Question about Maytag 24 in. MDB4000 Built-in Dishwasher
Clogged The upper spray arm is clogged. How do I get it out to clean it?
    President:
  • 878 Answers
Richard, There should be a spin nut just above the spray arm that attaches to the spray arm hose. Unscrew this and it should come off. Catriver...post back.
Posted on Sep 10, 2006
2 Suggested Answers
huuum
  • 750 Answers
SOURCE: lower spray arm needs to be cleaned out.How do i take 0ff?
jocRDFAN43,
They do make a dishwasher cleaner that you can buy for about 5.00 and it cleans your dishwasher and also helps get rid of stains too!
This may solve you sprayer problem easier!
try it first with no dishes in the machine
bless you
huuum
please give me a good rating before you sign off
Posted on Sep 12, 2008
Dishes on top shelf not getting clean
Check your upper wash arm.... check the holes, especially the ones at the end of the arm. Are they possibly clogged with debris or hard water? This is the usual cause of dishes on the top rack not getting clean. The holes at the end of the wash arm are angled to eject the water at an angle to use the reaction to push the wash arm around. If those holes are clogged, then the arm won't rotate, and only those few dishes or glasses right under the arm will get clean, and the remaining 80% of the dishes on the upper rack won't get clean!
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Sep 13, 2014 | GE Dishwashers
Dishes on top shelf do not get clean.
Your sprayer arms may be clogged.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 13, 2011 | KitchenAid Dishwashers
Top shelf glasses are all foggy and not getting cleaned-mdb-5000AWW
Jun 13, 2011 | Maytag MDB5100 Dishwasher
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Middle spray arm clogged
no it cant to clean a dishwasher good the best thing you can do is run lemeshine often found at a publix or wallmart in the dishwasher detergant isles . if you try to sepperate the arms ther is a very good chance you will break the water tight seal and it cannot be fixed without replacement.
Jun 02, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
The top rack is not cleaning. When I've run a test, it seems like the top "arm" is not turning or spraying water.
Check the spray arm opening/holes for clogging with debris. If clogged, remove the debris from the holes. Then position the spray arm in a certain position and operate the dishwasher for a minute and stop and check the position of the spray arm. If in the same position, then the arm may not be receiving water from the water pump and/or upper water inlet housing/tubing. Contact an appliance service company.
Feb 25, 2010 | Kenmore Dishwashers
Spray arms clogged
Top: Remove the upper tray by releasing the clips on the ends of the runners. (Squeeze the top of the clip and pull upwards). Remove the spray arm by holding the round plastic clip that holds the arm and turning the arm. It will unscrew.
Bottom: Grab spray arm in centre and pull sharply upwards to unclip.
Wash in warm water and solvent-free detergent.
Jun 11, 2009 | Samsung Dishwashers
Bosch dishwasher - top row of dishes do not get clean
There is a screen that you can remove from the sump of the dishwasher to clean. Just twist it to the left and pull it out. I have some tips that you might want to check out if this does not resolve your problem.
<a href="http://tclaundryrepair.com/">St Paul Appliance Repair</a>
Feb 25, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
How to remove upper spray arm of Maytag DWU 9200 BBE dishwasher
There is a plastic clip that holds the spray arm to the inlet line. This clip is in the center and has to be sqeazed together to release the arm.
Both upper and lower spray arms become clogged by different objects like paper, plastic, stems from fruits, etc... These are particles that cannot br dissolved be the detergents.
Jan 10, 2008 | Dishwashers
Dishwashers Logo
254 people viewed this question
Top Maytag Dishwashers Experts
Carmen Mikulic
Mike
Marvin
Marvin
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
