Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice maker will not eject ice after it is frozen, fails to rotate
    Genius:
  • 1,198 Answers
At least you know the water is getting to it. The module is behind the square plastic cover, it fails easily. If you see any soot or melted spot on the timer wheel, it's done. The new one must be installed very carefully, don't force it. It is best to take the unit out of the freezer to be sure everything is aligned properly. The bin switch is delicate, must be handled carefully.
Posted on Jan 24, 2009
Ice Maker Failing to Eject Ice
icemaker not making ice video-
Nov 23, 2014 | GE Refrigerators
Ice cube ejector bar keeps freezing preventing ice from ejecting to tray
Replace your water valve part # WR57x10032, from what you have listed above you have a bleeding water valve allow water to enter the ice maker mold. The valve is not closing completely. This part show fix this issue for you.
Good Luck
Mar 30, 2014 | General Electric GE GSS25GFXWW (25.0 cu....
The ice make stopped working. There is ice in the water feed tube. The ice maker is full of ice, but it is not dispensing. Ice in the storage bin was frozen together into blocks.
The icemaker in it's operation hits a microswitch to turn on a warmer in the aluminum tray that aids in extracting the ice by the rotating vanes. It may be that that part of your icemaker has failed.
Try this for a solution first. Remove all of the ice from the bin. Using a hair dryer, melt the ice in the tray and the fill tube. Be sure to warm all of the switches behind the plastic front cap in case those switches are frozen. Let the ice maker fill again and see if you have made ice. Often splashed water will freeze the rotating vanes and will not let the ice maker rotate through it's complete cycle.
Mar 08, 2011 | KitchenAid Refrigerators
Ice maker makes ice but will not rotate and dump the ice.
You have a thermostatically controlled heat release ice maker. Any number of issues can cause a failure to "dump" the ice. The harvest is started when the thermostat closes. A motor rotates the ejector fingers which are at rest in the 2 o'clock position. The ice maker operation will stall until the heater releases the ice from the mold. After the cubes are ejected into the ice bucket, the water valve will refill the mold with water to begin the next cycle. Lack of ice dispensing could be a failed thermostat, heater, motor or switch contact withing the ice maker module. You could simply replace the ice maker and save the expense of the service call.
Dec 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
My ice maker does not eject ice when frozen. Make
Good day,
Unplug refrigerator.
Snap off front cover of the ice maker. You will see a large white gear.
If the plastic gear has a screw in the center, then you can remove the gear and inspect for broken teeth. The gear is easily replaced thru any appliance parts house.
If there is no screw then the ice maker uses a semi-solid circuit board and must be replaced.
Dec 17, 2009 | Kenmore Refrigerators
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
Jun 13, 2009 | Amana ARB2257C Bottom Freezer Refrigerator
Ice Maker Infrared light doesn't light
Each mold tray has a heating element that is turned on to free the ice cubes from the mold tray and allow them to fall into the ice bucket when the tray is rotated into harvest position. Sounds like that is not being turned on... or is defective..
Sep 18, 2008 | KitchenAid KSRG25FK Side by Side...
Ice maker not working
Depending on the ice maker style, they typically work off a motor timer. The timer motor rotates to set up the ice making process... starting with letting water into an empty ice mold tray, allowing ample time for that water to freeze and then to rotate that mold so that the cubes fall out into the bin. In conjunction with that process, a small heater is turned on to release the frozen cubes from the tray. The 'ice tray full' lever signals the system to stop making ice so you may want to verify that the lever is down and not causing the ice maker to stop, If that's down then I suggest you monitor the position of the motor gearset underneath an access cover. With power applied, the gears should rotate and cycle thru an ice making process. If it does and ice fails to fall out, your heater may be defective. Hope that helps...
Jun 22, 2008 | Roper RT21AKXKQ Top Freezer Refrigerator
Ice maker cycling but getting stuck
Either you have a bad heating element (soften the ice to eject) or a stripped gear in Ice Maker either way it will have to be replaced by the time you buy the parts and install them you can just replace the ice maker as a unit
May 10, 2008 | Frigidaire FRS23KF7AB Side by Side...
Ice is not ejecting
Sounds like the icemaker thermostat is opening too soon which turns the heater off.  The easiest thing to do is replace the whole ice maker which I have seen pretty cheap on ebay.  If you want you can test these part with an ohm meter.  Check the heater for resistance.  If it is ok then replace the module and thermostat.
Oct 26, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
236 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
