Question about Canon FAX-L900 Plain Paper Laser
Machine ID We have 2 Canon L-900 fax machines, but having moved offices, the machine ID shown at the top of a transmitted page is no longer correct. How can I access the relevant menu to reset the number shown?
  • 318 Answers
Press Dataregistration-set-usersettings-set ,change the name and number in this mode.
Posted on Oct 30, 2008
Transmission difficulty with my Philips Fax machine (PPI 27 1B/05).
I don't know much about faxes but I have used a couple and found nearly all such problems are caused by the recipient machine encountering a problem and closing the transmission line.
Standard machines aren't so bad and most problems I have encountered are caused when a desktop computer is used instead of a fax machine - they are often switched off except during office hours for instance...
Nov 27, 2017 | Philips Office Equipment & Supplies
My fax machine is recognizing my home number which is line 1 in our house. I need it to recognize line 2
No fax machine holds your address. You can enter your fax number which is called the csi (caller station ID) and your Name (ie company name) called your TSi (transmitting station ID). thats all. Some machines will let you have multiple TSI's for different departments. I have never in 25 years on working on faxes ever heard of one holding an address!. The maximum amount of digits you can enter ranges from 15 to 30depended on make and model.
Srri
May 15, 2011 | Canon Office Equipment & Supplies
We have two fax machines hook up to one dedicated fax line. When we send a fax from wither machine it is not faxing to the phone we fax it only sends the fax for the second fax machine that is in our...
Yes, you must set up your fax machines like this: The receiving fax must be set to auto receive and the telephone line must be inserted in the "line" input. A line must then be connected from the "Tel" to the "Line" of the Transmitting machine, which must be set to "manual receive." This is not really a satisfactory way of doing things as you can't send and receive 2 machines on the same line together. A much better way is to have 2 lines. with a machine attached to each. Get the tel company to put "No answer transfer" on the line as an accesory. Give them the number of the fax machine that transmits. Make it "manual receive" Now you have a versatile system that you can also use the office telephone with.
Oct 05, 2010 | Brother Office Equipment & Supplies
Cannon laser fax 1060 P "check paper size"
Hi Margaret
Ok,the problem normaly with this model is in the feeding of the paper.For some or other reason the paper is moving to slow threw the machine and then the machine detect it as a longer size paper.
  • Clean the rollers that pick the paper up and clean also the sepatation rubbers under neath the paper pick up rollers.This rubbers is called the separation pads.
  • To clean this rollers,remove the cartridge and you will see the feed roller at the back.
I think what happened with the move the machine might collected dust and now the rollers are slipping.
Thanks for you support
Dec 29, 2009 | Canon L220 Plain Paper Laser Fax
Error code 345
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted.
Number of possible causes, check the phone line, try a different fax number for a start. Is there other fax machines in the office on the same line
Sep 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
TX Report misses out Destination Number
The ID on the TX report only show the ID if the ID is programed on the fax machine you send it to.The only way is to ask the destinated party to program the Fax name.
Apr 30, 2009 | Canon FAX-JX200
FAX back
Do you mean to get the paper document back out of the machine? If it doesn't feed out automatically, it may need to be repaired.
If you mean that you want confirmation that a fax was sent, you can turn on the TX (Transmit) REPORT. This will print out the first page of a fax sent successfully.
1. Press the Additional Functions button.
2. Use the arrows to select FAX SETTINGS. Press the Set button.
3. Use the arrows to select REPORT SETTINGS. Press Set.
4. Use the arrows to select TX REPORT. Press Set.
5. Use the arrows to select OUTPUT YES. Press Set.
6. Press the Stop/Reset button.
The machine will automatically print an Activity Report after every 20 faxes (sent or received). If you want an Activity Report at any time:
1. Press the Function button.
2. Press Report button (number 03 on the left side of the keypad)
3. Use the arrows to select ACTIVITY REPORT.
4. Press the Set button.
Apr 17, 2008 | Canon PC-1080F Plain Paper Laser Fax
How to change the receiving tray for faxes?
Look around for a small lever or lock that you adjust for one way or the other. open the top front and look to the left. it might be there.
Feb 12, 2008 | Canon FAX-L200 Plain Paper Laser
Canon FAX-L900 Plain Paper Laser Logo
91 people viewed this question
old marine
old marine
