Question about Onkyo TX-SR600 Receiver
Volume decrease Hi, I own a receiver Onkyo Tx-SR600E, bouth in 2003. I use it just on weekends, and just ocassionally at more that 50-60 volum (maximum volume 100). The problem is that, now the volume has decreased without explication, I mean, now I must turn to volume 55 to hear what normally was heard at 35. And I must turn into 75 was before was heard at 55. I have inserted my cans, just to comprobe if the problem could be in the loudspeakers, or in the wires that connect with them, but the cans are heard the same low. I have tried differents channels, dvd, radio, etc, and they all works the same bad. I have had a look into the instructions manual, but, of course, no solution. Before I take it to the technical service, it would be very kind of you if anyone could give an idea of what could have happened. Thanks everybody in advance. Antonio Lopez (Spain), 10/Sep/2006
I own the same receiver for three yeras now. During that time it happened four times that it lost all pre-settings such as speakers volume settings and intelli volume. I have no idea why this happened, but it did. If this happens it feels like your amplifier suddenly lost half of it's power. Restore these settings and you'll have your "old" power back.
Hope this helps,
Posted on Nov 24, 2008
May be some one modified the set up. You can configure different level for different speakers.
Posted on Jul 10, 2008
Replacement Volume Knob Onkyo TX-5811
Maybe the cheapest and the best way to get the knob is to check ebay and buy the hole receiver for parts or check the link below. :) hope it helps
https://www.partstore.com/OpenSearch/Model/Onkyo+Corporation/Onkyo.aspx
Jan 29, 2014 | Onkyo Audio Players & Recorders
My Amplifier is in good working condition, except for the volume control has gone weird Using the remote, you can increase volume, but not decrease volume. On the unit, rotating the volume control...
Cleaning the contacts may help. The volume knob should pull off. Once its off use a non-flammable contact cleaning spray to clean the contacts behind the knob.
Electronics and automotive stores should have this.
May 16, 2011 | Onkyo TX-DS494 Receiver
My Onkyo TX-SR806 remote has recently lost its mind. The On/Standby switch no longer turns receiver on or off; must do it manually on the receiver. The Volume control is now reversed: when you press the UP...
Hello, the most used buttons can wear out over time. On/standby and volume are the ones that are used most often. I suggest purchasing a new remote. It is available at shoponkyo.com. Thank you, Onkyo USA
Jul 08, 2017 | Onkyo TX-SR806 Receiver
If I turn the volume yp over 60 on my Onkyo
disconnect speakers turn up to 60 and see if cuts out if it does not cut out check your speakers
Apr 04, 2010 | Onkyo TX-SR602 Receiver
"The blue light around my volume dial does not light
Try resetting the receiver (you will lose your setup). I recently reset my receiver and the blue light returned. It's possible that the Audacity setup turns off the blue light because the volume is now being "regulated" by the equalizer.
Mar 26, 2009 | Onkyo TX-SR705 Receiver
Onkyo ts595 goes into protect mode with volume increase
Hold the VCR/DVR button in and press the ON/OFF Standby button. The display should briefly read CLEAR and then the unit switches off. If that clears protect mode, you'll need to redo the Audyssey and configuration setup as these will have been cleared by the reset.
Sep 27, 2017 | Onkyo TX-DS575 Receiver
Volume on my Onkyo Receiver
Yes it is. I have the 705. My room mate has the 605. Both AVR's will not have appreciable volume until 50 on the dial.
The dial in not linear. I don't know of anyone who has plotted the scaling of the volume control yet.
I have found much useful user info on avsforum.com. Owners post Q&A based on experiences.
Search the forum for "official onkyo TX-SR605" thread.
Some comparable info may also be found under the "official onkyo TX-SR705".
May 21, 2008 | Onkyo TX-SR605 Receiver
Volume is changing/decreasing
well, that information is slightly undescriptive and unnecessarily vague, but I think I can suggest a few things.
If the problem only occurs when watching your HDTV, I am assuming you are using the Audio Out on your TV to pipe sound down to your Onkyo receiver. If this is the case, the TV volume may be turned down lower by mistake and you have to turn up the Onkyo's volume to correct for the difference.
Another possibility is that some other variable has changed i.e. source material, programming, TV firmware update. What did you change to get this to happen? Is it reproducible? Can you use other source material (DVD, VCR, or DAP (mp3 player) and use it at the same volume levels as before? I tend to think that your problem is with the HDTV, not the Onkyo. User error is the most common type.
Jan 14, 2008 | Onkyo TX-SR503 Receiver
Default volume too high
You can download the manual from the link below: http://www.intl.onkyo.com/downloads/manuals/pdf/tx-ds787_manual_e.pdf c. Power On Volume This sets a designated volume setting for the TX-DS787 to be set every time that the power is turned on. This prevents the TXDS787 from being turned on while it is set to an extremely high volume and suddenly output very loud sounds. For the absolute volume display method, this can be set between min and max. For the relative volume display method, this can be set between ?? and 18 decibels. If you do not mind having the TX-DS787 turned on with its current volume setting, set this to "Last." Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 03, 2007 | Onkyo TX-DS787 Receiver
Onkyo TX-SR600 Receiver Logo
252 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
