Toshiba 46x3500a removal of base
How do you get the standard base off a 46X3500 plazma please surely you don't have to remove the back panel do you ???
Thanks Jason
  • tufy Dec 02, 2008
    I have exactly the same problem as Jason..... I made a wall fitting all ready for the TV and when I turned the TV over - lo and behold - no way to remove the existing base!!! I'll be going into town tomorrow to find out from the supplier (hopefully HE knows!) If I find out I will post a solution ..... but don't hold your breath!
5 Suggested Answers
SOURCE: How to remove a back panel of maytag neptune dryer?
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Posted on Mar 19, 2008
SOURCE: Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Posted on Aug 18, 2008
Catriver was right on the mark. Took a little bit of doing but I was able to fix the problem myself within 30 mins, and saved some money. Many thanks. I'd like to expand Catriver's solution a bit.
I found a layer of lint on the inside bottom of my dryer. With the face off of the dryer, it proved to be a good time to vacuum the lint out and reduce the potential of fire.
Posted on Sep 07, 2008
SOURCE: Remove Base from Toshiba Regz 42RV530U
I bought this LG flat TV at Circuit City last week. TV is okay, but I was trying to hook up my portable DVD player and I can not make it work. I can hear the sound that coming out from the DVD but theres no picture from the screen. I believe my connection is correct, because there is the color coding which is red, yellow and white which you just connect at the back of the TV and at the DVD player.
Can anyone help me to figure out the problem. thanks a lot
Posted on Jan 31, 2009
SOURCE: Install Rear Speakers Ford F150 1997 Regular Cab
you should not have to remove the panel by taking the four phillips screws out of the speaker grill you will pull out through front
Posted on Apr 02, 2009
How to I remove the back cover on a Toshiba 50L1350UC LED TV. I have removed all the screws as I have on dozens of other tv repairs, but can't seem to see how to remove this back cover. Thanks.
Toshiba TV Repair - Replacing 26AV5 Backlight Inverter ...
? 2:36
https://www.youtube.com/watch?v=ZoAn6ovLVXc
Apr 22, 2013 - Uploaded by ShopJimmy.com
There are various ways to eliminate static electricity, but the most common ... Return the back cover to its original position and secure all screws. .... Hi I am having problem with my TOSHIBA46TL963 TV 3D LED TV WITH NO ...
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
Free Fix For Toshiba 50" TV That Will Not Turn On. ... Removeall; Disconnect. Watch Queue. Queue ... p.s. could they put more screws in that back panel? .... Now the TV turns on, so does theLED backlight, but NO PICTURE!
Toshiba TV Repair - How to Replace 75021540 Main Board ...
? 2:38
https://www.youtube.com/watch?v=AUOAQR_raTA
Feb 28, 2013 - Uploaded by ShopJimmy.com
Toshiba TV Repair Main Board Replacement for LCD TV Fix No ... Unscrew and remove the back cover. ... LCD & LED TVRepair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD & LED TVs - Duration: 5:56.
Jan 17, 2016 | Toshiba Televison & Video
I cant remove the stand of my toshiba television model number 32AV554D
Take a good look as it should have 4-6 machine bolts holding it--be careful as usually it must be laid face down to remove----no weight on the screen or downward pressure or bang---screen destroyed and set with it.
A few models the back cover has to be removed but that is rare.
Nov 04, 2012 | Toshiba REGZA 47HL167 TV
HOW DO I REMOVE THE BACK FROM TOSHIBA 32HL67
Remove the base stand assembly.
Find all perimeter screws and remove those as well. Most sets have big arrows pointing to the holes on the back cover where screws must be removed. This one may or may not. Before you go yanking on the cover, make sure you check near the inputs (RCA jacks, HDMI ports, etc.) to see if there are any small screws and remove those as well. Gently begin prying at the cover; if it's not coming off with utmost ease, you probably missed a screw. Just be patient and gentle and treat her like lady. Er, wait, we're still talking about TV's right? haha. But seriously, that's all there is to it.
Jan 18, 2012 | Toshiba 32HL67 32 in. LCD Television
How do you remove the base from A toshiba REGZA 37A3030D
There are four screws located on the back of the tv twords the bottom. unscrew those then flip tv on its back to let the fallout. base should come free.
Mar 30, 2011 | Toshiba REGZA 47HL167 TV
I cant remove the base for my 16 inch lcd toshiba tv can you send my a diagram i cant find the bolts in the bottom
See page 5 of the USER'S MANUAL at the following link:
http://support.toshiba.ca/support/ceg/manuals/manual.asp
If your tv is not the same as that then just enter your tv's model number at the following link:
Good luck and please comment back if this was helpful.
Feb 04, 2011 | Toshiba Televison & Video
How do you remove the base stand from a toshiba 46lx177?
First, carefully lay the face of the TV down on a soft surface with the stand protruding over the edge of the surface, then remove jack panel cover on the back of the TV to expose the 5 screws holding the base on. Remove those screws and slide the base away from the unit. These instructions are also found on page 5 of your owners manual.
Jan 29, 2011 | Toshiba 46LX177 46 in. LCD HDTV
I want to hank my toshiba 42-95plasma tv on the
Toshiba has about six screws holding the base legs on remove them and pull the base straight down till the legs come out all the way
Jul 25, 2009 | Televison & Video
Removing the base of flat panel tv
You don't have to mess around with the screws on the bottom of the base.
There are 4 screws on the back of the Toshiba that are in line with the wall mounting screw holes.
Remove the 4 screws and the base falls off.
Nov 23, 2008 | Toshiba Televison & Video
Jul 11, 2008 | Televison & Video
Toshiba regza lcd 46x3500
This is what is known as a dead pixel. If you have a standard wide screen lcd monitor it has over 1 million pixels. It is not super un-common for one to go bad. It will either always be dark or in your case always be lit. It is not worth it to repair, and in most cases unless you have multiple dead pixels with in a square inch of screen, it is not covered under warranty either.
Each pixel is individual and the problem will most likely not spread.
Jul 08, 2008 | Televison & Video
Televison & Video Logo
188 people viewed this question
Top Televison & Video Experts
Electro Med Services...
