Stopped Dead I have a Roper washing machine Model # RAB4232EW1. A couple of days ago I went to start it up, and nothing. Not one sound. I checked the electrical connections and fuse box and everything checked out. Anyone know why it would suddenly stop working? Just out of curiosity, how old is this model?
  • MaggieWillow Oct 30, 2008
    It may sound obvious, but to us non-mechanical/technical types who only use the machines and could care less about the mechanics of it, always check the electrical outlet. Turns out the outlet itself was dead. Plugging the washer into another outlet proved to be the solution. I will certainly know to check the lid switch (and outlet) should it happen again. Thanks for the help.
These machines only have 2 problems
dive coupling no wash or spin
or lid switch machine totallaly dead normally caueded by droping heavily & breaking the housing of the lid switch
Posted on Oct 30, 2008
Greetings, and thank you in advance! I have a Roper Heavy Duty Super Capacity 7 Cycle Top Loading Washing Machine.
sounds like you need to call a repair service . motor or transmission may have went out
Mar 16, 2017 | Roper Washing Machines
Roper washing machine whines intermittently throughout the entire wash, rinse and drain cycle.
Roper whining noise Washing Machines Questions ... - Fixya
www.fixya.com > Forum > Tags > whining noise > Washing Machines
Roper washing machines whining noise related questions and answers. Ask your Roper questions. Get free help from washing machine experts.
Sep 28, 2015 | Roper Washing Machines
Dead phone
I know this sometimes happens with these smart phones; one day they just up and quit.
You could try a fresh battery, and check your charging source.
Mine did something similar a couple days ago - I thought it was charging all night long, and in the morning when I went to turn it on... nothing. It ended up being my charging cable, it wasn't putting any juice to the phone.
Apr 01, 2014 | HTC EVO 4G Smartphone
My roper washing machine modelRA845KJQ have a fuse in it? I just stopped wrking mid wash..its full of water and will not work andwe repaced the motorand he coupling in it ndstill nohin and was wondering...
If its sitting dead... and you have no wash/fill/or spin.. I would tend to think timer. If the tub I full of water, reset the timer to wash... if it washes and then die's at the rinse... look at the lid switch.
Mar 08, 2014 | Roper Washing Machines
I have a Whirlpool Ultimate Care II washing machine, model number: LSQ9110PW3 that stopped working properly two days ago. At first it seemed to not be able to go into the spin cycle. However, I just...
You have one of the best washers ever made... It is called a "Direct Drive" by us technicians. You probably need this part, but NEVER get rid of this machine as NOTHING out there is this good- not for anyprice. https://www.repairclinic.com/PartDetail/Whirlpool-Washing-Machine-Motor-Coupling/285753A/1195967?modelNumber=LSQ9110PW3&ss=a11b5d654521&mr=1
Apr 07, 2017 | Whirlpool Washing Machines
Roper model RAB4232EW1 doesn't spin out most of the water on close. Spins and drains but leaves close too wet.
Pulloff the back of your washer sounds like you might have overloaded it and cause the belt to slip. Should be just a couple of screws when you look in with a flashlight you should see the issue if you dont start it up on a dry run and watch what happens. But I am guessing that the belt must be slipping. Let me know what you find and I hope it helps!
Dec 22, 2010 | Roper Washing Machines
Started making grinding kind of noise a couple weeks ago...just now stopped spinning.
there are to tub wheels that hold the front of your drum up ck them but it sound like your tensioner has went bad it is a spring with a plastic wheel on it located beside the motor in the bottom and back of your machine. It sound like the tensioner went bad a probably broke your belt replace both
Aug 08, 2010 | Roper RES7648E Dryer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
185 people viewed this question
Top Washing Machines Experts
