Question about Proview PL926WBi 19" LCD Monitor
Proview 900T hi i have a proview 900T flat panal tv that i am having problems with. every time i turn it on it shows the picture for a second then goes black but i can still here the sound perfect from the channel. I moved the tv upstars to see if it was the cable but the same happened. what do you think it could be? i slept with the remote one night could i have put it on a setting that made it do this? please help!
  • jason May 11, 2010
    sleeping on the remote will not do it but it sounds like there is a problem in the video processing board , if you have a warraty i would use it
    have you tried the other video inputs on the tv to see if you can get video out of one of those?
    if you have and you get nothing but sound then it will need repair
    unfortunately these video boards have been going out like crazy , they just don't give them any type of good cooling system so the chips go into thermal break down , thus failing
    hope this helps and sorry about your tv
    electech
  • 905 Answers
Hope this helped you , if you need more help just ask and i will assist you as best as possible
electech
Posted on Oct 31, 2008
No sound on proview 900t tv
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Sep 01, 2014 | Proview Televison & Video
Proview mh422 su no picture
the cable my have a short or the dvd box might be connected wrong if your wires are not connected write the tv will continue to do that
Dec 29, 2009 | Proview Mh422su 42 in. EDTV-Ready Plasma...
Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 07, 2009 | Proview PA-32JK1A 32 in. LCD Television
TV Backlight turns off after a sec
its not the lights because i plugged in a screen from an old dell laptop and it does the same thing, light turns on and off in a few seconds
Jul 03, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
I have the pink screen of death on my Proview model 900T
on the ac circuitboard replace the two 1000uf 24v with ones from radio shack,with two 1000uf 35v i just did it yesterday it works mint total time 45 min if your good with soldering gun good luck
Jan 10, 2009 | Proview PL926WBi 19" LCD Monitor
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Sylvania (proview) cl2072b flat panel monitor
Well the first and second paragraphs make me say the Inverter/power board must be replaced.
A white display typically means either your display cable (in your monitor) is loose or logic board is dead.
Either one of these things typically mean take it in for an estimate to repair, and if it's too much, buy a new one.
With your luck I think I might switch to big cheap CRT.
Mar 12, 2008 | Proview PL926WBi 19" LCD Monitor
Proview PL926WBi 19" LCD Monitor Logo
652 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Pawan Ambastha
Level 1 Expert
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
