Question about Teledyne Laars HEAT EXCHANGER ASSEMBLY, DP-350 - 10403602
Replacing High Limit Switch
We have a Teledyne Laars hotwater boiler with a high limit switch which has a manual reset. We have to do the reset very often and I am looking at replacing the switch.
I am entertaining the idea of replacing it myself but I am curious as to what to expect in the process, or whether it is sufficiently complex that I should call in the pros.
  • 125 Answers
It is just threaded into place. once you get to it - it is a pretty simple process.
Posted on Mar 04, 2009
Reset hi limit switch
there might be a resettable one in the top if you take it off if not replace fusible link if bad if ok replace the hi limits under where the plumbing goes in
Mar 20, 2012 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
Where is the hi temp limit switch located?
where is the high temp limit switch located on my laars 44000 pool heater
Jun 02, 2010 | Jandy Laars LX Pool Heater / 400,000 BTU /...
(natural gas) the heater comes on for 3-5 minutes and then shuts off, and won't work again for hours. this is a shred heater between the pool and hot tub, but never used for the pool.
Check your high limit switch inside of the heater. Usually when the high limit switch pops it will take about 4 to 6 hours for it to reset itself without you resetting the system.
May 16, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a laars swimming pool heater, there is gas coming into the valve unit but it will not pass the valve block to light the pilot light.
Disconnect the pilot tube from the valve and pass a thin wire through it to make sure it is not blocked. Spiders have been known to nest in tubes off-season. If the tube is clear and the gas still won't flow through then the valve block probably needs to be replaced. If the high temperature limit has been tripped the valve will have to be replaced as high limit safety does not reset.
Aug 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars LX400P pool heater Hi Limit Switch light is on? ???Fix?
This indicator normally means that your water temperature in the pool heater exceeds the internal limit. The corrosion should not be causing this problem. Since the high temperatures can be dangerous, you will probably have to contact a pool professional to service the machine.
May 31, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars HEAT EXCHANGER ASSEMBLY, DP-350 - 10403602 Logo
520 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
