Cordless mouse Hi there, my mum has a cordless mouse on her laptop and has deactivated the touchpad mouse on the laptop. The cordless mouse is not working, so how do I manually reactivated the touchpad mouse without a mouse????!!!!! Wouls a soloution be, to install a new mouse via CD rom? A
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Have you tried new batteries in the current cordless mouse?
  • Vivian
    Vivian Dec 06, 2016
    Maybe the mouse pad is work out, you can try this one:http://www.ebay.com/itm/2-4GHz-Cordless-...
Just a thought, perhaps you could borrow a usb cable mouse. Tell the comp to detect the wireless mouse, then unplug the usb mouse.
Posted on Nov 02, 2008
Hi, i have a Acer Aspire 5 laptop computer, running on Windows 8. occasionally, my mouse (not cordless by the way) will randomly spasm, shooting all over the screen an clicking. I have tried changing my...
Sometimes it occurs due to the problem with touchpad. try one thing just turn off the built in touchpad and than check if it occurs again, I hope that should work for you. If that work for you than try to uninstall the drivers for touchpad and if your computer is under warranty than try to replace the part.
Feb 07, 2014 | Computers & Internet
Touchpad doesn't work
Step 1:
The touchpad of any laptop is always subject to heavy use.
Most touchpads are designed for their durability to sustain the daily wear and tear for the lifespan of the laptop.
However, there may be instances or accidents that cause the touchpads to malfunction or stop working entirely.
There are ways to troubleshoot such problems and there are also remedies to salvage the touchpad's functionality without heavy repair or replacement cost.
Determine What's Wrong
A laptop's touchpad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touchpad may be damaged by excessive use or foreign substances such as water, dirt or food items. Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return." Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touchpad to become unresponsive. But if any of these steps fail to remedy the problem, then the touchpad may need to be repaired or replaced. b> Repairing/Replacing Touchpad b> A touchpad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touchpad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touchpad is deemed a necessity, such repairs are rarely worth the cost. Attempting to replace the touchpad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop. Long-Term and Better Solution b> The simplest, and best, solution to a malfunctioning touchpad is to replace its functionalities with an external mouse. Most PCs sold after 2000 come with USB ports and getting a USB mouse either a corded or a cordless one--will remedy the problem. A cordless USB mouse may be bought for as little as $10 and some of the better-designed ones allow the user to tuck the USB stick inside the mouse's belly when not in use. Even when a touchpad is working properly, a laptop user should be advised to plug in a mouse anyway whenever possible as touchpads are notoriously difficult to use and also leaves the user in an ergonomically incorrect position.
http://www.microsoft.com/ b> http://www.streetdirectory.com/travel_guide/116002/hardware/touchpad_keyboard_for_personal_computers__pc.html
Feb 19, 2013 | Computers & Internet
Lo scroll touchpad non funziona samsung p530
google translated
touchpad scroll does not work samsung
Feb 07, 2013 | Samsung P530 Notebook
My Advent 5421 Touchpad Is Not Working!!!
Advent laptop computers are equipped with a touchpad and two buttons that service the function of an external mouse. The touchpad can be turned on or deactivated, depending on the user's preference. It's not difficult to either activate or deactivate it.
Power up the computer. Connect a plug-and-play computer mouse to a free USB port on the laptop. The mouse is just temporary to help you get the touchpad working again. Locate the touchpad icon, which is in the lower right-hand side of the screen. The icon will appear as a gray square or rectangle, with two rectangular buttons underneath. Use the mouse to double-click on the touchpad icon, opening a window on your laptop screen. Inside the touchpad window, click the option labeled "Enable Device". Select other options for the touchpad, such as pointer speed and shape. Click "Apply", then "OK". Disconnect the mouse from the laptop.
Feb 02, 2013 | Advent Computers & Internet
Hi, my brother has locked the touchpad/mouse part of my mums laptop and I cant find out how to unfreeze/unlock this. It is a packard bell easynote tj61.
there are a few button over the keyboard, one of them is the switch of you touchpad mouse.
If the led of the touchpad mouse button is on, then the touchpad is unlocked.
And viceverse.
Good Luck. Remember to rate my answer.
Feb 16, 2011 | Computers & Internet
I want to purchase a cordless mouse for my dell laptop.
Hi
You can buy a cordless mouse for your laptop from this link---
Cordless/Wireless Mouse for Dell laptop Link 1
Some more options are available on this link--
Cordless/Wireless Mouse for Dell laptop Link 2
Daniel Scott
Jun 14, 2010 | Dell Computers & Internet
Touchpad will not move censor. Cordless mouse will. Can the touchpad be locked? Solution?
Hi, try updating drivers for touchpad from acer website 1st. or it could be a fauly pad
Aug 04, 2009 | Computers & Internet
How do i operate the mouse on a toshiba 8200
hi, you probably have to disable the touchpad, for the microsoft mouse to work properly, i had same problem on my notebook. i conflict of software for touchpad made my microsoft cordless mouse not work, until i removed the touchpad software. i hope this is helpful,good luck!
Feb 13, 2009 | Microsoft Wireless Optical Mouse
Cordless mini optical mouse
My Logitech cordless mouse quick working when I checked into a motel. How do I get the mouse working again? The touchpad is driving me whacko!
Sep 14, 2008 | Logitech Cordless Mouse
Computers & Internet Logo
920 people viewed this question
David Payne
David Payne
