Question about HP Office Equipment & Supplies
Printer Prints the same thing over and over again
    President:
  • 1,901 Answers
First thing to check is to see if you have documents in que.
Click Start>Printers and Faxes. Are there all 0 (zero) under the heading "Documents"?
If there is anything but zeros, double-click the printer icon. In the window that opens select Printer>Cancel all Documents.
If that is good, open any document and select File>Print. In the window, is the "Number of Copies" box 1 (one)? If not, you need to set your printer default settings.
Posted on Oct 30, 2008
HELLO: PRINTS ONE LABEL
This could have a couple of different causes. Best thing to do is determine if the problem is with the printer or the software. Turn the printer off and back on again. After the power-on self test is done, just press the feed key. Does the printer feed just one label ? If so, then you know the printer has a good calibration on the size of the label. Now print a label. Does it skip one after printing ? If it does, now you know the problem is in the software because the printer is only going to do what it’s told to do. Check all settings in the label software / printer driver to make sure label size is accurate, correct printer driver is being used, etc.
So first check to see if the printer is ok by itself. If it feeds two labels after powering up, then the calibration is needs to be redone. Also make sure the media sensor is positioned over the label. This can cause skipping as well if out of position.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
Photosmart 3210 - A Printer alignment failed error
Mine has done the same thing.
To fix this you have to reinstall the software, then reboot your computer.
I did that, and the printer alignment function worked fine for a while, then I started getting the same problem again, possibly after I had installed other software not related to the printer -- I don't really know.
In any event, it's doing the same thing again, so I just "cancel" the alignment and continue to use the printer. My prints are fine.
Jul 20, 2009 | HP Photosmart 3210 Printer
Only prints one page then stops
I have a HP Laser jet 4L that prints one page then skips the next.
I uninstalled the printer then re-installed which temporarily fixed the problem, now it's doing the same thing again. Please help!
Nov 28, 2008 | Office Equipment & Supplies
My printer always prints the test page
go to printer folder
choose the printer you have as default and right click on it
choose properties
choose printer preferences
in the banner part disable it
and thats it
Nov 24, 2008 | HP PSC 1315 All-In-One InkJet Printer
The printer won't print what I want it to.
hi,
try to replace the printer cable or usb cable to fixed your problem...
rey
Nov 02, 2008 | HP DeskJet 932c InkJet Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
The printer prints nothing
maybe the printer is out of ink! or try printing again!
laser printer at home did the same thing, but when i tried it again it was fine!
Oct 16, 2007 | Lexmark P707 Photo Jetprinter InkJet
Prints continuously
sounds like when it wasn't printing properly, you tried to print several times, not realising that prints which were not printed at the time were being stored to print when the printer was available.
you need to check the print queue, by clicking on the printer icon in the bottom right hand corner of the screen(by the clock)
you should be presented with a list of pending documents, which you can delete or suspend as required.
if the printer icon cannot be found next to the clock you can find it under START>settings>Printers
Oct 13, 2007 | HP PSC 1350 All-In-One Thermal Printer
Ben Johnson
