Question about HP Office Equipment & Supplies
Trying to connect my laptop to the printer. The printer is currently connected to my desktop and i want to share.
    Genius:
  • 1,447 Answers
HI-
You can load the printer driver to your laptop, but make sure you configure the printer to the networkl printer port. make sure both computer have the same domain name as well and you can access files vice versa from laptop to desktop.
Hope this helps
Posted on Oct 30, 2008
EFI/Mircrosoft/Boot/BCD
It's not clear what exactly you mean. Generally, you don't connect two computers together using a USB cord. You can use a "cross-over ethernet cable" to connect the network jack of one computer to another computer. This allows transferring files and/or sharing an internet connection. If you have a wireless router you can enable Windows "File and Printer Sharing" on each computer and transfer files that way. Please provide more details of what you're trying to accomplish by connecting the computers together with a USB cable, and we may be able to give you a more specific answer.
Jul 30, 2014 | E-Machines eMachines Desktop PC
Im trying to set up wired computer desktop to share my new s605 to my sons laptop wireless...do i need to use the CD enclosed with the printer and put it in my sons laptop to install the printer on his...
Yes you need to setup the printer as a shared printer using the printer driver CD.
Your shared printer and computer would need to be on your LAN and connected to a wireless router. The laptop will connect to the shares printer via the wireless router and LAN cable to the computer with the shared printer.
Please click on this link and follow my instructions to setup the shared printer.
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Jun 03, 2011 | Lexmark Interact S605 All-in-One Color...
Trying to share a HP Photosmart 7150 that is connected to an workstation with XP. The laptop has vista
If u have a router connect the printer to the router and it will be detected after installing the drivers on the sys.
If the printer is connected to the desktop pc than u need to share it with the laptop if the networking has been done or go aheaad and setup the network and than share the printer it would work fine
Feb 06, 2010 | HP PhotoSmart 7150 InkJet Printer
Just bought win 7 laptops wont connect to my lexmark x1180 printer connected to my desktop running xp any ideas?
Enable File and Print Sharing on your XP system.
Click Start
Click Control Panel
Click Printers
Enable "sharing' for the printer.
Click Start
Right-mouse click My Computer
Click Properties
Click Computer Name
to show the current "workgroup" name on your XP system.
On the Windows 7 system:
Configure it into the same workgroup.
Then, "Add Network Printer", connecting to your XP system, and pointing at the shared printer.
Dec 10, 2009 | Lexmark X1150 All-In-One InkJet Printer
Laptop wont print to remote printer
just bound your both computers in valid ip range and attach your printer with you desk. or lap. & just share it.
Mar 15, 2009 | HP Pavilion dv6000z Notebook
Hp Vista Laptop won't communicate with XP desktop when trying Prt
u have share your printer and add your printer in laptop u have to connect both pc in lan (local area connection ) or u can use the cross cable of lan when both pc connected then u have share your printer in xp then u have to add the printer in your vista laptop by using printer add visrd there is option on it u have to select the network printer & add it in to vista then u can print it
or
there is onther way u can install your printer in a laptop u need ur printer vista download
Jan 17, 2009 | Office Equipment & Supplies
I am trying to set a network using a wired desktop and a wireless laptop (desktop using XP and laptop using Vista)I am using a Linksys WRT160N, I can get on the internet with no issues at all but when...
in the router's lan (not wan) configuration - set the dhcp server (gateway address) to be 10.1.10.1. Then set the addresses of the clients (connected to the router) to be assigned addresses from 10.1.10.10 - 10.1.10.20. Set the desktop's TCP/IP address to be 10.1.10.11 (static) with a subnet of 255.255.255.0, and a gateway address of 10.1.10.1. Set the laptop's wireless connection (TCP/IP adapter) to have a static 10.1.10.12 address with same subnet mask and gateway address of desktop. Change the workgroup on both computers to be of the same name (case sensitive here) to a name such as HOMENETWORK. Then on each computer, open up "My Computer" and right click on folders, files or printers that you want to share on your network!
Sep 26, 2008 | Computers & Internet
Trying to connect share printer w/Vista
If you connect the printer to the desktop computer and enable file and printer sharing on that computer. You will then need to go into printers and faxes and share your printer. Then go to the laptop and browse the network so you are looking at the desktop computer. You should see a folder that says printers. Open the printers folder and you should see the printer you just shared. Double click on it to install the shared printer on your laptop.
Now when you print from the laptop, you will print to the shared printer that you just installed (you may have to select it from the printer list). That will send the print job through the network to the desktop and the desktop will send it to the printer (the desktop will need to be turned on for you to be able to print).
If you don't want to have to leave your destop turned on just so you can print, you should look at a print server for your printer. That will connect the printer straight to the network. Then both computers will print to the printer over the network.
May 28, 2008 | Linksys 4-Port CPU Switch 843734000836
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
37 people viewed this question
Ben Johnson
