Question about Sharp Office Equipment & Supplies
The Sharp FOP610 often reports a "LINE ERROR" when attempting to transmit. It truncates the transmission and then prints out a page to tell me. Very annoying ! Whats a Line error ?
  • 82 Answers
SOURCE: SHARP UX B700 TRANSMISSION REPORT
Does your machine show anything on the confirmation report like fax number,duration, pages sent, etc. or is the image just not being printed. If you have properly programed machine to show image on the confirmation report. I don't see anything that will cause that except your origianls may not right side up/down.
Thanks,
Mikey
Posted on Apr 03, 2008
leroyal
  • 2120 Answers
SOURCE: Confirmation of Transmission of Fax for Panasonic UF-890 Machine
Function 74 set 12 set 2 set stop
Posted on Aug 30, 2008
SOURCE: Canon MP530 - Fax Not Working
the fax is in the memory - and I can't print it out. Please advise.
Posted on Sep 09, 2008
leroyal
  • 2120 Answers
SOURCE: Stop Transmission Verification Report on Brother 2820
It should be under the REPORTS section of the menus.
Step through the menus to turn off CONFIRMATION REPORTS.
Posted on Oct 01, 2008
  • 3422 Answers
SOURCE: My Sharp fax machine model
Unplug the fax machine from the power outlet and allow it to reset for 30min. Then plug it back in to the power outlet. If this does not solve the problem, thencheck if the phone line between the fax machine and the wall is 'OK'.
Let me know the result
Why does Xerox 7335 truncates output from Oracle PDF?
It may not be the printer and I did some research on Oracle and this seems to be a common issue.
I pulled this information off an Oracle knowledgebase it may not resolve your issue and there is more info on the following site if you want to investigate further:
http://docs.oracle.com/cd/E23943_01/bi.1111/b32121/pbr_uxprt009.htm#RSPUB75727
NOTE:
If you're printing to the Xerox MFD with a PS (postscript printer driver) you could try installing and printing using the Xerox PCL driver for your computers operating system. If you printing reports from a mainframe this may be an issue at the mainframe level in which case I would engage your companies IT department for assistance.
Any one of a number of possible causes may account for the truncation of fields.
  • Check the field and determine if it is allowed to expand.
    1. In Oracle Reports Builder, double-click the field in the Paper Design or Paper Layout view to display the Property Inspector.
    2. Find the Horizontal Elasticity property.
    3. If it is set to Fixed, you should change it to Variable or Expand.
    4. Run the report to the printer.
    5. If it still truncates, it could be that the field requires multiple lines.
    6. Return to the Property Inspector for the field and check its Vertical Elasticity.
    7. If it is set to Fixed, you should change it to Variable or Expand.
    8. Run the report to the printer again.
  • If the right most fields on the page are always the ones truncating, it could be an issue with the printable area of the printer. If you are using a PCL printer, then you will have to estimate the size of the printable area and resize your margins accordingly:
    1. Open the report in Oracle Reports Builder.
    2. Go to the Paper Layout view.
    3. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins.
    4. Click and drag the black line to the left approximately 0.5 inches.
    5. Save and run the report to the printer again.
    6. If necessary, repeat steps 4 and 5 to determine approximately where the printable area boundary is located and then ensure that your report body fits within that area.
  • If you are using a PostScript printer, you can get the printable area boundary to appear in the Paper Layout view as follows:
    2. Choose File > Page Setup.
    3. Verify that the margins are small and that the orientation is correct.
    4. Click OK. The Paper Layout view should now be able to read the boundary.
    5. Go to the Paper Layout view.
    6. Click the Margin tool on the top tool bar. A thick black line appears indicating where the body of your report ends and the margin begins. A black hashed line also appears indicating the boundary of the printable area.
    7. Ensure that the thick black line is inside of the black hashed line. If it is not, click and drag the black line inside the printable area.
    8. Click the Margin tool to leave margin mode.
    9. If necessary, reposition your fields to fit within the new body boundaries.
    10. Save and run the report to the printer.
  • For PCL, if it is still truncating, try using a fixed space font instead of a proportional font. Sometimes PCL printers have problems interpreting proportional space fonts and it leads to truncation. You should try using a fixed space font, such as Courier, and possibly font aliasing.
    Note:
    Default layouts are built against a generic printer. Each printer has its own printable area. As a result, you may have to reset the report to fit the printer. Ideally, if you know the various printers you will be using, you can design the report from the start to fit the printer with the smallest printable area.
Mar 10, 2015 | Xerox Office Equipment & Supplies
We keep receiving a T.30 Protocol Trace Report with the "Type: Receive" and "Result: Communication Error (17)". How do we figure out what this means? Thnaks.
If this is printing out and consuming a lot of paper it can get annoying. This report is intended for a technician to trace problems with your machine. The report basically tells you that your fax attempt failed and gives all the technical settings. To the average user this is meaningless. The print feature for this is normally turned off, but I have seen a few cases where the default was set to print. Under the diagnostics menu, find the T-30 error setting and set it to never. Check the firware on your printer to make sure it is current. Print the configuration page and check the firmware version on the front page. The current version is 48.181.8. There are many modem fixes included with the firmware.
May 23, 2011 | HP® LaserJet M5035 MFP Laser...
How do I get a fax transmission report to print from a Fuji Xerox C1190FS?
Printing Transmission Reports
To select a default option for printing fax transmission reports:
1. On the printer console, press the System button.
2. Select Admin Menu, and then press the OK button.
3. Select System Settings, and then press the OK button.
4. Select Fax Transmit, and then press the OK button.
5. Select one of the following options, and then press the OK button:
- Print Always: A transmission report is always printed.
