Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
I cannot connect to the Wireless router Gateway if i type the Ip address of the router gateway. I am able to access the internet but sometimes gets disconnected if am using wireless connection. I am using a HP laptop. Can anyone help.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
try to reset the router!!
what router did you used!!!
Posted on Oct 30, 2008
Connecting wireless cam with different ip address
An IP camera is a video camera that can be viewed over a Local Area Network or the Internet. The camera typically is monitored locally from a computer via the network to which the camera is attached. With just a few additional configurations of your network, you can access the IP Network Camera so that it can be monitored remotely using the Internet. This is the benefit of a network camera, as it can reside on an IP network and the video stream can be accessed or saved remotely.
Get the Default Gateway of your IP. Do this by entering "ipconfig/all" in your Command Prompt and hitting "Enter" on your keyboard. Your IP information will be brought up, and number you are looking for is the Default Gateway. This is underneath the IP address. Identify this number by its number pattern, which will look like the following: 111.222.3.4. Access your router. This is done by simply typing the default gateway from Step 1 above into the address bar of your Internet browser, and pressing "Enter." Forward your port by configuring your camera. Open the configuration section on the router web page where port forwarding is located by clicking on the "Applications & Gaming" link along the top of the page. In this menu, click on "Port Range Forwarding." Configuration sections can be located differently with each kind of router. Find this information by referring to the documentation that came with your router when you purchased it. Access your camera over the Internet. To do this, type your public IP address into the address bar of the web browser and press "Enter" in the same way as described in Step 2 when entering your default gateway. Note: The public IP address is different from your regular IP address. The regular IP address identifies computers and other devices on your network, whereas your public IP address is what is used to make yourself known to others on the Internet. Your Internet service provider can supply you with your public IP address if you call them and ask for it.
Viewing an IP Network Camera over the Internet http://www.networkcamerareviews.com/articles/portforwarding.html
Apr 18, 2013 | ASI Trendnet Wireless Tew-639Gr 300Mbps...
How to open asus wifi router home page?
In order to access the web interface of the router you should know the IP address of the router. Please try the following steps to check the ip address on the computer which is connected with the router (wired/wireless doesn’t matter).
1. Click on start the go to run and try cmd and click on ok.
2. Type ipconfig and press enter.
3. look for the default gateway numbers.
the default gateway is the address of the router. Open internet explorer and type http://default gateway numbers (for example http://192.168.1.1)
It should take you to the web interface of the router on which authentication is needed. The default user name and password is admin and admin.
Let me know if it help.
Rashish
Aug 09, 2010 | ASUS WIRELESS ROUTER |WL-520G - RT...
When typing 192.168.1.1 into my address bar I get a not connected error screen when I am connected. Trying to find the wep key to set up an xbox
On your computer, open a command prompt (Start>Run> type in CMD), and the type in "ipconfig" without the quotes. This will give you the IP address and the default gateway. Type the IP of the default gateway into your internet browser (it may not be 192.168.1.1). If it still doesn't work, try putting https://192.168.1.1 in the address bar. If that still doesn't work, then make sure you're connected to the router with an ethernet cable and not over wireless. Some routers do not allow wireless client computers to access the configuration page. Good luck.
Feb 27, 2010 | Gateway Wireless-B Router (wbr-100)
Intermitant signal
on your computer goto start - run - type services.msc and press enter.goto wireless zero configuration and enable it. now goto start - run type msconfig and press enter then goto startup and uncheck your netgear adapter.press apply and OK or close. restart your computer.goto start - control panel - network connection then right click wireless network connection and view available wireless networks.select your network and connect.once it`s connected goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it. now right click wireless network connection again and click on properties and double click on internet protocol(TCP/IP).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
this will fix your problem...
Jun 11, 2009 | Arris SURFboard SBG900 Wireless Router...
Wireless set up problem - no gateway ip or limited connectivity
Connect using Lan Cable
be sure to enable java on your Browser.
Use ONLY IE: some router refuse other browser.
SET your PC on a static IP address on SAME subnet as your router (but of course different IP).
If subnet concept is NOT clear to just just ask here.
When connected with router (on Lan Cable) check every setting (WPA-PSK) TKIP key, Broadcast / Channel etc.
You can also disable every WLAN protection and restore it later.
Activate WLAN connection WHEN you are STILL connected.
Last but not least: SET your DNS IP address = your gateway IP (router)
Feb 07, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Router connecting to Linksys USB adapter
to confirm if your Network adapter's assigned IP, subnet, Gateway & DNS
  • Start > Run > cmd
  • at cmd prompt type: ipconfig /all
  • look at the parameters given to your Network Device that is connected to the router (IP, Subnet, Gateway & DNS Servers.
  • Verify those addresses if they are reachable by pingging. Check your IP, Gateway, then check for the DNS Addresses. Type cmd prompt: ping ip_address << do not omit the periods between the numbers.
  • See if there are replies from those addresses. if you get Request timed out, tell us here which part you get one. if you can receive a reply from those addresses (gateway & DNS Servers) definitely you are already connected to the internet. Just check your Browser's connection setting.
Jul 06, 2008 | Linksys Computers & Internet
Internet access problem with a Linksys 54g router
Try setting the default gateway on the laptop to the ip address of your ICS gateway machine. Some routers separate the wireless and LAN connections on different subnets.
Try comparing your laptops ip information with that of one of the working wired computers. You can do this by going to Start up to run and type cmd then click "ok"
At the black prompt screen type "ipconfig" without the "".
You want to compare the IP Address, Submet Mask, and Default Gateway.
If one has an ip of 192.168.1.* and the other has 192.168.0.* then the wireless and wired are on seperate networks.
If the subnet masks are something like 255.255.255.0 and 255.255.255.1 they are on seperate subnets. Both should be fixable by putting in the same default gateway.
For example if your ICS gateway is 192.168.1.1 then set that as the default gatway on the wireless laptop. This can be done by going to start >> Control Panel >> Network Connections then right click your wireless connection and goto properties then double click on the "Internet Protocol (tcp/ip)" option. This will list all of your ip information (if its static) if its dynamic (ip gotten from router) you can still click "Use the following DNS server address" and set preffered dns to the gateway ICS ip. Or click "Advanced" and click Add under Default Gateways and add the gateway ICS ip there.
Jun 20, 2008 | Computers & Internet
Password setting not going
Hello there.
You need to give the correct IP address to connect to your router through your web browser. 192.168.0.50 is most likely your Vista PC's IP address, not the D-Link router.
To find out what IP address to type into the web browser please do the following:
1) Press the "Windows" key + "R" on the keyboard, at the same time.
2) Type "cmd" without quotes in the run box and click "ok"
3) Type "ipconfig" without quotes.
Notice it says Default Gateway followed by an IP address, this is your router's IP.
Hope this helps.
May 04, 2008 | D-Link DWL-G700AP 802.11g/b Wireless...
Static IP on machine, no outside access
Double check that the Default Gateway in TCP/IP properties is the routers LAN IP address (By default this is 192.168.1.1) Without a gateway installed, there will be no Internet access. After verifying this go to Start>Run and when the "Run" window appears type command into the "Open" Field, then click OK Once the Command prompt appears type in: ping 207.69.188.185. If you don't get a reply, the gateway is not installed. If there is a gateway already installed, check for any third party firewalls that may be installed on your computer. These can sometimes block Internet access. For more information please see the related article on assigning a static IP address behind the router. If still having problems, contact Linksys Technical Support.
Feb 16, 2006 | Linksys BEFSR11 Router
Feb 16, 2006 | Linksys WRT51AB Wireless Router
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
75 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
