Bike has no spark
SOURCE: i have a 2004 ttr yamaha 225 dirt bike and theres no spark too p
check stator ac output 1st.check pulse coil next. find cdi box to try next.other possibles- ign coil, try unscrewing plug cap & trimming about 1/4" off coil wire. check spark w/ cap off. finally could be wiring.
SOURCE: how do youfind a serial number on a yamaha 125 dirt bike 2004
Should be stamped on the neck of your motorcycle or on the left hand side lower rail. Look on the neck, right side, under the dirt.
Where is the neck? It is the place where the front wheel assembly is fastened to the rest of the motorcycle.
Thanks for your interest in FixYa.com
SOURCE: Spark disapear on AG200cc Yamaha Farm Bike
If you've tested the ignition components and everything is good to go, the most likely candidate for causing intermitent fire is actually the spark plug cap.
First, just pull the cap off the plug and take a look inside to make sure the fitting is still clamping snuggly and squarely down on the plug. Now, holding the plug wire still, rotate the boot a full turn clockwise. Replace the boot and try it out. If this hasn't eliminated the issue, the little wires within the plug wire may be frayed and broken. To check this, pull the boot back off of the plug. Again, holding the plug wire still, rotate the boot COUNTERclockwise and unscrew it right off the end of the wire. Take a look in the end of the wire and check the condition of the little wires that should be in the center of the plug wire. If the don't look 100%, use some wirecutters and snip off about 1/4" of the plug wire. Replace the plug boot by insuring the screw tip of the boot enters exactly in the center. Give it a few turns clockwise-until it snugs up. Replace the boot onto the plug and you should be ready to go! I hope this helps! Good luck!
*Help me out. Rate me!
Testimonial: "Thanks for advise, will try it out."
SOURCE: yamaha zuma 08
i have a yamaha xj600 1990 model.. been running brilliant for ages but now all of a sudden its stopped runner theres no spark getting to the plugs, ive changed the coils and it still aint givin me any spark its as dead as a doe doe.. help me please some1..
SOURCE: Cant get spark from a TTR600 Yamaha bike.
I have tryd every thing on hear related to no spark is there any more soultions??
