Question about Sharp VL-Z100U Camcorder
Tape door stuck
Hi, can anybody help please. My VL-Z100 works ok but the tape door/mechanism won't close. The battery charges ok and the lcd and all functions are working. The tape door seems to be stuck. It won't close with or without a tape. Any advice would be most welcome. Cheers.
5 Suggested Answers
SOURCE: problem with camcorder model vl-z1h
same problem. please help
Posted on Apr 15, 2008
SOURCE: Sharp Viewcam VL-E66U
I let it sit overnight and when I opened the door I nudged the part that holds the tape up. I got the tape out but I think it is still frozen. I will try a different tape and hope it still works. I'll post results.
Posted on Sep 08, 2008
SOURCE: Sharp Hi8 Video Camera VL H410
This camera needs to have the battery recharged in order to remove the tape.
Posted on Nov 20, 2008
  • 405 Answers
SOURCE: Sharp VL-Z1 will not load the cassette...
Modification is available to fix this problem, contact sharp repair facility.
Posted on Oct 26, 2009
  • 48 Answers
SOURCE: i need an ac adapter for sharp viewcam vl-z100
Futurshop and a few other smaller stores like Mycrobytes have anything you need.
Posted on Feb 08, 2010
0 characters
1 Points
I have a Sharp VL-E760 viewcam LCD that records on 8mm tape. The battery no longer charges and I have a tape inside that wont come ojt because it needs the battery. Is the problem the charger itself
The problem is most likely the battery itself when you have finished using your kit and wish to put it away never put it away with a half or fully charged battery as it will not last always run it down and never leave a tape in either.
Apr 18, 2013 | Sharp Video Cameras
Tape door won't open or close to release tape
Sony Handycam CCD-TRV58 Hi-8 Analog Camcorder
1. Per the manual on
- if the power is disconnected door won't open, and if the battery is the dead the door won't open.
Plug it in and hopefully you can get the tape out.
Did this work?
Feb 11, 2013 | Sony Handycam CCD-TRV58 Camcorder
Sharp VL-Z7U cassette door will not shut - with or without tape.
Always use the camcorder with the battery and power button on.
Does the cassette compartment close without the tape ? If yes. then we have hope.
Now insert the tape and press to close the compartment as usual. Does it close or reject every time ?
If it rejects, then very slightly nudge the three tiny figures of the mechanism where the two wheels of the tape fit.
Now the tape will sit inside the compartment and lower itself.
If it still ejects, then very slightly press the base metal (where the tape rests once loaded but) without the tape. This is the largest metal piece visible closest to the hinge and door.
The tape will load properly now.
You could face error DEW or 007. Both are known errors.
DEW is really due to moisture in the air. Try on hot dry place.
for 007 error, you would need to carefully clear with one index figure the reading head. Remember all parts of the camcorder are delicate and need carefull handling.
Never use any tools, fluids, fabric or tissue.
Let me know if this solves.
I am looking for USB driver for Windows 7 and the method to extract from tape as I do not have Firewire (Ieee 1394) any more in my laptop and desktop.
Jan 06, 2013 | Sharp Viewcam VL-Z7U Mini DV Digital...
Cancorder not wrking-e007 error message
moisture in the cassette holder. Take out the cassette, leave the holder door open for a couple of hours in a dry, warm location, and it should work again.
Sep 12, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Reinsert cassette
I've been researching this for hours. I have the same problem. Took it to a repair shop today that would charge me $250 to replace the whole tape mechanism. Finally, I tried the whack trick. I gave the camera a good firm smack on the right side, and voila, now it works! I'm going to tranfer everything to DVD ASAP!
Jul 10, 2008 | Sony Handycam DCR-TRV480 Digital Camcorder
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Gs36 tape door doesnt open
In case anybody read this....     I have a GS-36 that would not eject the tape. I removed all the screws from the bottom and pulled the bottom plate off. Then I fidgeted with the mechanism near the eject button towards the front of the camera.  In my case it had just become stuck and needed to be gently pried open.    Tested it a bunch of times with tape - seems to be o.k.!
Oct 13, 2007 | Panasonic PV-GS36 MiniDV Digital Camcorder
Cassette holder does not close
Try inserting another tape first. If the trouble is still there,Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Aug 20, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Dew liht comes on and camcorder shuts off
I had the same problem with a VL-Z3U, there was no home fix, the dew sensor needed replacing costing $130 CAD
Jun 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Tape door wont close
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Sharp VL-Z100U Camcorder Logo
Top Sharp Video Cameras Experts
abdul rauf
abdul rauf
Are you a Sharp Video Camera Expert? Answer questions, earn points and help others
