Question about HP ProMedia Computer Speakers
Klipsh Promedia 2.1
Hi,...Klipsh Promedia 2.1 Computer Speakers...No longer any sound.Had these 2-3 yrs and worked fine.Have operated them connected to my desktop.On/off switch in back of Sub is hard to reach so have them plugged into a power strip and turn them on off via power strip main switch daily.Now green light on control speaker does not light up.When I click the switch off/on directly at the back of Sub I can hear an internal relay clicking on but still no sound and no green light on control speaker.If wiggle Sub connector can get popping sound from both speakers.If put either speaker to my ear can hear soft hissing noise.Also cones on both speakers flex when power switched on.Picked up a complete new set of these.Connected the 2 NEW satelites to the OLD Sub... no sound... no green light.Connected the OLD satelites to the NEW Sub... got perfect sound.Looks like problem inside the OLD Sub.Please help me figure out how to fix it.I was afraid to open the Sub up because I have no electrical repair knowledge. Thanks
  • Anonymous May 17, 2008
    Satellite work, subwoofer doesn't.
I was face the same problem 2 year's ago.This problem occur when you move the speaker's here and there.at that time speaker's wire diconnected in inside...please check the whole wire by electricians for where exactly it is disconnected...
Posted on Aug 25, 2007
I still have a Dell Dimension 8400. The external hardware (big box, speakers, cords, etc...) no longer work....If I connect headphones into the computer, the sound is fine..But now I want to be able to...
Hi Bill. You can buy a small multimedia speaker package for very little money these days. A small subwoofer and a pair of speakers (called a 2.1 system) will give pretty reasonable sound if you are on a budget
Jan 26, 2014 | Dell Dimension 8400 PC Desktop
Lost sound in left channel?
I presume you are playing a stereo cd. Plug some other device, like headphones in to see if the computer is putting out stereo. Use the same plug as the speaker system is plugged into.
I presume you have swapped the speakers to test them.
If the speakers work, and the headphones work, it's the amp.
Nov 26, 2013 | Klipsch Promedia 2.1 Thx Computer Speaker...
Headphone jack on my compaq presariocq62 is not working
hi
maybe you have loss in jack connection otherwise check sound setting in volume bar right corner of desktop
Dec 04, 2012 | Compaq Presario 700 470024-192 Notebook
My altect lansing bxr1121 speakers stopped working suddenly. I have checked all the connection but the power led is off.
Hi. i think it is the internal connections or jacks need to be resoldered, but first try to check the continuity of each wires. tact switch cleaning and replacement is another approach.
Mar 07, 2011 | Altec Lansing BXR1121 2 Speakers
RCA jack in back of the speaker is no longer connected. I can NOT get the cover off the speaker.
cut connectors from board & join cable of speaker & output wires
raj@npconline.in
Jan 26, 2011 | Klipsch ProMedia GMX D51 5 Speakers
When speakers are connected to the computer, they produce a popping sound every second. However, when headphones are connected to the speakers the sound works fine.
these speakers are quite problematic aren't they!! From the information you have given there is either a problem with the mains trans former or the internal wiring. Neither of which are user serviceable.
Jan 07, 2011 | Bose Companion 2 Series II Multimedia...
My stero is not loud enough.
Check for the tape monitor being on or amp mute type function. Larry's Electronics
Apr 27, 2010 | Audio Players & Recorders
Dell Dimension 4700 PC Speaker No Sound
Check to make sure all cables are connected. After this you will need to click on your sound card properties and set it to 5.1. which will allow all the speakers to play.
Please note you will need to have a card that supports 5.1 sound I do not believe the stock card in the Dell supports this feature which could be the problem.
Feb 05, 2010 | Dell Dimension 4700 PC Desktop
Speakers not working
hi,
ok so your speakers are alright, but you dont hear any sound when connected to the computer.
1.this might be due to a driver problem. install the correct driver for your sound system and it will start working. to check if the driver are ok, right click on my computer icon on the desktop and select properties. now go to the hardware tab an and click device manager. a yellow mark will in the sound system category will tell of a device driver or conflict problem.
2. if there is no problem as mentioned above... you can try this go to control panel. click the sound icon and check i the device is muted and volume sliders are adjusted.
hope it helps.
regards.
bzoy
Jan 09, 2008 | Dell A525 Computer Speakers
HP ProMedia Computer Speakers Logo
6,746 people viewed this question
Top HP Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
rfredey
Are you a HP Audio Player and Recorder Expert? Answer questions, earn points and help others
