Question about Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A, 9.6v 1000mAh NiMh Pk 2-Way Radio
TH-79A amateur radio
Remote control is on, how to turn off?
  • schrieby Oct 30, 2008
    Tried your PTT/MR /Turn Power On solution. It did not work. Still show RC. Appprecciate any other solution. KF6JQI
    Thank you, the RC is gone. IIt is now locked on Ch 43 and won't change bands. This dual TH-791 is showing Ch 43 in the lower prorttion of the screns. When I press
    band it jumps to the other band but immediately reverts to the CH 43 on the lower portion of the screne. I appreciate all your assistance. KF6JQI
    Problem Solver:
  • 14 Answers
TH-79A Kenwood HT and with the power off, hold down the MR button and the PTT switch, and while holding both of these turn on the power. The HT will come up in the remote control mode with the display indication "RC" on one band and the normal display on the other band.
To get the HT out of the "RC" mode just repeat the MR+PTT+Poweron sequence
Posted on Oct 30, 2008
  • fire342 Oct 30, 2008
    By chance is the radio in lock? If all else fails, it sounds like the processor might need to be reset...
    TH-79A/AD/AKSS - With the power off press the F key for (memory reset),
    and turn the radio on.
    For VFO reset with the power off press the VFO key, and then turn the radio on.
Why does my kenwood TH-K2 fm transceiver will not transmit
Users Manual (download if you don't have it)
You can inhibit the transmission to prevent unauthorized
individuals from transmitting, or to eliminate accidental
transmissions while carrying the transceiver.
1 Press [MENU].
2 Turn the Tuning control to select Menu No. 25 (TXI).
3 Press [MENU].
4 Turn the Tuning control to select "ON".
5 Press [MENU] to store the setting or [PTT] to cancel.
"TX INH" appears and an error beep sounds if the
transceiver tries to transmit while TX Inhibit is ON
May 11, 2014 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
TH-79A Blank screen. It works with "F-switch on" but then goes blank.
Happened to me too. It takes some disassembling!!!! Between the screen and the underlying circuit board is a rubber strip with conductive material throughout which provides ''ground' for the display. This rubber wears out over time, but the quick fix is to turn it a quarter after cleaning and treating the contact surface with 'contact spray'( sparsely!!).
Job requires steady hand and pincers.
May 28, 2009 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
I don't have a screen display on my TH-79A. The radio is usless in this condition. Has anyone else had this problem and what was your fix?
You could have a defective screen or a defective LCD driver, either way you have to replace it.
I 've replaced LCD screens before they typically are the entire front half of the radio inside wise. Probably going to cost a few to do it.
Mar 12, 2009 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
My th-79a shows channel numbers only
RTFM Page 29
Press [BAND] + POWER ON to toggle Channel Display
Gerard - PE1OUD
Mar 04, 2009 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Unlocking Kenwood TH-22AT
Dec 20, 2008 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Drill a hole in the front panel. The mic is behind the front panel. Be careful.
Aug 12, 2007 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Kenwood 79a dual band transiever
There are several reasons for this, but one can be the flex that joins the display with the circuitry, carefully check if this is not broken or in this process or dirt.
Jul 02, 2007 | Kenwood PB-34M, ,TH-22AT,TH-42AT,TH-79A,...
Radio Communications Logo
376 people viewed this question
Top Kenwood Radio Communications Experts
michael galang
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
