Question about Toshiba MV13P2 13 in. TV/VCR Combo
PICTURE JUMPING THE CABLE IS CONECTED BUT THE PICTURE IS ZIG ZAGING THEREIS NO VCR TAPE IN THE VCR TV WILL CHANGE CHANLES
When my VCR records programs and I play them back, I find that it's jumping and when I adjust the tracking it works for a little bit and starts all over again..I cleaned it with the special cassette cleaner and solution that comes with it but still stays a problem. I am deaf so I need to read the captions which come and go...I hope it's a simple thing to fix..
Posted on Nov 03, 2008
    Sergeant:
  • 291 Answers
Check ALL filter capacitors, /when u find it, change also the filter resistor
Posted on Jun 25, 2008
How to make straight on singer 20u33 machine it just zig zaging
Owners manual are usually quite clear.
no manual? try http://www.manualslib.com/
Mar 08, 2015 | Singer Sewing Machines
Have a video cassette recorder & dvd/cd player. Need instrucdtions on hooking it up correctly
power off all items... do you have cable/satellite (this cable wire needs to be connected from box to the in on VCR) from the out on VCR connect back to TV...okay DVD you should have 3 cable wires (red/white and yellow) this is to be plugged into AV1 (on the back or side of TV) follow the colors... red to red and so on...note you should tune your Flat panel CH 3 along with the VCR (set it CH 3)... okay turn on all, get a tape, pop it in VCR press play... do we have a picture and sound? okay press stop.. get a DVD disk place it into DVD player press play.. using your TV remote we need to change the source from component/cable to AV1 in order to view a DVD. and change it back once finish so you can view regular TV. okay do we have picture and sound?
have fun enjoy your movie
Aug 09, 2011 | Televison & Video
Static jumping picture
sounds like bad connection or bad tuner in the tv - have you tried playing a DVD or VCR tape ( if available ) - more info would be needed to help you further -such as - are you on cable, cable box, satelite or antenna and do you hook up to your TV using the a/v or RF(cable) input.
Oct 18, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Jail bars in picture on analog cable tv only
this kind of intermittent noise has to be researched in the bench specially because the lines are there and then go out. it can be any component false contact, or solder joins.
Apr 15, 2009 | RCA B27TF680 27 in. TV/VCR/DVD Combo
Troubleshooting vcr
Usually one connects a RF [cable tv, Dish tv, antenna ] cable to the INPUT of VCR & a RF cable output to tv (antenna )INPUT .The reason is that if you are watching TV reception (Cable, Dish, etc) and you want to watch VCR tape, just push the tape in and it should start playing picture.
From what I understand that you are trying to say:: [ YOUR NEW TV ! ] you MUST connect to the RCA jacks, CABLE S with RCA plugs that come out of the VCR to the new TV [ INPUT & OUTPUT] jacks .When you ["" use input botton on VCR remote"" ] you are using a DIFFERENT input signal. You are not letting the TV know that you are changing the signal from RF(antenna, Cable, Dish,etc)to the RCA signal ["" I use my input botton on my vcr remote""]
Aug 14, 2008 | Televison & Video
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
Connections
Without the manual !!
1)VCR INPUT:: [Cable_antenna In] the coxial screws on from "output" of cable box or ( airwave )antenna.
2) VCR output:: connect another coxial into input of TV. You should be able to keep all the other wires connected from SONY theater system.
note:: your VCR has a switch for VCR\TV. When u have a VHS tape playing a movie & switch from VCR to TV, you will see the channel that is on the VCR not the cable box\ antenna input.
example:Cable channel is on Ch.122, & your TV must be set to Ch.3 to view cable.If your VCR is set to Ch/5 you may not see that Ch.122.You will still be able to see your VHS tape when u place the VCR\TV switch back to VCR.
I am going to share wt.u a $100,000,000.00 trick:put any ch.on cable box.Switch VCR\TV to TV,change channel ON VHS tuner.When u come to the [picture] that the cable box is on,Then that is the Ch.u can see cable ON the VHS.
U owe me!!
Jun 08, 2008 | LG 42LC2D 42 in. LCD HDTV
Recording from camera to VCR
1st setup ur VCD with TV and playback it to view on TV. If picture is coming, thats OK.
2nd plug ur camcorder in VCR input and select VCR input according to plug in and monitor the camcorder picture on TV through VCR. If its ok, now u r ready to record the picture from camcorder to VCR.
Jun 07, 2008 | Sony Handycam CCD-TRV308 Camcorder
NO picture showing on screen even though the VCR is running and hooked up properly
u have to run it directto tv yellow cable ok and sound cables not throw dsh tv
Feb 03, 2008 | Quasar VHQ400 VHS VCR
JVC HR-S3901 S-VHS / Switching from TV to VCR no longer works . . .
Ifyou do not see the VCR/TV button switch on the front panel, then its a problem most likly with the firmware in the microprocessor. If you do see the VCR/TV indicator switching in or on the front panel display, most likly a defective RF modulator/switcher or RF antenna pack. You may still be able to get one from like MCM or tritronics or PTS corp can rebuild it for you. I have seen this type of break down many times with VCR's as we used to do hundreds of VCR repairs a day as we did factory service for several companies in the NY/NJ area. Good Luck Please do not forget to rate this thread.
Dec 10, 2006 | JVC HR-S3901 S-VHS VCR
Toshiba MV13P2 13 in. TV/VCR Combo Logo
146 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
