Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Software not opening with Singer Futura on Windows XP
Just a note for people with Windows XP using the software for Singer Quantum Futura CE 200. I could not open the program, called a computer repair person, spent lots of money, restored my computer and it still would not work. I just happened to call the store where I bought the machine and "Oh, other people have been also calling about this". Well it turns out that the only problems was that Windows XP's new automatic updates do not support the software for opening the futura program. I had to just TURN OFF the automatic updates and it worked like a charm. $500 later and losts of frustration. I hope I might prevent others from going through this. Jonebone
  • 1 more comment
  • Anonymous Apr 16, 2008
    Yes im having the same problem, glad I found this article
  • M4SHERMAN Jul 22, 2008
    windows will not update
  • pgray297 May 11, 2010
    I have an apple computer. I am not able to install. Anyone know what I can do to get started?
I am having the same problem with the autopunch , i too am running win xp sp2 , i have downloaded the patch , i have turned off automaic updates . and tried the to completly disable it . i think we should write to singer this isnt gwtting our moneys worth its getting a headache . what u think . they should come out with better software , it works or a while but when you shutsown and try again at later point you have to re do all the installation . is there anyone we can write to ,since singer isnt helping find a solution . if anyone comes up with solution please post . i am going bananas , i love my machine but i want to be able to import my own designs . help ....
Posted on Jan 29, 2007
Hello all. today i went in this site www.futura-support.com. so press this http://www.futura-support.com/downloads/patch.htm and read... you will she this ->
Posted on Nov 02, 2006
You have to download the patch
I have the problem of there not being a patch for Windows 7
Posted on May 10, 2010
After much frustration with this problem, I finally went and bought a used, refurbished laptop with xp on it. Warrant lasts one year and I am ever so happy to get going again! Now, both of my machines are up and running at the same time, and I can now get my orders out on time!. I decided that when this happened, I could not afford to lose this kind of time again, so, I DO NOT CONNECT EITHER LAPTOP TO THE INTERNET, for my machines, so no possible problems ever again. I also get to use my main computer for internet only.
Posted on Feb 23, 2010
You all can trade places with me My cd got broke in the move And its gonna cost me an arm and leg to replace it
Posted on Oct 09, 2009
When i try to open C: or D: in my acer aspire 5570 (I am using Window XP), it asks me from which program? Also, my Internet Exporer prompts an error "The procedure entry point InternetGetSecurityInfoBy URLW could not be located in the dynamic link library WININET.dll.
What could be the reason for this and what is the solution?
Posted on Sep 30, 2008
I do not have a solution, but the same problem. Also, Hyperfont causes the same shut done. Don't we need the sp2 for the other applications on our pcs?
I will be contacting Singer and making a complaint!
Posted on Dec 17, 2007
Sorry no solution but I am in the same boat as eabates. I can't load autopunch and open the Futura software. I did turn off the auto updates but if I'm reading this right I have to remove the updates as well, right? I have to turn off startup type, right? I am so new at this that I need someone to bring out the crayons. Paige
Posted on Jan 07, 2007
This is not a solution but I have the same problem as eabates. As soon as I intall the Futura AutoPunch software I can't open the Futura embroidery software anymore. Like eabates I have turned off the auto updates; I have disabled it at STARTUP TYPE. It all worked fine until this week. Thank goodness I found this site and got the primary software working but I WANT AutoPunch too. Anyone have any additional potential solutions??? Thanks so much for just getting part of the software working again.
Posted on Sep 25, 2006
Ok, i dont have a solution...i have a problem, when i install the Futura software it works fine but as soon as i install the Furtura AutoPunch software i cant open the program anymore...I turned of the Automatic Updates but it still wont work. I hope someone can help me... thanks, eabates
Posted on Sep 22, 2006
  • Erika Bates Sep 29, 2006
    Dear Sandie,
    Thank you so much for your help!!!! Its working!!!!
    Thanks again!!! Erika
    Problem Solver:
  • 15 Answers
I know what your talking about I have help others the same thing and turning off the updates is not all you should do cause it well come back ON in time you have to disable it from the Administrative Tools menu - click on Services, at the Automatic updates right click, click on properties at middle of page you well see "STARTUP TYPE" change it to Disabled. That well take care of it for good until you change it back to Automatic which you well need to do if you want an system update then you can go back to Disabled.
