Question about Tascam 2488 Portastudio Multitrack Recorder System
Connect yamaha keyboard to tascam 2488 MKII
There doesn't appear to be a port of any kind to attach a keyboard to the 2488. There's a 1/4 inch port for a guitar and for headphones. There are microphone ports and a usb port on the back. I don't see where a keyboard will attach.
    Novelist:
  • 189 Answers
There are 8 inputs on the back. 4 of them support XLR type microphone connections, but also double as 1/4 inch and the remaining four are just 1/4 inch. These are all line level inputs and you can use any of them for a keyboard hookup. Typically you might leave the XLR inputs (A thru D) available for mics and take the next two (E and F) to use from your keyboards L and R outputs. Then just assign those inputs to two adjacent channels (tracks) or one of the stereo pairs, turn up the input levels for those inputs and the faders for those tracks and you'll be able to hear the keyboard playing through the 2488 (or whatever monitors/or stereo you have hooked up to it for monitoring). To record the keyboard simply arm whatever tracks you have those inputs assigned to for recording and record away.
bd.
Posted on Oct 30, 2008
How do i load a song from a cd onto tascam 2488 mkII?
Although I was a factory authorized service center for Teac and Tascam, this is a much later product than I'm familiar with; no problem however.
If you have your owner's manual, the procedure will be listed there. If you no longer have the manual, just Google Teac, in Montebello, CA. I'm quite sure it will be our their website.
Jun 12, 2014 | Tascam 2488 Portastudio Multitrack...
My husband and I just purchased tascam 2488 portastudio, we are truly novice and need help with figuring out what cords are needed to connect the mics we have to the tascam. We would also like to know is...
If your mics are XLR (a hole on the bottom of the mic with three pins visible in it) you will need one of these for each mic, plugged into one of the four channels on the tascam that has an XLR connection (which will be the female version of the connection on the bottom of your mic). If your mics have a 1/4-inch connection, you can use the 1/4-inch connection on any channel on the tascam. For the stereo connection, you will need one of these of sufficient length to convert the RCA output from your stereo to the 1/4-inch input on your Tascam. Find "Tape Out" or "AUX Out" on your stereo and plug in the RCA side of the cable there (note which color you use for R and L). Use the 1/4" end of the cable to connect to two available channels on your mixer. Use the Pan knob to pan the left channel to the left and the right channel to the right, and voila! Hope this helps, and good luck!
Nov 13, 2009 | Tascam 2488 Portastudio Multitrack...
Control midi program sampletude
The Tascam has no midi In,Out or Thru so the answer is No.
Apr 21, 2009 | Tascam 2488mkii 24 Track Recording...
2488 as an interface
yes if usb connection
yes if you can connect line in line out connection
yes pararlell port connecting
May 07, 2008 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
In the monitor section on the 2488 console (upper right) make sure your monitoring source is set to 'stereo'. Then make sure your 'monitor level' control is turned up. The 'stereo' fader (sub mix fader on the MKI, stereo fader on the MKII).
Dec 26, 2007 | Tascam 2488 Portastudio Multitrack...
Don't know how to Pre-Master or Burn to CD, please help me!
Don Q -
This answer assumes you have the 2488 mkI and not the newer mkII because the process may differ slightly on the mkII.
To premaster you first have to set an out point for the end of your pre-master (the start point is always zero). Go to the 'Audio CD' menu item and choose 'pre-master' under that. You'll see the word 'mastering' appear in the top left of the screen to let you know you've entered mastering mode. Make sure you have the tracks unmuted that you want to mix into the pre-master and have all of your eq, panning, etc set the way you want. Then hit record and play. The pre-master records to a stereo pair of dedicated internal tracks. You can redo the premaster as many times as you like which will overwrite those internal premaster tracks. You can clone the premastered tracks to a stereo pair of tracks, export them as waves or burn them to a CDR.
fnawesomewes - You have to press record and play to record your premaster.
Dec 07, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488
Link to Tascam 2488 documents page:
http://tascam.com/Products/2488_downloads.html
Individual Items as Listed:
Link to the Tascam 2488 product brochure:
http://tascam.com/Products/2488/2488_bro.pdf
Link to the Tascam 2488 application guide:
http://tascam.com/Products/2488/2488_AppGuide.pdf
Here's the link to the Tascam 2488 quick start guide:
http://tascam.com/Products/2488/2488_quickstart.pdf
Link to the updated Tascam 2488 manual:
http://www.tascamcontractor.com/ftp_resour...w_additions.pdf
Link to the Tascam 2488 manual additions:
http://www.tascamcontractor.com/ftp_resour...e_additions.pdf
Link to the Tascam 2488 MIDI Parameter Mapping
http://www.tascamcontractor.com/ftp_resour...ontrol_v0.2.pdf
Link to TASCAM 2488 Hi-Res images:
http://www.tascamcontractor.com/ftp_resour...488_images.html
Oct 23, 2007 | Tascam 2488 Portastudio Multitrack...
Tascam 2488 Portastudio Multitrack Recorder System Logo
432 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
John
John
Michial Gueffroy
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
