Posted on Oct 30, 2008
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Top of screen had 2 6'' lines across top of the screen,then it went all distorted and shut itself off. the unti is a 50'' lg model 50pg25 and is only 9mths old what caused this and is it upgradeable to the...
You can't upgrade a panel tv, plasma or LCD.You may have had a plasma panel failure,I sell LG tv's and for the panel to go bad is rare but I have had it happen approx.6 times in the past 5 years.I highly recommend contacting LG"s customer service they will stand behind the panel and get you going again.Good luck!
Nov 22, 2009 | LG 50PX5D 50 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
LG 50PC5D rigth screen colored lines 12''
LG 50PC5D-UL Plasma TV.... While playing XBox360 the screen just shrunk to the top 3" as though some one was holding a towel over the bottom portion of the screen. I have unplugged all inputs and the unit. I have let it cool down. Still it remains in this condition. I can't see the menu because it's in the portion of the screen that is "blacked out". What do I do?
Jan 18, 2009 | LG 50PC5DC 50 in. Plasma HDTV
Hitachi 32" Plasma TV fault on screen thin pencil type line on left hand side of screen from top to bottom. Line thickness is approx 1mm TV is 5 years old Thanks Tom
iav a sky 42 inch plasma model number pd54250 when i swich it on i av got a green lined picture sometimes it comes on with a full picture can you help
Nov 22, 2008 | Televison & Video
Dell W5001C 50 in plasma - vertical black line
the y-boards are not the problem. its the e or f board located on the bottom of the panel open the back cover and look at both for potential burn spots around the silicon sealant. if one or r brown, theres your problem. ebay the board number and get it fixed.
Aug 18, 2008 | Dell W5001C 50 in. Plasma HDTV
Black horizontal line 1 pixel high
Depends on what area the line is in the bottom half or top?
Mar 10, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Vertical bar on Daewoo Plasma screen
YES YOU HAVE DRY JOINTS UNPLUG FROM POWER SUPPLY REMOVE THE BACK/ INSIDE YOU SHOULD SEE AT THE BOTTOM SEVERAL RIBENED CONECTORS FROM THE SCREEN ITSELF? UNDERNEATH YOU SHOULD BE ABLE TO SEE 2 OR 4 COMPONENTS CAREFULLY APPLY A HOT SOLDERING IRON AN SOLDER THE ONE THAT YOU ARE HAVEING PROBLEMS YOU SHOULD NOW HAVE FULL PICKTURE AGAINE ANY PROBS email me andymay2@msn.com
Mar 09, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
Electro Med Services...
