Question about 2wire HomePortal 1000HW DSL Modem and Network Router -1000-400210-000_LN_R (1000400210000LNR)
Modem power adaptor
My modem's power adaptor (the one that was provided with the sales pack)recently bacame faulty. So i purchased a universal adaptor from an electrical store. With the new adaptor, my modem could be switched on. However, only the power indicator lights up. All the other indicator lights are "off". I tried changing the voltage on my adaptor form 12volt(which is the output stated on the initial modem, so i assumed that the new adjustable power adaptor need to be set to the same voltage as well) to 7.5volts. And only one more light appeared(LAN indicator light). But my PC i not able to detect the LAN connection at all. So, i purchased another adaptor and the same happens with the other one as well. Lastly, i connected the first replacement power adapter I purchased, and it worked. I was using the the modem for a short time until the issue started again. When the modem is connected to the adaptor with the output set to 7.5volts(other volts options like 12v, 11v, 3.5v dont work at all) only 2 lights appear to light up-POWER and LAN(but lan cannot be detected by the PC)....wht should i do???
  • Carl Navarro
    Carl Navarro May 11, 2010
    With any luck, you should buy an original power adapter and quit screwing around with the voltage. Or, just wait and buy a new modem.
    A DC power adapter requires two things, voltage and current. The guess is that you have 12 volts and not anywhere near the 1 amp of current usually required.
    Scholar:
  • 65 Answers
On the bottom of the Modem, it usually lists the type of voltage/current ratio, for example, My modem is a 12VDC in, output is .75A Through the modem. Each modem has its own power requirements. Therefore if they dont match, you have the chance of either underpower (which means no use) or overpowering (and killing your modem permanently)
Best suggestion si the same as above by cnavarro, Buy the Right power supply for it, dont just try anything. get the matching one. Otherwise it will be Incident A or Incident B. Neither would work well, and you would end up buying a new modem all together.
Posted on Oct 31, 2008
I believe my power cord is bad. I have the older style 2wire modem and they don't provide replacement cords to the one i have. According to AT&T person! How can i get one?
you can get an universal dc adapter from most big box retailers/ electronics stores. however given the age of your modem- you may see if AT&T would be able to replace the entire modem with a more recent modem
Jan 07, 2011 | 2wire (1000-000057-000) Modem
Power light is green and keeps blinking. it changes to red sometimes and i cant connect to the internet..
Hi der... well the issue your facing is simple to say ur power adaptor is faulty. Usually its due to some electrical shorts or maybe some heavy lightnings. You can remedy for it.
1st : Buy a new adaptor if available or sold seperately
2nd: call ur ISP to have it replaced if ur still under some contract term or if the modem is still under warranty. usually 1year warranty
3rd : you can buy ur own ADSL2+ modem from supporting outlets . Make sure ur isp supports this modem.
Or u can always contact the vendor of 2WIRE in your location. They might be able to assist u in adaptors replacing issues. I would suggest calling ur isp first and enquire. :)
This are the solutions for ur problem pal.. So make a wise decision.. Any needs and help post it to FixYa..ANd the experts here will fix ya..!
Oct 23, 2009 | 2wire (1000-000057-000) Modem
Modem stop working
Hi der... well the issue your facing is simple to say ur power adaptor is faulty. Usually its due to some electrical shorts or maybe some heavy lightnings. You can always have a remedy for it.
1st : Buy a new adaptor.
Aug 13, 2009 | 2wire (1000-000057-000) Modem
HI. The power light is red and the only other light is the wireless and that's green. I have model # 2701HG-B. I have unplugged, re-plugged, reset, etc..
Aug 04, 2009 | 2wire (1000-000057-000) Modem
Modem 2 wire redlight on power
Jun 30, 2009 | 2wire (1000-000057-000) Modem
Power light cycles to red, no other lights on
Jun 27, 2009 | 2wire (1000-000057-000) Modem
Inspiron laptop Battery won't charge
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
Apr 06, 2009 | Dell Inspiron 9400 Notebook
2wire 1800hg wireless gateway/router not functioning...
Your power adaptor might be faulty.  Yes, you can measure to have 6 volts.  But due to faulty electronic component in the power adaptor, the 6 volts will be dropped to a very low level due to "loading effect"  when you connect to the router.
I had the same problem but could not find the original power adaptor.  I replaced it with a 3rd party power adaptor.  You must ensure that the 3rd party power adaptor can provide 6V output with minimum 2000mA (2 amperes) and correct connector size.
Apr 07, 2008 | 2wire 1800HG Router (RG1800HG00)
Computers & Internet Logo
222 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
