Question about Garden
Riding tractor blowing fuse
I have a 2000 Poulan Pro lawn tractor with the 18.5 Twin V Intek Briggs engine and last weekend it blew the 15 amp fuse. I replace the fuse and it will start the mower and I can use it for some time... but after I shut it down and attempt to restart it, it blows the fuse after the engine starts to run (5-10 seconds). I have looked for any shorts but have not found any... and that should cause the fuse to go immediately anyway. I replaced the seat switch and ignition (matching parts from a like unit) but the same thing happens. I do not know how to diagnose if the voltage regulator could cause this? Thoughts?
  • blind_eagle
    blind_eagle Nov 25, 2008
    Unfortunately I had not received the post from 4x4papa prior to doing a few more tests. I had checked the switches and for the grounding. I had not disconnected the battery. All good suggestions. --What I did do was disconnect the voltage regulator and start the unit on battery only power. It ran fine and did not blow the fuse after several restarts or running for a few minutes. Once plugged back in it blew immediately. I ordered a new volt. reg. and installed it... no problems yet.
  • 14 Answers
Put a volt meter on the battery when running. Shouldn't be higher than 14.5 or so. if so, it's overcharging. If you checked for shorts, did you run a continuity (ohm) test with a meter to see if the fuse is going to ground in anyway....do this. Disconnect battery completely, ground cable first. With fuse removed check each direction of fuse wires. If getting an indication of going to ground, unplug ignition switch. still grounding? check starter solenoid with ohm meter for grounding. With wires disconnected, check between battery side of solenoid and body of solenoid where it mounts, or a good chassis ground. (you might check that the solenoid mount is grounding to the chassis first) Then between the starter side. And the small connector from the ignition switch. It should not be going to ground at all. The ignition switch sends the ignition to ground to stop the engine, and the safety switches go to ground to prevent starting when in improper position. One of these switches could be faulty as they also allow voltage for ignition through when in proper position. Check switches. If two blade, it should open or close when operated. If 4 blade, one side is open, the other is closed when operated. With ohm or continuity meter, connect to two blades on 4 blade switch and see if they connect. Push button and see if there's a change. Try the other two blades. You should see a change on both, but different. Again, two of the blades (connectors) will see each other, two will not when button pushed. Same on two blade switch. Either open (see each other) or closed when button depressed. If not, bad switch. Some of these riders came with a 30 amp fuse, by the way..... 4x4papa
Posted on Nov 15, 2008
Popular Pro 625 series. starts and runs but why does it die while cutting?
Poulan PR625Y22SHP Lawn Mower User Manual
homeappliance.manualsonline.com > ... > Poulan Lawn Mower
Poulan PR625Y22SHP Lawn Mower User Manual ... Briggs & Stratton 850Professional-Series Commercial Replacement Push Lawn Mower Engine (190cc, 7/8
Sep 11, 2015 | Garden
What is the compression lbs for a 18 hp brigg/stratton intek engine
Not sure where to get compression pounds for this, but let me refer you to the Briggs website for detailed product specs and power curves.
Intek can be twin or single sylinder.
For Twin....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-series-v-twin
For single....the are in 1/2 HP ratings but the link is below....
http://www.briggsandstratton.com/us/en/engines/rider-mower-engines/intek-with-xrd-single-cylinder
If further detail is required, I will need the model type and trim found on the valve cover.
Aug 18, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Where to buy a new oil filter and fuel filter?
You can buy a new oil filter and fuel filter at the briggs & stratton website here are the exact links
oil filter http://www.briggsandstratton.com/engines/shop/parts-and-accessories/part.aspx?id={803C6266-A7A3-4F83-A56E-8148DE31F0F6}&cs=Intek%E2%84%A2+with+XRD+Series+(V-Twin)
fuel filter http://www.briggsandstratton.com/engines/shop/parts-and-accessories/part.aspx?id={7135A082-B7B4-4F72-B4AF-29FBEBB661C5}&cs=Intek%E2%84%A2+with+XRD+Series+(V-Twin)
Regards obliqueridge
Nov 19, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Brigss and Stratton engine getting to much fuel
I HAVE A BRIGGS & STRATTON INTEK 18.0 ,JUST FINISHED CUTTING THE YARD,WENT BACK ABOUT 20 MINS LATER TO PUT LAWN TRACTOR AWAY. WILL NOT TURN OVER WHEN I TRY TO START, FUEL LEAKS OUT OF THE EXHAUST AND AROUND THE BOWL
Jun 19, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Battery want charge... ok i paid to talk w/ a
Sounds like the voltage regulator is bad--will run the battery down!
Feb 27, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical engine 24hp,48in riding lawn mower,keeps smoking.
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Oct 21, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Engine starts but won't stay running
an easy way to know that is to start engine and give it a shot of starting fluid ,if you can keep it running by this method I would replace diaphragm.
Jun 18, 2009 | Briggs & Stratton Briggs Stratton Intek V...
What kind of oil for a husqvarna riding mower?
Yes SAE 30 is the recommended oil for B & S engines. You can find it on amazon for good price. here: Amazon com oil 30w . Hope this was helpful. cheers
Jun 14, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
729 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
