Question about RCA VR706HF VHS VCR
TIMER flashes on the VCR front panel and there is a cassette in the VCR. The TIMER indicator is suppose to flash when there is no cassette in the VCR. I always keep a cassette in the VCR because I tape General Hospital Monday-Friday. After watching my tape last night, the timer button began to flash and the power on the vcr automically shut off. Everytime I would turn the power on,the vcr automically shut itself off after 10 seconds. I can't even eject to remove the tape. I have had this vcr for years and never had a problem. It's really is a good product. What's going on? My second question is, I have about 50 tapes I have recorded from this vcr. How do I convert those to dvd?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Hold the stop button
Posted on Jul 15, 2010
Town and counrty front right signal light flashing faster, rear light stop flashing
the signal indicator lights are suppose to flash in perticular time interval which is connected to a timer relay when the light flashes faster that means the other light is not working and the relay is getting double the current and moving faster so check the other light either the bulb is fuse or the current is not reaching up to the bulb
Aug 22, 2012 | 2005 Chrysler Town & Country
My Sony Trinitron tv is not turning on. It has turned on a couple of times, but the standby light on the front is blinking. WHat's wrong?
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes
Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
when there is trouble with your Sony Television set -- it indicates the issue in either the diagnostic mode, or even more commonly by flashing a series of LED blinks or flashes on the front of your television. Each set or frequency of the blinks indicates a very specific problem with the television itself.
Sorry but unless you may be able to repair the television set yourself , please call a local repair shop to the have a repairman sent out,,
Take care and please Remember to rate/vote for us to
continue f
or Helping out the Community :)
Jul 08, 2011 | Sony Televison & Video
Sony bravia KDF-50E2010 RED LIGHT FLASHES 4 TIMES THEN 3
Sony TV LED & Blinking Codes - What Does It Mean When Standby/Timer Light Flashes Sony has provided a "self-diagnosis function" with your TV, that in the case of abnormalities or problems the LED or red blinking light on the Timer/Standby indicator flashes a number of times to indicate the issue.
continue f
Jul 08, 2011 | Televison & Video
The cst in light keeps blinking how to turn it off
Hello
I managed to find a PDF manual for your VCR Combo, However i couldnt find anything to indicate a reason for the Cst in light flashing. I did find however find that the TIMER REC Light flashes if T-SET is pressed for a timer recording, but there is no tape in the DVD/VCR. It also flashes when all timer recordings or One-Touch Recordings are finished. So possibly this could be the light you see flashing.
The PDF can be found Here
Hope this helps
Mar 06, 2011 | Symphonic WF803 DVD Player/VCR
I have an older but operable Sanyo VWM-700 4 head hi-fi VCR to connect to an older but operable 13" TV just to watch workout video cassettes(via cable, no cable box necessary).How are the connections made...
You connect the Antenna to the VCR, you connect the AV OUT from VCR to AV IN on TV.(Yellow, Red & White) (Doesn't matter as long as color to color) Then you TUNE the VCR to the channels and the TV simply acts as a monitor. You must tune the TV to the OUTPUT from the VCR. If ya play a tape and look for the signal on the TV, to "Tune it in" to the VCR. first. then go to tuner.
Jan 26, 2010 | Televison & Video
Washer lights are all flashing
Hi friend.....
It is an indication of an error code,,,,,,,did you see any error code on timer.........
thank u..........
May 03, 2009 | Electrolux EIFLW55HIW Front Load Washer...
Entire front panel does not work, but responds to control.
have you pulled the plug from the wall for a few minutes?
also, some vcrs will eject the tape when the RECORD button is pressed on the remote, and a tape is inside that has the record tab REMOVED!
good luck
Feb 07, 2009 | RCA VR622HF VHS VCR
Flashing auto display - won't power up
The infra red light in the middle of the mechanical deck, that powers the left and right photo sensors is not ok.It looks like a small lamp( you cant see it when it works-Infra red mind it).The video cassette has a large round opening in the bottom towords the front, and accomodates this lamp.please check it out.
Apr 25, 2008 | Televison & Video
Error 2 on Front Panel
I'm not sure if this is a solution, but it cleared up the problem for me. It turned out there was a loose paper label for the cassette that got stuck inside the VCR with the cassette.
I had to take off the top of the VCR by removing the three screws. I then removed the jammed loose paper and then was able to get the cassette out. The flashing number 2 (whatever that means) went away. The machine seems to be working fine now.
Apr 19, 2008 | Philips VR620CAT VCR
RCA VR706HF VHS VCR Logo
327 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
