Question about Polaroid FLM-4201 42 in. LCD Television
Polaroid tlx04240b lcd tv cant change input orany other functions.
Tv powers up with remote and manual buttons screen is blue but i cant get it to change inputs, volume or any other function with remote or buttons?
tried to play with a dvd player no sound or picture just a nice blue screen.
  • suu woo Nov 29, 2008
    wtf is up with these tvs mine is exactly the same
4 Suggested Answers
james klgr
  • 362 Answers
SOURCE: polaroid lcd hdtv 27" buzzzz
thre are several components that can make a buzzing sound, especially a bad power component or capacitor. check the capacitors to make sure they are installed in the board correctly. the stripe on the cap must line up with the white mark on the board under it. remove the back panel lay the tv down on a blanket turn it on and see if you can isolate the noise component by ear up close. and visually check for swollen capacitors the top will be pushed up round if bad if good it will be flat on top. warning if tv is less than a year old make the place you bought it replace it. so you dont void the warranty.
Posted on Feb 25, 2008
  • 4 Answers
SOURCE: polaroid tv
As a home theatre sales person, i can say that i have had my fare share of dealings with new TV manufacturers. Although sometimes what i am about to say sounds a little abrasive, it seems as though youve fallen victim to the newly developing 'disposibility' trending in electronics manufacturing. You may have already tried using the on board controls, and if that works, try an advanced learning remote control to regain control of the functions. if the onboard controls arent working either, you could try to send it in for repair if its under warrenty, or look at buying a new flat panel. The avg repair cost on an lcd is 300-600 for parts and labor, there are many 1080p 40-42 in the 600-800 range.
Posted on Jan 05, 2009
SOURCE: Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Posted on Feb 02, 2009
gcrcomputers
  • 170 Answers
SOURCE: I cannot program my Directv RC 23 remote to operate my Polaroid t
Here is the list from Direct tv with your Polaroid TV Codes:
Polaroid 10765, 10865, 11262, 11276, 11314, 11316, 11326, 11327, 11328, 11341
***Note: White remotes RC16, RC23, and RC24 may not be programmable to some later TV models
I hope this helps,
David
If my solution helped please rate accordingly
Posted on Mar 17, 2009
I'm trying to connect my Polaroid 15" LCD TV (model FLM-1514B) to my Directv box and only get a blue screen on the tv.
Turn off blue screen in the menu of the TV if you can or cycle through the input sources on the remote to find the directv signal. Check cable setup in back of TV if it still does not work. Has the directv box been working with any other TV?
Apr 13, 2010 | Polaroid FLM-1514B LCD TV
My 26" lcd television FLM-2601 polaroid is not working it constantly stays in standby mode you push power button and blue light flicks on then goes right back into standby mode how do i fix this?
First of all, check your input source on your TV.
Turn on TV.
Press the Input button on your remote.
Make sure the Source Input matches the corresponding device that is wired on the back of the TV.
Nov 12, 2009 | Polaroid FLM-2601 Television
We connected the computer to polaroid lcd screen and it doesnt want to turn on can any one help me
l;kl
  1. Use a D-SUB cable to connect the PC’s D-SUB output jack to the LCD TV’s VGA input jack. Use an audio cable to connect the PC’s audio output jacks to LCD TV’s.
  2. Connect all AC power sources, before turning on the power switch of the LCD TV or other connected equipment.
  3. Press the button on the remote to turn on the LCD TV.
  4. Press the Input button on the remote to select COMPUTER.
Sep 11, 2009 | Polaroid 3211TLXB 32 in. LCD Television
Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
May 29, 2009 | Polaroid FLM-4201 42 in. LCD Television
I hope this helps,
David
Mar 17, 2009 | Televison & Video
Tv screen has turned blue and I can't watch tv
i think by accident you have changed the input when you went to change the volume. look for a button labeled " input" or "video" select on the remote and scroll through the various choices. you should get your picture back.
Jan 21, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid tv
Dec 17, 2008 | Polaroid FLM-4201 42 in. LCD Television
Polaroid LCD universal remote
I used a Sony RM-V210 kind of long silver on top, black on bottom. It works for me.
Mar 17, 2008 | Polaroid FLM-3225 32 in. LCD Television
No Signal
You will have changed the video/audio input, on your tv, it should be an input button on remote. The signal will either be on AV1, AV2, AV3 Component or HDMI.
Jan 24, 2007 | Polaroid FLM-3225 32 in. LCD Television
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at http://www.remotes.com Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
Polaroid FLM-4201 42 in. LCD Television Logo
301 people viewed this question
Top Polaroid Televison & Video Experts
Dave Naylor
Dave Naylor
matt martin
matt martin
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
