Question about Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop
Gas stovetop flame pattern
I have a gas cooktop and the tips of the flame are a yellow/orange color instead of the blue at the base of the flame. Is that an issue? I check for a breeze but no fans or HVAC on.
  • jgilbert4901 Oct 30, 2008
    My 3- or 4-year Kenmore Elite cooktop has an intermittent problem like this. That is, usually I get a blue flame but sometimes it is orange. Sometimes the orange color persists several days, but then just as I am getting concerned it returns to blue. A couple of years before buying this range, because of low pressure we spent considerable money replacing a leaking old natural gas line (running from the meter to the house), so we assume the problem is not there.
3 Suggested Answers
  • 2976 Answers
SOURCE: creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Posted on Jul 03, 2009
jumptrout51
  • 3361 Answers
SOURCE: Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Posted on Sep 29, 2009
Yellow flame
The problem is with the orifice leading to the burner. If it is not centred then you will get yellow flame. Or you are impeding the flow out of the burner and it is not mixing properley. I would pull the burners apart and make sure everything is clear and the orifice is centred.
Apr 14, 2014 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
New cooktop ! long flame yellow tips black deposits on pans
This is probably the result of inefficient burning of gas resulting in sooty deposits being left on the base of saucepans etc. It may be that the gas jets are blocked with spilt material and need cleaning. Try removing the gas hub with the gas jet holes in and sliding a paperclip sized rod into each hole to dislodge any material. Blow in the holes afterwards to force any loose material out. If this fails you may need a gas fitter to adjust the gas mixture regulators.
Nov 03, 2013 | Smeg 23 in. SE64 Gas Cooktop
I am using propane for my cooktop but all my pots and pans have been turning burnt black soot on the bottoms. It's ruining all my other dishes now from the dishwasher spreading it all over, We tried...
You don't have the right Gas to Air ratio..... Not enough air to the burners or you are running to low of gas pressure for propane... Propane takes a smaller orfice or operate than Natural Gas.....
You should have 10" of WC for Propane operation..
You will need a manometer to check it.
The flame should be a blue color with no yellow in it. There should be air shutters right at the orfice to each burners. You will have to play with the adjustment to get the best blue flame with no yellow in the flame.... Hope this helps.....
May 17, 2011 | Jenn-Air JGD8130 Gas Cooktop
Hi - I have a 4 burner GE gas cooktop. The clicking sound comes from all the burners but 2 of them are difficult to light. If I hold my hand over the top ... they will light! Is there an adjustment that...
Usually this happens if something has been spilled or a pan overflowed and is partially clogging some of the burner holes. Make sure the burner holes are clear and try poking them with a sewing needle to make sure. I am assuming the flames are a nice blue color and not a lazy yellow or yellow-tipped. If there is some orange, that is usually an indication you are burning off some food and will need to be cleaned. If that doesn't appear to be the issue, then let us know and we'll dig deeper. Douglas
Sep 18, 2010 | GE 30 in. JGP328 Gas Cooktop
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
Flame in cooktop (3rd one) seems to be mostly blue with orange tips appearing here and there, but is agressive and pots almost burn with food not cooked. No way to turn down on a sealed cooktop. Is this...
if your on propane you will get a little bit of a orange tip. need to see if your model has shutter valves. this adjustes the gas air mixture
Jun 22, 2009 | Cooktops
Burner flame on GE 5 BURNER cooktop (JGP637) is orange
You have trash, corrosion or a mis-aligned part.
Check and repair these and you will be fine.
Feb 20, 2009 | GE 36 in. JGP628 Gas Cooktop
Creda 4 burner, converted to LP
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop Logo
138 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