- Print at Error: A transmission report is only printed when an error occurs with the fax
transmission.
- Not Print: A transmission report is never printed.
Note: The factory default is Print at Error.
Mar 05, 2011 | Office Equipment & Supplies
I HAVE A SHARP UX-A450 FAX MACHINE AND WANT TO EMPTY THE FAX MEMORY.
MEMORY IS FULL / SEE MANUAL (alternating messages)
The memory is full. You may have too many messages recorded in the answering machine. To erase messages, see below. This may occur during fax reception if too much data is received before the pages can be printed out. If faxes have been received to memory because printing is not possible (an additional message will indicate the problem), resolve the problem so that printing can continue (see Substitute Reception to Memory on page 66). If you are attempting to transmit from memory, see If the memory becomes full on page 57. If you are copying, see If MEMORY IS FULL appears on page 67.
Erasing received messages:
It is important to erase received messages after you listen to them to ensure
that the memory does not become full.
? Erasing all messages: To erase all messages, press FUNCTION, DELETE, and then START/MEMORY.
? Erasing a single message: To erase a single message, press DELETE while the message is being played.
If the memory becomes full while the document is being scanned, MEMORY
IS FULL and SEE MANUAL will alternately appear in the display.
? Press START / MEMORY if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder. After transmission, the memory will be cleared and you can transmit the remaining pages. You will also need to transmit the page which was being scanned when the memory filled up.
? Press STOP if you want to cancel the entire transmission.
Nov 25, 2010 | Sharp Office Equipment & Supplies
Sharp fax machine UX30 memory is full. How to empty fully?
If the memory becomes full while the document is being scanned, MEMORY IS FULL will appear in the display. This may occur during fax reception if too much data is received before the pages can be printed out.
  1. Press these keys: (function) 6 # #
  2. The display will show: RECEPTION RATIO
  3. Press 1 to turn automatic reduction on.
  4. Select the reception ratio to be used in the event that the memory becomes full (automatic reduction is not possible when the memory is full). Press 1 for 93% or 2 for 100%.
  5. Press the STOP key.
If you are attempting to transmit from memory:
  1. Press the START/MEMORY key if you want to transmit the pages which have been stored up to that point in memory. The remaining pages will be ejected from the feeder.
  2. After transmission, the memory will be cleared and you can transmit the remaining pages.
  3. You will also need to transmit the page which was being scanned when the memory filled up.
  4. Press the STOP key if you want to cancel the entire transmission.
Here is a copy of the User Manual for the Sharp UX30:
http://www.docshare.com/doc/227849/Sharp-UX30-User-Manual
Jun 30, 2010 | Computers & Internet
I'm getting an error mesage: ECM error on my Sharp AR-M207 fax machine. How can I fix it?
ECM (Error Correction Mode) is a feature common in most fax machines today. It helps to minimize errors while transmitting faxes over noisy phone lines.
1) Be sure you have the latest version of the drivers installed
2) Turn the fax off, then unplug for 10 minutes, turn on and try again. This should clear up anything in the printer/fax memory
3) Check if your phone line is unsually noisy when you tried to send the fax(es) that gave you the error message. If this is the case, a sucessful fax transmission will be almost impossible. You may have a faulty phone line or an improper installation. Either of these two should be fixed by your phone company. Also, most phoen companies can test your phone line (for fre) remotely to check for abnormally high noise levels.
Please, report back if you need further assistance.
My ID: alexocuello_
Mar 31, 2010 | Office Equipment & Supplies
My Sharp UX-355L Fax machine printed unwanted information
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following:
1 Press these keys:
FUNCTION
TRANSACTION LIST
2 Press a number from 1 to 5 to select
the condition for printing.
ALWAYS PRINT A report will be printed after each
transmission, reception, or error.
ERR/TIMER/MEM A report will be printed after an error,
timer operation, or memory operation.
SEND ONLY A report will be printed after each
transmission.
NEVER PRINT A report will never be printed.
ERROR ONLY A report will be printed only when an
error occurs.
To print from memory:
If the memory becomes full...
♦ Press the START/MEMORY key if you want to transmit the pages
♦ Press the STOP key if you want to cancel the entire transmission.
Hope this helps. : )
Mar 30, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
Hi how do I turn of tx and rx reports on faxcentre F110/
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
  • With: a report is printed when the fax transmission was successfully sent or when it is completely abandoned. There is only one report for each fax sent.
  • Without: no transmission report is automatically printed, however, the machine will save all fax transmissions that took place in memory. The faxes sent can be viewed by printing out a transmission log (report).
  • Always: a report is printed after each successful or interrupted transmission.
  • On Error: a report is printed only if the transmission failed or is abandoned.
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
  1. Press the [OK] button directly below the Display Screen. '1 Installation' and '2 Fax' will be displayed.
  2. Press [2], [5] on the numeric keypad. ‘25 >Send Report’ will be displayed.
  3. Press [OK]. The transmission report screen will be displayed.
  4. Press the up or down arrow button directly below the Display Screen to select a transmission report setting, then press [OK]. ‘25 Send Report’ will be displayed.
    NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
  5. Press the [Stop] button on the Control Panel. The 'Date / Time' screen will be displayed
Dec 11, 2008 | Xerox FaxCentre F110 Plain Paper Laser
Thanks,
Mikey
Mar 06, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
149 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
