Question about Compaq Presario 700 470024-192 Notebook
Ftp doing steps please
How do I upload/download data using ftp command.
I am new to computer. I want to upload and download using ftp. Please tell me simple steps to do it and how many commands are there roughly?
Do you really need to be using command-line? Here are the things you need to do this as simple as possible:
Information Needed:
Host address: (example: ftp.somesite.com)
username: (if not anonymous)
password: (if not anonymous)
Software Needed:
FTP CLIENT: download here
After you have it installed, follow the documentation in the help menu to connect to the server and transfer your file(s).
Posted on Oct 30, 2008
How to Share Files With Cerberus Ftp Server?
FTP and SSH SFTP are application protocols designed to allow
individuals and businesses to easily transfer files between
computers. The two protocols are commonly used to transfer
data reliably and efficiently, whether it is uploading important
files to your home backup system or securely sharing company
files between two remote offices.
Setting up an FTP server will allow you to receive and share files
with virtually anyone, anywhere in the world. This tutorial will
walk you through the basic steps of downloading, installing, and
configuring Cerberus FTP Server . In addition to standard FTP and
HTTP, Cerberus can also secure your connections with encrypted
SFTP , FTPS, or HTTPS .
You can also use this link to download it How to Setup File Server with Cerberus FTP Server
Oct 19, 2016 | Computers & Internet
Tip
After Updating or Installing Wordpress 2.8, Plugins won't Install
Steps to Correct Plugin Upload Problem in Wordpress 2.8
Follow the steps below to fix the problem with not being able to install plugins.
1) Download the following file to your desktop. Just right-click on the link below and choose Save As to save to your desktop
New Version of http.php for Wordpress 2.8
2) Once the file has been saved, open your FTP program and log into your site
3) Transfer the file http.php into your WP-Includes subdirectory in Wordpress. I used a free ftp program called FTP Commander to transfer the file into the wp-includes subdirectory. Then I closed the FTP program
4) Now log back into your Wordpress Control Panel and try to install a new plugin. This simple fix worked for me.
NOTE: Not all Wordpress 2.8 installations are experiencing this problem, however for the ones that do have an issue, this fix worked and the ability to download and install plugins was restored.
on Jun 25, 2010 | Computers & Internet
Corrupt rar/winrar Archive
Maybe is uploading to the FTP site using ascii transfer type, once on the FTP connections, you should use binary type.
that is done with the command bin:
The following FTP Command will set the file transfer mode to BINARY (the binary mode transfers all eight bits per byte and must be used to transfer non-ASCII files). ) and display the information.
ftp> binary 200 Type set to I. ftp
May 06, 2015 | RARLAB WinRAR
How to upload ready configuration file into the new switch?
yes you can upload configuration file on S5300 switch flash using serial connection. Please check below link. is an upgrade guide for deploying a system software. it shows you how to upload system software to the flash, the process is the same for configuration file.
it is possible to connect a laptop to the switch? Ethernet cable, configure ip addresses, enable ftp, configure ftp user and then upload to file to the switch via ethernet?
Apr 10, 2015 | Huawei Computers & Internet
FTP CLIENT
The following is a generic outline for using FTP clients since I'm not sure which specific FTP client you want to use. Where an example is needed, I'll illustrate using the ftp command in Terminal.
First, open a connection to the remote computer. This is usually done using the remote computer's IP address, e. g.,
ftp 192.168.1.2
You may be prompted for your user account name and password on the remote computer. If you are using a command-line client such as that found in Terminal, you can consolidate the login with a URL:
ftp://accountname:password@192.168.1.2@[portnumber]/Users/accountname/Documents
Once you are logged in, you can view directory contents (pls or dir), delete (rm or rmdir), upload (mput), or download (get) files. Be sure to log off or otherwise close the connection when you are done (bye).
There is not enough space here for a comprehensive description of all of the features of a typical FTP client. Many have graphic user interfaces with selector menus, file tree display and possibly even click and drag file manipulation resembling the Finder. For more details on the Terminal's ftp client, open Applications/Utilities/Terminal and type "man ftp" (without the quotes).
Jun 15, 2013 | Computers & Internet
Joomla
Hi, Here you will find a list of the most popular Joomla extensions, a short description of what they do, a download link plus how to install instructions. Currently, most of Joomla addons are compatible with Mambo CMS, so, you can use them on your Mambo site as well. Please remember:
arrow1.gif When installing add-ons make sure you download them from known sources;
arrow1.gif Always make backups of your Joomla site before you start installing addons. Always!
This tutorial is designed to teach you how to create a backup of your Joomla website.
To make a backup of your Joomla application you need to download all your Joomla files to your local computer and to export the database that Joomla uses.
How to download your Joomla files? To back up the Joomla files to your computer please, use an FTP client to connect to your account. Then navigate to your Joomla application folder and download it to your local computer. Here you can learn more about how to configure and use an FTP client.
