Question about Dryers
Push to Start switch does not Start Kenmore Elite Dryer Mod # 11065944401
Push to Start button switch does not start dryer. If I direct short the terminals on the back of the switch (or just push the switch), I hear a very faint click coming from the timer switch. I've checked that the door switch seems to be working as it activitates and turns off the light.
  • Anonymous Mar 23, 2014
    Roper Dryer RES7745RQ0. Will not start
  • 550 Answers
A likely cause is failure of the relay.
the start switch provides a current to energise a relay,
the relay latches open (draws energize current from switched circuit) until current path is broken by the timer or door switches.
if the wires have come off the relay(happens) or the coil of the relay has failed, there will be no start.
With plug pulled
trace the wires from the start switch, to the first device, looks like this Push to Start switch does not Start Kenmore Elite  - 8fc4980.jpgmay be opaque. if any of the wires have come off refit them and retry start.
relay diagram looks like this 5a14628.gif test with meter for conduct between terminals labelled 85 86 (or Coil in other labelling standard),
or take to appliance parts store, can test and provide replacement on site.
Appliance part store will likely provide part labelled whirlpool, not a problem all the small parts are interchangeable
NOTE dryer relay may have up to 8 terminals,
2 for coil
3 (open close common) for each phase
Posted on Oct 30, 2008
Kenmore Elite Gas Dryer starts/runs/drys only w PTS held on?
push to start button needs replacing,sometimes you can jump that out if you have another switch that starts the dryer when you close the door
Jan 15, 2013 | Kenmore 73952 Gas Dryer
I have a Kenmore dryer, mod 110 60956990, ser MJ4102370, type DDOT-ELE-2406028-EH54. When I push the button to start the dryer, nothing. If you wait several minutes, it sounds like it is trying to come on...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 28, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
I have a kenmore elite MOD#110 60992990 that when you push the "Push to start" switch the motor start however it shuts off as soon as you let go of the switch.
There can be many reasons why your dryer will not turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Aug 10, 2010 | Kenmore Dryers
Kenmore mod 110 87870110 gas dryer- at first push
the vent could be plugged and unit is going into thermal overheat if it works in timed dry properly then the moistier sensor is faulty.
Dec 01, 2009 | Kenmore Dryers
Dryer won't stay on. I press the start button and it won't work unless I keep the button depressed manually
Hi, your start push button is malfunctioning. simply replacing this start switch will fix your issue.
May 20, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite HE3 Dryer (3 yrs. old)
when u push the buttons do all lights light up if so ,, machine is in lock mode ,, press and hold the little icon that read lock for about 3 seconds unitll lights are off then run ,, let see
Nov 19, 2008 | Kenmore Elite HE4 Electric Dryer
Need help with OLD dryer
IF YOU MEAN THAT THE DRYER STARTS BACK UP WHEN YOU CLOSE THE DOOR, THE PUSH TO START SWITCH IS SHORTED. CHECK TO SEE IF THE PUSH TO START BUTTON IS STUCK PRESSED IN AND NOT SPRINGING BACK OUT.
IF IT IS STUCK, TRY WD-40 TO LOOSTEN IT. OTHERWISE, REPLACE THE SWITCH.
IF THE DRYER KEEPS RUNNING WHEN YOU "OPEN" THE DOOR, THE DOOR SWITCH IS SHORTED. REPLACE THE DOOR SWITCH.
Mar 31, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer stops
your motor switch is gone you can either change the switch or motor you could try tapping the switch sometimes it will free the contact this switch is on the motor
Dec 09, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
977 people viewed this question
Top Dryers Experts
