Question about Taxan Crystalvision 680 TCO 99-S 15" LCD Monitor
Power supply? One of these beauties has come into my possession, but minus a power supply. Anyone help about where I can get one? bogl
0 characters
1 Points
When I turn monitor on, it stays on only 2 seconds, then goes dark. When I turn the monitor on, it lights for another two seconds, then goes dark. It is a MAG Innovision TCO 03 display. Thank you!
It could be two things. 1). The video card is set to a resolution the monitor does not support. 2). The monitor's power supply is bad. You can try to boot into rescue (or "safe") mode, and adjust the video card to a resolution the monitor supports. OR, power supplies usually go bad because capacitors bulge or otherwise go bad. Most monitor power supplies are hard to get, so people typically repair them. If you disassemble the monitor shell, you can see the power supply (where the AC cord goes). You can look at the metallic, cylindrical looking things with minus signs down one side, and if they look bulged on top, you can replace them. You can get replacements at
Mar 30, 2013 | Mag Innovision 19" LCD Flat-Panel Monitor...
Where are the plus/minus buttons that are talked about in the manual?
They are on the bottom of the face panel of the screen.
They may be marked 'V' and and 'inverted-V'.
Apr 02, 2011 | Acer V193w LCD Monitor
My monitor is unresponsive. Does not power on anymore. Does anyone have any troubleshooting ideas?
If your monitor uses a power supply (the brick that plugs into the wall, and then a smaller cord plugs into the monitor), then it's more likely the power supply that's gone out than the monitor itself.
Find someone with a multimeter to check the output voltage on the power supply. There will be a label on the power supply that says what the DC voltage (VDC) is supposed to be. If the meter shows no voltage when the power supply is plugged into the wall, then you just need a new power supply.
Do not try using another power supply as a substitute unless it is a specific match to your monitor. They vary widely by output voltage, etc. and using the wrong one could fry your monitor.
Hope that's helpful.
Jan 14, 2011 | Dell E207WFP LCD Monitor
My acer m464 cd/dvd will not format any cds it says microsoft not able to format i have no user manual THANKS
u do not format cd's , it maybe plus or minus specific cd format, look at blank cd's it has plus or minus sign on it try opoosite one
Jul 06, 2009 | Acer V193w LCD Monitor
Vp230mb power supply
Follow the ribbon cable from the pwr supply down to the motherboard. Near where it connects there are two "U" shaped wire loop test points. One is positive, one negative, 12V at 7.5amps.
Solder onto these. There is one other "S" wire which is for voltage sense. Don't know what to do with that one.
Inspite of all the wires in the ribbon, half are + and half are minus 12V, but it really needs the 7.5Amps.
Oct 11, 2008 | ViewSonic VP230mb 23.1" LCD Monitor
Pe 191m power
try the capasitos in the in line of the circuit they have to be electrolitic condencer some times with the time they open and made the monitor not work try it wiht analog multimeter is more easer know if the condencer are bad
Sep 05, 2007 | Planar PE191M 19" Flat Panel LCD Monitor
The circuit breaker popped due to power fluctuation or something else ? It is clearly understood that your LCD monitor suffered some component burn inside otherwise it would show 'NO SIGNAL' sort of Display if it is not connected. There is nothing to resset. Please open it up & check if there is any sign of burned component or take it to a service center if it is still under warrenty.
May 03, 2007 | Dell E153FPc 15" TFT LCD Flat Panel...
Taxan Crystalvision 680 TCO 99-S 15" LCD Monitor Logo
27 people viewed this question
Top Taxan Computer Monitors Experts
Brian Sullivan
Brian Sullivan
Are you a Taxan Computer Monitor Expert? Answer questions, earn points and help others
