Question about HP Computers & Internet
LAPTOP WANTS TO BOOT BUT STOPS
WHEN BOOTING IT OPENS TO SHOW WINDOWS XP LOGO AND THE STAYS BLACK
    Brigadier General:
  • 6,966 Answers
Could be a number of possibilities:
  • video card;
  • driver(s);
  • virus/malware;
  • corrupted OS files;
  • defective sectors in HD.
Initially, pls try booting into "Safe Mode".
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 30, 2008
How do I get my windows 7 laptop to boot up
Need some more info from you.
Is it booting to windows? Can you see the windows logo? Is there anything on the screen at all? Please let us know what the last thing you see on your screen is before it stops working.
Aug 10, 2014 | Microsoft Windows 7 Ultimate for PC
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
My sony vaio pcv rs720g stays in windows xp logo when booting ....what do I do to fix this.......recovery disk is not helping...
AS YOU START THE SYS. JUST KEEP PRESSING THE F8 BUTTON EVEN BEFORE THE XP LOGO COMES. AND YOU GET A MENU THERE. SELECT SAFE MODE AND PRESS ENTER. IT WILL BOOT IN SAFE MODE. THEN RESTART. SHOULD BE FINE ELSE PLS REPLY WITH THE ERROR STATUS
May 13, 2011 | Sony VAIO PCV-RS720G (027242658103) PC...
Starting problem
Immediately after seeing the Dell logo, keep tapping the 'F8' key,
until you see a "menu" (white text over a black background)
giving "startup" options for Windows XP.
Select "Safe Mode" and see if you can start in that mode.
Then, use "System Restore" to go "back" in time, to the most-recent checkpoint (date/time) where your computer _DID_ work.
Restore to that point, and restart.
Jul 17, 2010 | Dell Inspiron 1525 Notebook
Wont boot into windows xp....
If you have the setup disk, boot the laptop with the system disk and when you are asked select repair.
The system either was attacked by Malware or became corrupted.
Jun 14, 2010 | Compaq MS Windows XP Home Edition for PC
Booting up problem on gateway laptop
If you have a Windows XP/Vista/Vista64/7 Disc, have your Laptop boot from it, This will require a re instillation of Windows, but will fix your laptop right up, and if you don't have one, they are cheaper than laptops and will save you money. Plus, they can be reused on the same computer.
Nov 24, 2009 | HP Compaq Presario CQ60Z Notebook
Laptop starts to boot then screen goes black
when the windows are going in the booting and it is colored black, the problem can be wrong with the windows or set the mode dual setting LCD 1st graphic assign it, try to use external LCD Monitor or connect to back of laptop
Dec 14, 2008 | Acer Aspire 3680 Laptop
The laptop doesn't boot up always.
I would try the following:
1. Remove the battery completely. If the computer boots properly several times in a row, then the battery may be causing the power supply to do strange things.
2. If you have experience removing laptop components, try removing the hard drive. Because you say the screen goes black (I assume the system powers off) sometimes after the HP logo, I doubt its Windows or a software issue.
3. If HP has a diagnostic CD you can boot to, try that.
4. It may be the power supply acting up. If it charges the battery, and if you can boot to Windows with the battery, try getting a new power supply.
5. Otherwise, it may be the motherboard of the laptop.
Nov 28, 2008 | Computers & Internet
Can't boot up laptop
If your Usb port works, then the mobo is working, so possible graphics problem. Try booting up in safe mode(normally pressing F8) on boot up then highlight 'start windows in safe mode', to see if Windows will load with only minimal drivers, if so restart again, pressing F8 again, but this time highlight 'start windows with last known good configuration' Doing any of these 2 things can be done in any order, either last known good config first or safe mode.
Oct 21, 2006 | Compaq Presario 2140US Notebook
Computers & Internet Logo
43 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
