Question about Microsoft Windows XP Media Center Edition 2005 for PC
It's not reading to burn
I am sorry but i am just getting the half of ur issue ... all i understand the drive is not reading while burning .. but in normal scenarios does it read cd's or dvd's ?
anyways try this
go to device manager > uninstall the dvd/cd drives
delete ede/ata/atapi channels ... both primary and secondary delete the secondary first coz 90% the hard drive is connected in the primary channel and if u uninstall the primary first the system will hang and than restart the system and than try it out and if that doesnt work reply back... we will try some other things
Posted on Nov 01, 2008
Mar 07, 2016 | Televison & Video
On a CD-R, if you don't finalize or write protect the disk, can you overwrite a file?
Or in overwriting are you simply creating a second file of the same name in the TOC/directory and deleting the name, only, of the first file
You can add more data if there is space on the DVD+R, but you can't overwrite it.
You see, when a disc is burned, little microscopic ridges are put onto the disc. This is your data.
You cannot overwrite this data.
It's kind of like trying to use a permanent marker on the same spot of paper twice.
CD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a CD-ROM.
650 megabytes (MB)
Highly compatible with most computers and devices.
CD-R
You can burn files to a CD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
650 MB and 700 MB
You must close the session to read this disc in a different computer. Highly compatible with most computers and devices.
CD-RW
You can burn files to a CD-RW more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A CD-RW can be burned and erased many times.
650 MB
Compatible with many computers and devices.
DVD-ROM
Known as a read-only disc, usually used to store commercial programs and data. You can't add or delete information on a DVD-ROM.
4.7 gigabytes (GB)
DVD-R
You can burn files to a DVD-R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
DVD+R
You can burn files to a DVD+R more than once (each time is referred to as a session), but you can't delete files from the disc. Each burn is permanent.
4.7 GB
You must close the session to read this disc in a different computer. Compatible with many computers and devices.
DVD-RW
You can burn files to a DVD-RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RW can be burned and erased many times.
4.7 GB
You don't need to close the session to read this disc in another computer. Compatible with many computers and devices.
DVD+RW
You can burn files to a DVD+RW more than once (each time is referred to as a session). You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD+RW can be burned and erased many times.
4.7 GB
DVD-RAM
You can burn files to a DVD-RAM more than once. You can also delete unwanted files from the disc to reclaim space and add additional files. A DVD-RAM can be burned and erased many times.
2.6 GB
4.7 GB
5.2 GB
9.4 GB
DVD-RAM discs can generally only be used DVD-RAM drives and might not be readable by DVD players and other devices.
hope this helps
Aug 28, 2012 | Ahead Software Nero Express 6.0 (NERO6OEM)...
Feb 14, 2011 | Microsoft Windows 7 Ultimate for PC
Nov 23, 2009 | Apple Mac mini 2.0GHz
Oct 14, 2009 | Sony Toshiba Qosmio F45-AV411 Notebook
Oct 12, 2009 | BenQ DW1670 Double Layer 16 DVD RW IDE...
Jul 10, 2009 | Gateway (5502216) CD-RW/DVD-ROM (Combo)...
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Dec 10, 2007 | LaCie d2 DVD-RW Burner
Jul 03, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
79 people viewed this question
model # hp pavilion a1330n
