Question about Lasko Ceramic Heater
Model 5800 How do you set the auto setting to 60 degrees
  • 3 Answers
In page three in the manual it shows you how to set your temperature settings.Model 5800 - eb6548e.jpg
Posted on Oct 30, 2008
Sign comes up "88 blinking abd the heater stops working
Posted on Sep 07, 2010
The head was done and I need the torque setting for this vehicle.
M10 bolts: 1st step; - 18 ft./lbs. 2nd step; - turn 60 degrees 3rd step; - turn 60 degrees M12 bolts: 1st step; - 22 ft./lbs. 2nd step; - turn 60 degrees 3rd step; - turn 60 degrees
2.0 Engine
Feb 02, 2016 | 2005 Hyundai Tucson
Thermostat set at 72 degrees on auto cool setting
Check the tstat's for a relative humidity setting. If it has that option set it to 60 percent. If not, make sure to check all programs if it's programmable. If not those 2 options, it may need to be replaced.
Oct 21, 2017 | Heating & Cooling
60 degree wash wont spin
Would it not take time to heat up water to 60 degree temp before it starts to spin ?
May 03, 2014 | Zanussi Washing Machines
Head bolt and overhead cam bolt settings for hundai lantra 1.8 litre
Hi there:Check this image for cylinder head bolt loosen and tighten sequence-1.5L (VIN K), 1.6L (VIN R), 2.0L (VIN F) and 1996-98 1.8L (VIN M) engines
Specs: 2.0L (VIN F) and 1996-98 1.8L (VIN M) engines- Tighten M10 bolts to 22 ft. lbs. (30 Nm), plus 60-65 degrees, plus 60-65 degrees. Tighten M12 bolts to 26 ft. lbs. (35 Nm), plus 60-65 degrees, plus 60-65 degrees.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 11, 2012 | 1998 Hyundai Elantra
Overhead cam bolt settings for hyundai 1.8 litre
Hi there:
Jun 11, 2012 | Cars & Trucks
Big ends torque settings head torque settings
10 mm bolts
step 1 22 ft lbs.
step 2 60 degrees
step 3 additional 60 degrees
12 mm bolts
step 1 26 ft lbs
step 2 60 degrees
May 26, 2011 | 1998 Hyundai Elantra
What are the torque settings of the j2 1.8GLS 1996 hyundai elantra
cylinder head bolt torque
10 mm bolts
step 1 22 ft lbs
step 2 additional 60 degrees
12 mm bolts
step 1 26 ft lbs.
exhaust manifold nut 32-41 ft lbs.
intake manifold nut 11-15 ft lbs.
rocker cover 71-86 in. lbs.
Dec 14, 2010 | Hyundai Motor 1996 Elantra
I have a used air conditioner with no book--i need some directions. i've been guessing as how to operate the machine and am getting cold air but am unsure that i'm running it right
Thermostat shoud be on auto and cool. Setting is normally set at 75-78 degrees f.In the winter, keep it on auto and heat. Setting should be kept around 60-65 degrees f.
Jun 27, 2009 | Heating & Cooling
AIR CONDITIONER ONLY BLOWING COLD ON ONE SIDE AFTER DISCONNECTING BATTERY
Turn your AC off. Turn the car off Crank the car turn ac on drivers side to 60 passenger side to 90 press auto wait 1 minute turn AC off (very important) turn car off turn car back on switch driver's side 90 passenger 60 press auto wait one minute turn AC off( very important) turn car off turn car on AC 70 both sides press auto your ac should be blowing cold If not, you have an expensive problem
Aug 25, 2008 | GMC Sierra Cars & Trucks
Lasko  Ceramic Heater Logo
650 people viewed this question
Top Lasko Heating & Cooling Experts
Steve
Steve Oakes
Are you a Lasko Heating and Cooling Expert? Answer questions, earn points and help others
