Issue:NTOSKRNL.EXE is missing or corrupt.
Related errors:
Below is a listing of the full error message that may be related to this error.
Windows NT could not start because the below file is missing or corrupt:
C:\Winnt\System32\Ntoskrnl.exe
Cause:
- Keyboard issue
- Miscellaneous corruption
- Corrupt boot.ini file.
- Missing boot.ini file.
- Missing or corrupt ntoskrnl.exe file.
- Windows NT installed on a partition bigger then 7.8GB
- Corrupted hard disk drive or severely corrupted Windows.
Solution:Keyboard issue
This
issue has also been known to be caused by a short in the ground wire in
the keyboard cable. Make sure this is not the cause of your error by
replacing the
keyboard with a different keyboard or simply just disconnecting the keyboard from the computer.
Before
trying any of the below recommendations it's recommend that you attempt
to load the last known good configuration. Additional information about
doing this can be found on
document CH000626.
This
issue is often caused when the boot.ini is missing or improperly
configured. This issue often arises after a user has recently added or
removed an operating system on the computer or added or removed hard
disk drives in the computer.
Make sure the
line pointing to the operating system and its drive and partition is
properly configured in the [boot loader] and [operating systems]
section. Additional information about boot.ini can be found on
document CH000492.
Microsoft Windows XP users:
If
the boot.ini is severely corrupted or missing a user running Microsoft
Windows XP can rebuild the boot.ini to resolve this issue. Additional
information about rebuilding the boot.ini can be found on
document CH000648.
Microsoft Windows NT and Windows 2000 users:
To restore the original boot.ini file in Microsoft Windows NT or Windows 2000 you will need an
ERD and follow the below steps. If you do not have an ERD you will be unable to follow these steps.
- Boot the computer with your Windows NT three setup diskettes or the Windows 2000 setup disc.
- In the setup menu, type R to start the repair.
- When prompted for the ERD diskette insert the diskette and inspect the startup environment.
If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps.
- Insert the Microsoft Windows XP CD.
Note: If you have a recovery CD or a restore CD and not a Microsoft
Windows XP CD it is likely the below steps will not resolve your issue.
- Reboot
the computer, as the computer is starting you should see a message to
press any key to boot from the CD. When you see this message press any key.
- In the Microsoft Windows XP setup menu press the R key to enter the recovery console.
- Select the operating system you wish to fix, and then enter the administrator password.
- Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32
- You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file.
- Type exit to reboot the computer.
If
you are running Microsoft windows NT 4.0 on a partition larger than
7.8GB this issue can occur if the boot files are located outside this
limitation. When this error occurs your computer will have the error
message as shown below.
OS Loader v4.01
Disk I/O error status=00000001
Windows NT could not start because the below file is missing or corrupt: winnt\system32\Ntoskrnl.exe
Please reinstall a copy of the above file.
If
your system partition is larger than 7.8GB you will need to delete the
partition and recreate the partition to 7.8GB or less. Additional
information about this issue can be found on
Microsoft KB Q224526.
Attempt to check the
hard disk drive for any errors by running the
chkdsk program. To do this follow the below steps.
- Reboot
- Once at the recovery console type chkdsk /r
- Once completed type exit and see if issue is resolved.
If
after trying all of the above steps you are still encountering the same
issue it's likely that Windows is severely corrupted and it is
recommended you attempt to reinstall Windows. Additional information
about erasing the computer and starting over can be found on
document CH000186.
Finally, if during the Windows installation you encounter errors it's likely that your hard disk drive is bad.
Have you tried to repair your existing Windows installation?It seems that the OS installation on the hard drive is corrupted so it can't boot properly.
I have tried the repair option from the disk i 'am currently booting from.It asks for the repair console disk;which i dont have.I fixed the problem with a older hard drive (80 gb) with windows xp professional. It's fine now and the sound is on also;I removed my sound card and it stop having a problem.
Thanks for good advice!
manintensemuscles
