Old sansui amp BA-FI turn it on an it blowes the 8 amp fuse instenly
Sansui amp BA-F1 bought in 1986 never hade a prublem ever terry
    Brigadier General:
  • 6,966 Answers
Hi again,
You might have need for the following information:
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 30, 2008
  • 4,234 Answers
The fact that this unit blows the main fuse immediately indicates a dead short in the power supply. With a unit of this vintage, I would check the main bridge rectifier or the rectifier diodes. If you have no experience with electronics repair, a repair estimate would be in order. Figure on $50 for an accurate estimate. If it turns out to be just the rectifiers, than expect a parts bill in the $20 range.
Dan
Why the fuse burn and the car turn off , I change the fuse and the car turn on again
It sounds like a dead short somewhere in the ignition circuit or the "main" circuit. If everything else on the car dies (lights, chimes, instrument panel, etc) when that fuse blows, that would most likely be the main fuse you've identified. It's going to be a serious pain to find that short, and I'm sorry I don't have any real leads as to what it could be other than tracing the wiring back. Whatever you do, DO NOT replace the fuse with one of higher amperage... The wiring will surely melt or even worse, catch fire!
May 05, 2016 | Suzuki XL7 Cars & Trucks
Why does my fuse blow out when i turn the amp on?
sounds like you have a dead short internally and unless you find and fix it will continue to blow fuses .
Aug 02, 2015 | SWR La15 Bass Combo Amplifier
IZE FUSES GO INTO A BALLY STRIKES AND SPARES PINBALL MACHINE
There are several fuses. All are 3AG size. On the Rectifier board you need:
F1=10 Amp 32V
F2=3/4 AMP, 250V SLO-BLOW
F3=4 Amp, 32V
F4=5 Amp, 32V
F5=20 Amp, 32V
F6=3 Amp, 32V SLO-BLOW
On the solenoid driver board you need:
F1=3/16 Amp
Nov 01, 2014 | Video Game Consoles & Games
All the lights are not working found 2 blown fuses / replaced still not working the power lite flashes red then turns to green
When a fuse blow suspect an overload. In an amp this old it will certainly be one (or more) of the main output transistors that has shorted.
Sep 25, 2013 | Sansui 1976 9090 Receiver Amp Vintage
What fuse controls heater panel
there is many fuses that work different parts of the heater controls, in the battery fuse box (under the hood) fuses (f1-8 30 amp)( f1-9 20 amp )(f1-15 10 amp)(f1-64 40amp) and in the central junction box (inside the car) fuses (f2-36 7.5 amp) and fuse (f2-45 7.5 amp) all these fuses control functions of the heater control hope this helps you out . please leave feedback
Dec 29, 2010 | 2003 Ford Focus
Rockford Fosgate Punch P325.1 Amp keeps blowing fuses every time I start the car. What is going on?
well if the amp works with the car off and when you start it the fuse blows then you may have alternator issues use a volt meter to check battery voltage is not above 14.5 volts
if the fuse blows when the amp turns on then most likely you have a shorted output section in the amp.
Mar 18, 2010 | Rockford Fosgate Punch P325.1 Subwoofer...
Need a fuse for Sansui stereo amp I purchased at a yard sale. Radio shack cares the fuse but doesn't know exactly which one.
Difficult question. Which Sansui amp? You could start small, say 2A, increase by 1's till it doesn't blow or if that is too expensive, 2, 5, 8, 10, 12, 15, get the idea? Just don't start big and expect it to work properly, the fuse that is, it is supposed to blow, not "let the magic smoke out".
Sep 03, 2009 | Audio Players & Recorders
Blows fuse when turned on
this is a normal behavior if one of the power supply transistors have blown. take the unit to an enlectronics repair. they can either change the transistors affected (usually more than one) or replace the power supply board.
May 29, 2009 | Sansui DTV3200 32" TV
86 toyota pickup fuse box diagram
When I use my turn signal in my 1986 toyota pickup every 5-6 uses it blows the fuse and my blinkers, backup lights, gas gauge and temp gauge stop working. What is going on
Jan 07, 2009 | 1986 Toyota Pickup 4WD
Need help with my Kicker Amp
Some amplifiers don't work well if the signal source has no connection to chassis ground, This could have caused instability in the amplifier and caused it to fail.
It's also possible that the amplifier had a manufacturing defect.
Aug 12, 2008 | Kicker ZX350.2 110W x 2 Car Amplifier Car...
399 people viewed this question
 Grubhead
Grubhead