May 15, 2010 | Computers & Internet
Upload my web pages
Dear friend you can check any web address in www.whois.net
goto this website and check your address in part: "Domain LookUp"
I checked that before and this address (online-education.com) is not available, it means that someone else toke it before you.But I suggest you check it by the address above, because it will suggest you other available webaddress like onlineeducation.net (it's really available now, and you can get it!)
For publishing there are many ways to do that. You can do it by Dreamweaver or Frontpage softwares.Or you can do it by some FTP softwares like Smart FTP, Core FTP, FTP explorer, Turbo FTP and ... . Download one of them and publish your web pages.
But the simples way is to use your browser (IE, FireFox)
Note: Each domain maybe has a folder named "www" or "root" if you see this folder it means that you have to publish your web pages in this folder.DON'T delete this folder!
Anyway, maybe you didn't get how to publish your web pages, this is my mail address: hussein@fardinfard.com and this is my Yahoo ID: l_finalcut_l
Please send me mail or leave a message in yahoo messanger I'll help you step by step.Don't worry!
At your service
Good luck
Apr 15, 2009 | Microsoft Windows XP Professional
Problem downloading files up to 100 mb
Well, here's a bit complicated, yet effective method that just might reduce your downloading headaches... Let's say you're connect to the Internet using a 28.8K modem and that your Internet service provider lets you telnet to their server. Of course, your provider's server can download files much faster, so the idea here is to download the file to their server at high speed, split it, and retrieve parts at the highest speed you can to your provider's server. Generally speaking, this method not only is a faster way to download files, but it is also a more reliable method since you'll be downloading many smaller files rather than one large file.
First, find out the FTP address of the large (larger than 16M for example) file that you want to download. For example:
ftp://ftp.x.com/bigfile.zip
Telnet to your Internet service provider's server.
telnet x.com
From within the telnet session, download your file to your provider's server. Following is a "screen shout" of a sample file transfer on an UNIX compatible server. Blue/bold text represents your input.
ftp
ftp> open ftp.x.com
Connected to ftp.x.com.
220 ftp x.cpm FTP Service (Version 2.0).
User (ftp.x.com:(none)): anonymous
331 Anonymous access allowed, send identity as
Password: my_address@x.com
ftp> binary
200 Type set to I.
ftp> get bigfile.zip
200 PORT command successful.
150 Opening BINARY mode data connection for bigfile.zip
226 Transfer complete.
ftp> quit
221 Thank you for using x.com! Once the file is download to the server, the next step is to divide the file into smaller pieces so that you will not waste too much time downloading should your Internet dial-up connection go down.
split -b 2000b bigfile.zip
You're almost there! Now simply log off from your telnet session and start downloading (from your provider's server to your computer) smaller files (not the bigfile.zip) which the above split command (on most UNIX compatible machines) created.
Once you have all the files, simply merge them and you got a good copy of the original bigfile.zip. If you're using DOS or Windows, you can merge files using the following command (assuming that bigfile.zip (16000 byte file) was divided into 8 2000 byte files named xaa to xah):
copy /b xaa xab xac xad xae xaf xag xah bigfile.zip
Don't forget to log back into your Internet service provider's computers and delete temporary files (bigfile.zip and xaa..xah) once you've made sure that your downloaded copy is in good condition. Doesn't sound like the above steps could make your downloads faster or more reliable? Well, in most cases it does; specially if the file you're downloading is rather large. The reason why this method could possibly be faster is because you can download files from your provider's computer to your computer faster than from most remote sites. Of course, the reason for reliability is that downloading many smaller files makes it possible to resume a download without wasting as much time as resuming a larger file download would.
************ALTERNATIVELY***********
You can use FRESH DOWNLOAD.Fresh Download is an easy-to-use and very fast download manager software that turbo charges downloading files from the Internet, such as your favorite freeware/shareware, mp3 files, movie files, picture collections, etc. Unlike any other similar utilities, this software is 100% free, no charges, no banners in the software (whichsteal your bandwidth), no spyware.
Apr 13, 2009 | Arris Touchstone 450a (CM450) Modem
FineDrive 400 Map Data
its impossible to email or post online due to the size of a couple of the files. I created a new dvd with instructions and automatically loading firmware update and are selling these on ebay for basically the cost of labor and materials, fine digital used to get $150 for an upgrade dvd... if you search ebay for finedrive dvd you should see it.
Sep 23, 2008 | GPS
3Com 3824
Download free version of HyperTerminal for Vista : ftp://ftp.hilgraeve.com/htpe/htpe63.exe
Make a new connection :
connect using COM1 (depends of your configuration)
19 200 bits/sec
8 data bits
No parity
1 stop bit
No control of flux
And push enter twice to display a "Login:" prompt.
Connect using default user/passwords : http://support.3com.com/infodeli/tools/switches/ss3/management/ug/setup.htm#13131
Regards,
AstroMan
Jan 14, 2008 | 3Com SuperStack 3 3824 (3cr17402-91-uk)...
Compaq Presario 700 470024-192 Notebook Logo
114 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