Posted on Sep 10, 2006
I just received the latest technical bulletion from Singer on this issue. The fix to the problem is listed below: My system worked perfect with Hyperfont and Autopunch after completing the process. GOOD LUCK! ------------------------------------------------------------------- REMOVING SECURITY UPDATE FOR WINDOWS XP KB917422 You must first disable the updates; otherwise as soon as you remove the update and reboot your computer, the update will automatically reload. To disable the updates: ? Left Click on Start. ? Left Click on Control Panel. ? Left Click on Security center. ? Left Click on Automatic Updates located at the bottom of the popup screen. ? Select either Notify me but.. .or Turn off Automatic updates. (You may choose the one that you prefer). ? Left Click on OK. To remove the update: ? Left Click on Start. ? Left Click on Control Panel. ? Left Click on ADD/REMOVE programs. ? Check (?1) the ?Show Updates? box at the top of the pop-up screen. ? Scroll down and look for ?Security Update for Windows XP (KB917422)? ? Left click on this update. ? Left Click on remove. ? Continue following the prompts such as Next and Finish to remove the update.
Posted on Sep 29, 2006
2 Suggested Answers
  • 106 Answers
SOURCE: Software not opening with Singer Futura on Windows XP
Bit out of my league can I suggest you talk to a computer expert.
My limited knowledge tells me while trying to update, your previous software package has been corrupted.
Posted on Mar 30, 2008
Software for singe futura ce-200
That is called the upgrade or compatibility software, and I would recommend that you search on eBay under Singer CE-200.
Nov 17, 2015 | Singer CE-200 Quantum Futura Computerized...
My embroidery (Singer Quantum XL6000) requires the Windows XP and lower on a computer to acquire additional patterns, will it work with Windows 7?
Mine works with Vista. :)
Just install the XP patch (futura-support.com/downloads/patch.htm) and tell Windows 7 to run the software in XP mode.
Oct 07, 2011 | Singer CE-200 Quantum Futura Computerized...
I have windows 7 and the futura software will not load into my singer quantum 200. I had no problems with my old computer which had windows xp. is there an updated futura software? Please help
Yes, there is. Go to http://www.futura-support.com/downloads/ce150.html. Read the instructions VERY carefully. You will need to have the 2.5 Futura upgrade, which is available for $99 at Jenny's Sewing http://cart.jennys-sewing-studio.com/.
In case you do have your old version of Windows XP lying around and don't care to spend the money on the upgrade, there is another alternative, though it does take a few more steps. But I use it currently on my machine to run my Futura and it works beautifully. It's available at http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista and will allow you to run any old XP software on a Vista or Windows 7 machine, but only if you have your old Windows XP software available.
Either way, be sure you follow the instructions carefully. With the upgrade, I have two friends who I've upgraded their software to run their Futura's this way and they both are working fine. As I said, I use the 2nd way and have been for month's. Good luck!
Jun 14, 2011 | Singer CE-200 Quantum Futura Computerized...
There is a patch for Windows 7 at www.future-support.com. That site is an amazing resource for the Futuras!!
Apr 14, 2010 | Singer CE-200 Quantum Futura Computerized...
I have lost the Access Key from my CD to the Futura Software. The software is loaded on my system but is asking for the key. (Singer Quantum Futura CE 200)
You will have to contact Singer customer service.
They have a website where you can look at FAQ and Futuras to see if this has been addressed before sending the question.
Mar 27, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer futura ce200 software problem
You may ask your Singer supplier about Futura 2.5, this version of the software supports old machine models ce100/200, contains more features like the software for newer machine models and works under new OS including Windows 7.
Mar 22, 2010 | Singer CE-200 Quantum Futura Computerized...
My quantum futura CE-200 won't work on my new laptop which has windows 7..Anyway to correct this problem...
If you are using Futura 2.0.0.x software there is no update yet, but Windows 7 support has been already included into update for Futura 2.5.0.x. You may ask a closest Singer supplier about it.
Feb 21, 2010 | Singer CE-200 Quantum Futura Computerized...
I have a Quantum Futura CE-200 and my computer cannot find the drivers for the machine. Not sure where to look for them. I have loaded software and patches from Singer web site. Any ideas?
You need to look for the drivers on the site and download it to the futura program, if one driver is not loaded correctly your program might stop while you are embroadering of might not work at all.
Apr 10, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura CE-200 Software fails to initialize on XP sp2
Maybe you should try to contact singer south africa and ask them whats wrong, my laptop did the excact same thing switch over to home pc and no problem ever again.
Mar 02, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
1,502 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
