Question about HP LaserJet 3330 All-In-One Printer
Problem with HP LaserJet 3330
It doesnt work. Gives message printer mispick.
  • dwilsonjones Dec 10, 2008
    Whenever I try to copy or print, "Printer mispick (ENTER) to resume" appears. I would like to clean the pick rollers with cotton w/alcohol, Where exactly is the pick rollers??? Where is the separation pad?
  • 66 Answers
try to clean the pick rollers with cotton w/ alcohol.if it doesn't work maybe your separation pad is worn out and need to replace it..
Posted on Oct 30, 2008
Printer mispick message
Your printer probably needs to have the paper pickup roller replaced.
You might try to clean the roller with a slightly damp lint free cloth.
Pull out the toner cartridge and look down you will see the roller sitting there.
Gently wipe it down, reinstall the toner and try printing again.
Mar 29, 2011 | HP LaserJet 3330 All-In-One Printer
"printer mispick enter to resume"is
replace pick up rollers and or the whole pick up assembly
Dec 25, 2010 | HP LaserJet 3330 All-In-One Printer
Message: Printer Mispick.[Enter] To Resume
Sounds like the pick up rollers are not pulling the paper in. Try cleaning them or replace if they look worn. When I try to examine all the parts you can find some small piece of paper caught in somewhere around.
Thank you!
May 18, 2010 | HP LaserJet 3330 All-In-One Printer
Problems with hp laserjet 3330
suspect either worn ADF(automatic document feeder) pickup roller or there is a jam in the ADF unit where the paper feeds to the scanner.
Mar 11, 2010 | HP LaserJet 3330 All-In-One Printer
Printer mispick
Hi ,
The print engine has failed to pick up a piece of media.There is a paper jam in the printer's paper path. Reload the paper in the paper input tray; verify that there are no jams in the paper path, and press MENU/ENTER to continue the job. If the error persists, replace the printer pickup roller. Check paper path, including rear output door for jams, fuser area, and under the print (toner) cartridge.
Feb 10, 2010 | HP LaserJet 3330 All-In-One Printer
Printer mispick and how to solve it? I tried to open the door to take paper out, but left a little piece there I believe since the paper was broken. Now, I can not print anything and can not find any piece...
Clearing a paper jam - (or leftover bits of paper)
The LJ 3380 may be shown in this tutorial from HP: (do not try any disassembly other than opening the product doors as suggested in this tutorial)
HP LaserJet 3330 Clear Paper Jams
If this info is helpful, please vote.
Dec 29, 2009 | HP LaserJet 3330 All-In-One Printer
Printer error as stated "Printer Mispick [Enter] to resume." There was a mispick but that was corrected; however the error message is constant.
Hi:
I own a HP Laserjet 3330, and usually all that it takes to fix this problem is cleaning off the paper pick up roller with a damp cloth.
It is having trouble picking up the paper sheets, and you will get the error time after time. It seems that the recycled paper is worse than others. Remember to use a cloth dampened with only water, as other cleaners will dry out the pick up roller
Oct 26, 2009 | HP LaserJet 3330 All-In-One Printer
Printer Mispick is displayed on my HP LaserJet 3330 mfp
It just means the paper wasn't fed and you should use a damp cloth and clean the paper feed roller, any other cleaner dries out the rubber on the roller.
Sep 01, 2009 | Office Equipment & Supplies
Our HP Laserjet 2840 gives document feeder malfunction. the On Screen msg reads document mispick.
Check the feeder, it is either loose or broken making the printer to think that you have in a different size or type of document.
Aug 18, 2009 | HP LaserJet 2840 Printer
Recurring error
This answer was almost exactly correct:
>hey guys, for the "printer mispick" problem, try to remove the >toner and look IF there's any paper jam inside,because this >solved my problem,..
>=open toner door
>=remove the toner
>=look carefully IF there's any paper stuck between roller
>=CAUTION - carefully and gently remove the paper if so, as it >will be a nightmare if half tear off and the half end will be more >difficult to remove,...
The only thing I did differently, that worked like a charm, was to =open the door on the other side of the machine, and
=swing down the two green levers (one on each side); this released the roller tension and removal of the paper was easy.
=Once the paper has been gently removed, put back up the two green levers, and
=close everything up, re-installing the toner cartridge as you do.
Nov 16, 2007 | HP LaserJet 3330 All-In-One Printer
HP LaserJet 3330 All-In-One Printer Logo
437 people viewed this question
Seeker5211
Seeker5211
